Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 17, 2009, 09:18 PM   #1
Personal Sales Rating: (0)
iamaiun's Avatar
Drives: RR Evolution X GSR SSS
Passenger headlight won't move along with the dial.
Hi,
I'm pretty sure this is not covered yet and is not a repost but if it is, I'm sorry.
I just recently blacked out my headlights and i noticed when I moved the headlight dial, my passenger headlight wouldn't adjust, it would remain stationary, while the driver headlight moved up and down perfectly.
Has anyone had a similar problem, and how can I go along and fix this?
Thanks ahead of time.
Offline
Old Sep 17, 2009, 09:37 PM   #2
Personal Sales Rating: (27)
rogue's Avatar
Drives: WW EVO X.... previously -EVO IX - Apex Silver
Send a message via AIM to rogue
Did you recheck your connections at the headlight?
Offline
Old Sep 17, 2009, 09:40 PM   #3
iamaiun's Avatar
The headlights work fine. Highbeams, indicator and signal lights. It just won't move along with the dial.
Offline
Old Sep 17, 2009, 10:42 PM   #4
Personal Sales Rating: (4)
Drives: 08 PB EvoX
When you painted it, did you remove the internals to paint them?
The motor connects to the internals by a little "ball" joint, so you need to make sure that is properly seated. If the electronics are fine, it's probably this mechanical connection.
Offline
Old Sep 17, 2009, 10:56 PM   #5
iamaiun's Avatar
I basically only removed the bulbs, the wires connected to the bulbs and the power box I think. I didn't mess with anything from the inside. Could you explain where the ball joint is located in more detail? I want to know for sure before I have to take my bumper off again and my light.
Thanks.
Offline
Old Sep 18, 2009, 12:08 PM   #6
Drives: 08 PB EvoX
Wow, I actually have pretty damn good pictures of this!
Now, first off, I'm not saying that this is necessarily your problem. However, it is a potential reason in why your level switch isn't causing movement of the passenger side. You may not even have to take the bumper off, you might be able to get the closest bulb out, get a gloved finger in the housing and pull the internals towards the back of the housing towards the ball.
Here is the outside of the housing, with the motor circled. This is the location of the ball joint, as the motor essentially just pushes the ball in or out depending on the setting.
Now, the internals. The connector on the internal component is a yellowish clip (mine is slightly damaged in this photo, the light was salvaged from a crashed car and repaired) that snaps over the ball (circled but slightly out of focus).
Offline
Tags
adjust, headlights
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
