Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 3, 2009, 02:49 PM   #1
Personal Sales Rating: (5)
Spunkysandoval's Avatar
Drives: 08 Evo X
Send a message via AIM to Spunkysandoval
HOW TO : fuel pump relay 1 test
My hand writing is not the best, so here the steps.
Step 1. Swap relay A-27X (fuel pump relay 1) with relay A-21X (Headlight Relay high)
Step 2. Turn car on so the headlamps can be turned on low beam. Observe the headlamps to see the light pattern and identify which bulb is illuminated.
Step 3. Turn the high beams on and observe the headlamps again to see if there is any change in the bulb that is illuminated, or if there is any light at all. If there is no change and there is no light at all, the relay is bad.
*NOTE* be sure to observe the high beam state for at least a few minutes because the relay can stay on for a while and then turn off. It can also just not work at all
if there is any questions, please ask. I performed this test on my GSR and on the GSR, there is two seperate headlamps for hi/lo beam. I'm not sure how the hi/lo beam is distinguished on the HID equiped models, but I assume it comes from the projector and there wont be any light at all when the hi beams are on with a failed relay.
EDIT:
For clairity on relay position
__________________
Fender Roller For Rent in So Cal
I do fenderwork, pm me with questions :D
Mods: Invidia Riceback single exhaust, tightened stock ricegate actuator, ricemasters clutch, hawk ceramic rice pads, hks drop in rice filter :P
Offline
Old Sep 3, 2009, 02:54 PM   #2
Personal Sales Rating: (1)
2 Deep Motoring's Avatar
Drives: 2006 Mitsubishi Evo IX MR(Sold), 2008 PB Evo X GSR
Send a message via AIM to 2 Deep Motoring
maybe im over analyzing this but long story short... if the relay is bad, the high beam should not come on at all.. am i correct? does this apply to HID equipped head lights?
__________________
2006 GG IX MR (SOLD)
2008 PB X GSR
Offline
Old Sep 3, 2009, 02:59 PM   #3
Drives: 08 Evo X
Quote:
Theoretically, you are correct. However, relay failure is not always black or white. There are grey areas. Relays can turn on and be fire for a few seconds, but then fail durring operation. Relays that that are on their way out will fail in this way. I personally observed this type of failure in my tests, both on the bench and using this method described above.
__________________
Offline
Old Sep 3, 2009, 03:34 PM   #4
Personal Sales Rating: (0)
Drives: Evo X GSR
On GSR's with HID's (SSS package), the high beam is the same bulb as the low beam, but a metal plate moves up to allow more of the beam to come out. Therefore, I'm assuming this test wouldn't work for HID GSR's unless the relay failed immediately (and not after several minutes)?
To summarize, on GSR w/SSS, when you turn on low headlamps, HIDs illuminate. When you switch to high beams, a metal plate moves out of the way - there is no change in the HID bulb illumination.
Offline
Old Sep 3, 2009, 05:28 PM   #5
therocket's Avatar
Drives: 08 WW EVO X GSR
I think this is correct; so maybe the test is not good for EVOs with HIDs.
However, if it can be interesting for someone, this is the datasheet of the relay NAIS ACV31212 (in the pdf it is the Micro ISO 1A type): http://www.datasheetarchive.com/pdf-...DSA-104509.pdf
EDIT: just found also this other thread: it seems that now Mitsu suggests to use, for the fuel pump, the green relay NAIS ACM32221 (we have already 3 of them in the relay box: relays H, K, N that are throttle actuator control motor relay, injector relay, starter relay) in place of the black relay NAIS ACV31212 Attention: New relay part number from Mitsubishi
Someone can check if this is confirmed?
Offline
Old Sep 12, 2009, 11:26 AM   #6
Personal Sales Rating: (2)
Guru's Avatar
Drives: 08 EVO X WW GSR SSS Aero Navi
Thank you for write up. Mine went bad as well. 22,000 miles, stock fuel system. might have gone bad weeks ago, not sure since I had a bum clutch that prevented me from boosting.
__________________
Dan
Thinking of a Blouch Turbo? Read this first:
http://forums.evolutionm.net/service-parts-tuning-review/375268-stay-away-blouch-turbo.html
Offline
Old Sep 18, 2009, 03:45 PM   #7
chidevildog's Avatar
Drives: 2008 EVO X
thanks for the info.... i switched the high beams and fuel relay and so far mine is holding up did the quick test and so far so good...
__________________
Forge Bov (FOR SALE)
AMS Intake
Nisei Uicp
UR TP
HKS hi power
Cobb AP
Tein S.
Offline
Old Sep 29, 2009, 10:51 AM   #8
Silver Sponsor
Personal Sales Rating: (6)
DG Motors's Avatar
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Excellent!
I would like to say this got a client of ours from NJ out of a huge jam today. He was experiencing some rough bucking/hesitation from 2,500rpm-5,000rpm during WOT. We have been talking through p.m to try and rectify this situation for the past week.
Today he came in and I immediately checked the FPR line that pops off from time to time and would cause this same exact dilemma.(bucking/hesitation) which is an extreme lean condition that would cause knock sums over 15+ counts during WOT
The problem was fixed and I would like to conclude by saying thank you! Client is satisfied and more so if we ever come across this problem again we will know exactly where to check!
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Old Sep 29, 2009, 06:35 PM   #9
Drives: 08 Evo X
Awesome! that is exactly why I felt the need to post this quick test for people to do. I know how hard frustrating it can be when your trying to pinpoint a problem. Hopefully this will help many more people
__________________
Offline
Old Oct 2, 2009, 02:54 PM   #10
nice writeup....
__________________
WTB: EVO8 or 9. or trade for a 91 Nissan Pulsar GTi-R Right Hand Drive Turbo AWD rally coupe, low miles - 47k kms. Asking 7k.
Offline
Old Oct 2, 2009, 04:37 PM   #11
2008 Mitsubishi Lancer Evolution
Jimyumi's Avatar
Drives: 2008 Evo X MR
Quote:
Originally Posted by overdrive1 View Post
nice writeup....
+1
__________________
08 Evolution X MR Apex Silver
Blitz Nűr-Spec DT Exhaust / SUS Power Air Filter LM
Cobb AP w/Perrin Stage 1 map
Forge Motorsport Actuator
Perrin 3" Antenna
Pivot MegaRAIZIN Voltage Stabilizer (Purple)
Ralliart Radiator Cap (P=1.3kgf/cm²) / Sport Oil Filler Cap / Tail Lights
Sequential Titanium Intercooler Pipe
Tanabe Front Under Brace Bar
OEM Back-up Camera / Brake Air Guides / Hand Brake Grip / Mud Flaps / Rear Spoiler Extension, Lip Spoiler, Strut Brace / Rear tint windows (25%) / SST Knob
Offline
Old Oct 2, 2009, 04:48 PM   #12
EvoM Moderator
Personal Sales Rating: (4)
macPSU's Avatar
Drives: RR Evo X GSR
Send a message via AIM to macPSU
So has it been confirmed that this won't work with SSS-equipped cars?
Either way, great write-up. Thanks!
__________________
2008 Rally Red Evo X GSR
AMS Intake | AMS UICP | AMS FMIC | AMS LICP | AMS O2/Downpipe | AMS HFC | Buschur Catback (modified) | Ivey Tune 340whp 338wtq
Eibach springs | Advan RS 18x10 +25
We Are Penn State!
Live it. Learn it. Love it.
Offline
Old Oct 4, 2009, 01:22 AM   #13
19EVO86's Avatar
Drives: 08 EVO-GSR WHITE
what i did was switch the fuel relay with the horn relay its the same type of relay. after they are switched honk your horn and if the horn sounds muffled then u have a bad relay
__________________
ams tuned
installed
3" artisan exhaust
artisan intake & uicp
UR O2 dp
ams intercooler
AEM wideband O2 sensor
need to install or order
Fp Red(sitting in the jms shop)
1000 cc injectors
mbc
ACT 6 puck sprung clutch(on order)
ACT streetlite flywheel(on order)
AEM boost gauge
JMS tune
Offline
Old Oct 5, 2009, 11:05 AM   #14
Personal Sales Rating: (3)
c_reber's Avatar
Drives: 08 Evo GSR, 90 Talon, 01 929RR
Quote:
Nice, I have the SSS pkg and was wondering how I could test this. I'll go try it now
__________________
2008 WW Evolution GSR
1990 Eagle Talon Tsi AWD
2001 Honda CBR929RR
Offline
Old Oct 5, 2009, 01:41 PM   #15
Drives: 08 Evo X
If you try this at night with your car parked close to a flat wall where you can see the light spread pattern it will work. You have to pay close attention to the change in light patterns when you switch form low to high beam. Park your car about 10 feet from a wall and (with low light conditions of course) and toggle the hi beam to see how the light pattern changes between hi and low.
Then you can perform the test as described above.
__________________
Offline
Tags
change, evo, fail, failed, fuel, fuse, howto, install, lancer, location, problems, pump, relay, relays, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
