Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 15, 2009, 09:25 AM   #1
Personal Sales Rating: (0)
CatalystGod's Avatar
Drives: Evolution X GSR Graphite Gray
Brake Oil Bleeding
Hello,
I was planning on doing a SS line install and changing the brake oil on my X. I have been doing some reading on the following excellent link for a How-To.
http://www.joe250.com/cars/evo8/brak...ebleeding.html
However, I just realized, there wasn't much detail on how to drain the existing fluid in the first place. Is it as simple as the following?
1) Opening all nipples, bleeding/draining as much as possible by pumping the brakes.
2) Replace the lines with the SS lines.
3) Refill the reservoir with the new fluid
4) Then follow the directions in the above posted article.
__________________
Keep yourself informed:
http://www.zeitgeistmovie.com
Offline
Old Sep 15, 2009, 09:33 AM   #2
Personal Sales Rating: (5)
Drives: Blue 2004 Evo, 1969 Datsun 2000 roadster.
Dude, dont pump the brakes with the bleeders open, you will be there all day that way. Replace the lines, you will lose plenty of fluid. Fill the resevoir, BTW dont let it get empty while you are changing lines. Add fluid when you have lines replaced, bleed in the proper order, you will likely go thru 1.5-2 bottles of fluid --fyi. When your done you will have fresh fluid in all lines and calipers. I just did this myself 2 wks ago--trust me.
Offline
Old Sep 15, 2009, 09:40 AM   #3
Personal Sales Rating: (13)
migs647's Avatar
Drives: cheetahs crazy with his Evo X MR
Make sure you make a bottle with some tubing to put over the nipples into the bottle. You do NOT want brake fluid on those pretty brembos. Or you will deal with the consequences of the clear chipping / peeling.
__________________
2008 Evo X MR GG -- New
2003 Evo VIII RR -- Sold
2004 Lancer Ralliart LB -- Sold
English Racing -- MidgetSpec -- ETS -- Ralli////Art -- Blitz
Quote:
Originally Posted by EvosnatcH
Welcome to your new addiction, its kind of like crack with out all the side effects minus the burning hole in your wallet
Offline
Old Sep 15, 2009, 09:44 AM   #4
Quote:
Does it matter that I am moving from the Stock brake oil to Motul RBF 600? Dont want the two oils to mix, or does it really not matter if there is still a little bit of the stock oil in there?
This is what I understand from what you said:
1) open the cap on brake oil reservoir.
2) open the stock rubber brake line.
3) let as much fluid flow out as possible before putting on the new SS line.
4) Then, refill the reservoir with the new fluid and follow instructions as per the article I posted earlier.
In step (4), should I just keep filling in the new oil as the old oil level is going down, in order to prevent too much air, or should I just let it all drain before I start pouring in the new fluid?
Thanks in advance.
__________________
Offline
Old Sep 15, 2009, 09:45 AM   #5
Quote:
I have been warned, thank you sir!
__________________
Offline
Old Sep 15, 2009, 03:18 PM   #6
Drives: Evo X GSR
If you bleed it properly, all the old stock fluid will get flushed out of the system, leaving only the new fluid in the system. I'm not sure on the order to bleed either. It should be in the service manual. By order, I mean which corners do you bleed first. It's VERY time consuming, but you have to patiently bleed the brakes to get all the old fluid out and new fluid in.
In step 4, also make sure you always keep the reservoir filled. Don't let it go empty or you will introduce air into the system and have to start from scratch again. This is also a two-person job if you do it manually with the pumping method. I'd advise getting someone who has done it before to help you since you seem to be unsure about some of the steps required.
Offline
Old Sep 15, 2009, 03:26 PM   #7
EvoM Moderator
Personal Sales Rating: (24)
atombomb33's Avatar
Drives: Evo X - GSR
Of utmost importance...DO NOT LET ANY AIR INTO THE BRAKE LINES. That could be catastrophic. If you're not 100% sure you can do it right, please take it to a shop. Bring your fluid with you and ask them to bleed the brakes and put in the new fluid.
__________________
2008 Evolution X - GSR Apex Silver /// SSS - Aero - Navi
Forum rules & regulations
Offline
Old Sep 15, 2009, 10:00 PM   #8
Thank you, I do plan on doing it with my dad or a friend of mine. I definitely wanna get this right, and hence all the questions.
__________________
Offline
Old Sep 15, 2009, 10:08 PM   #9
Quote:
I definitely have no intent of letting any air in either. I am confident about the bleeding to get rid of air. Where I am drowned in a cloud of doubt is the step in which we start adding the new oil. How can we ensure that the old and new oild do not get completely mixed up? In my mind, I see two liquids being added to the same reservoir, so I will think that they will naturally mix. This is where I have all my questions. I wish that article I posted had a few more details.
But where's the fun in that? . Seriously, I obviously dont wanna kill myself, but I also wanna learn to do it. Rest assured, I will not attempt it unless I have the steps jotted down 100% of the way.Until then, they'll just be sitting in my garage, no big deal. I'll take my time, thank you very much for the warning and advice though, I know you only have the best intentions in mind when yoiu say that .
__________________
Offline
Old Sep 15, 2009, 10:45 PM   #10
migs647's Avatar
BTW, the bleed order is 4, 1, 3, 2... right rear, left front, left rear, right front
And I've read you need to have the car running to pump ABS... not sure if that's true but I did anyways on my VIII.
__________________
Offline
Old Sep 16, 2009, 12:55 AM   #11
Personal Sales Rating: (7)
jdm_evo's Avatar
Drives: X
just follow the instructions and you will be fine. i recently just replaced my oem lines with ss lines and motul rbf 600.
Offline
Old Sep 16, 2009, 04:50 AM   #12
mad_VIII's Avatar
Drives: Curzio's mom
BTW man, it's not OIL it is fluid. And if you have never bled brakes before you need to find a general how-to for BRAKE FLUID BLEEDING or BLEEDING BRAKES, it sounds like you may still be a little confused about the sequence of events that need to take place to force the old FLUID out of the system.
__________________
Wicked White GSR SSS
93pump - 363 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (448 hp shootout)
Blouch Dominator 1 | Cosworth MX1's | HKS EVC VI | Ultimate Racing 02 Back | RC 750cc | DYNO4MANCE EcuTek Tune
Old Whip: 93pump 21psi - 340 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (~392 dynojet)
L.Y. VIII | DYNO4MANCE Tuned AEM EMS | HKS 272's | FPGreen | Cusco Twin | Shep Stg2 TC | KW V3's | TE-37's
Offline
Old Sep 16, 2009, 04:56 AM   #13
one more thing, the calipers are 2 part, you need to bleed outside then inside following the order given above.
Offline
Old Sep 16, 2009, 07:30 AM   #14
Personal Sales Rating: (3)
2008 Mitsubishi Lancer Evolution
MrBonus's Avatar
Drives: 2008 Evolution X GSR, 2009 Mini Cooper JCW
Send a message via AIM to MrBonus
I highly recommend getting a power bleeder and saving yourself the headache of having to do the two-man brake pumping routine.
Offline
Old Sep 16, 2009, 08:57 AM   #15
The article I posted in my first post actually has the order in it with a schematic. I intend on following it, unless someone's gonna tell me it has changed for the X.
__________________
Offline
Tags
abs, bleed, bleeding, brake, brakes, breaks, evo, f150, ford, oil, pump, pumping, replacing, sequence, start
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
