Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 12, 2009, 03:06 AM   #1
Personal Sales Rating: (0)
How hard to install a regular downpipe ( No O2 housing)
I read some threads about installing the O2 housing downpipe such as AMS, but I don't see any "how-to " for installing the normal one. Is it hard? and what tools do I need? Thanks~
Offline
Old Sep 12, 2009, 05:16 AM   #2
i64X's Avatar
Drives: 2008 Evo X GSR SSS
Pretty simple if you've ever done exhaust before. Get the car up on stands, crawl under there and look. You'll want to disconnect the cat from the rest of the exhaust first, and then pull out the O2 sensors and set them aside so you don't break them or stress the wires by moving the exhaust around. You'll need an air impact gun and about 2 feet worth of extensions and a couple wobbly adapters in order to get to the bolts you need. The bolts are about half way up the firewall and they're hard to get to. I also had to remove the crossmember that goes under the downpipe. It's not a big deal and takes like 2 seconds with an impact, but it's about 30-40 lbs so make sure you have the car high enough to get under it and move it out of your way (and can hold it up with your chest or something when it's time to put it back).
Without any how-to I did the full Perrin downpipe and exhaust in about an hour. It wasn't really hard at all. If you're even the least bit mechanically inclined you should be able to pull it off pretty easily. Things start to get pretty self explanatory once you're under there.
Offline
Old Sep 12, 2009, 05:35 AM   #3
Personal Sales Rating: (5)
TIBOevo's Avatar
Drives: 03 EVO V111
Send a message via MSN to TIBOevo
make sure you have good jack srands before you start tugging and pulling hard on stuff. you would want the car to collapse to the ground while your under it! be careful and use lots of safety.
__________________
http://s253.photobucket.com/albums/h...t=72c0b584.pbw recent pics
to FAIL, or not to FAIL?. that is the question.
Offline
Old Sep 12, 2009, 07:07 PM   #4
I want to buy an air impact wrench too. Do you know how much CFM does your impact consume at 90 psi? Thanks
Offline
Old Sep 13, 2009, 03:31 AM   #5
Personal Sales Rating: (1)
sne2040's Avatar
Drives: 2008 Evolution X
Send a message via AIM to sne2040
just make sure you get a good amount of wobble extensions because it's a PITA to get those bolts out with one long one.
Offline
Tags
downpipe, evo, evolution, evolutionm, housing, install, lancer, o2, pipe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
