Sep 2, 2009, 09:52 AM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
HOW TO: Make a distribution block for Gauge Installs/Radar Detectors/Anything else.
For anyone interested in making one of these. This is what I created for my boost gauge and wideband install.
Thanks to: ZWingerRyRy
Installed:
Fuse Block
Finished Product
Now you can use the fuse taps to tape into these power sources. Now with your new distribution block you can connect many gauges.
You need the following parts.
From Radioshack:
1-8 Prong Bridge
1- 16 Screw Distribution Block
4 Colors of 6"-12" of 14-18GA wire
AdvancedAuto Parts, Autozone, etc...
3- Bussman ATC fuse taps
???- Connectors to connect to distribution bridge
Tools
1x Crimp / Cutter
1x Solder Iron & Solder
Heatshrink
Lighter
Double Sided tape hold distribution block in place when mounted
1x Dremel with cutting wheel (cut the 8 prong distribution bridge in 2 prong sections)
The key to wiring these into the fuse box is to use the proper fuses. I had issues initially when using this.
The two prong holes closest to the prong require your stock fuse, 15A or 20A. The top two prong holes require a 10A this is for your accessory, in my case boost and wideband gauges.
You must use a 10A fuse, I tired to use something like 15A and the gauges would not power on.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
SteepSpeed Exhaust Manifold
Offline
Sep 2, 2009, 11:02 AM
Personal Sales Rating: ( 1)
Drives: 2008 Evo X
Where did you mount it? I had this same idea, just not nearly as fleshed out. I personally think it'd be simpler, long term, to mount the entire block somewhere, hidden, in the cockpit, so we wouldn't have to be running power leads through the firewall from the gauges.
Nice diagrams and such though, thanks!
Offline
Sep 2, 2009, 02:00 PM
I am going to mount it on the little door for the cockpit fuse door on the drivers side with some double sided tape, so it is out of the way but easy to access if I need to connect something new or I need to do any changes.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Sep 2, 2009, 03:14 PM
Personal Sales Rating: ( 0)
Drives: 2008 Lancer Evolution 2008 Triumph Daytona 675
Make sure you put up some detailed pics once you get it all installed please.
__________________
08 Evo X: Let the modding begin!
05 S2000: Traded
Offline
Sep 2, 2009, 03:44 PM
Quote:
Will do
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Sep 2, 2009, 04:26 PM
Drives: 2008 EVO X
subscribed!
__________________
Forge Bov (FOR SALE)
AMS Intake
Nisei Uicp
UR TP
HKS hi power
Cobb AP
Tein S.
Offline
Sep 2, 2009, 08:16 PM
Drives: EVO X 2008
i had the same setup done. i post a few months ago some pictures. i found a realy confortable place to mont it inside the plastic acces door of the fuse box. it's easy to conect everything seated on the driver seat, no need to go under the panel everytime that i want to conect something.
becouse i'm using also the same fuse conectors i can tell you in advance that you will need to bend one of the cables 90 degrees were the cable meet the conector. all the recomended fuses to tap are so close that there is no space for the cable in the middle fuse (white cable).
__________________
COBB APII
3M Tint 25% All
COBB SF Intake
AMS SS Test Pipe
AMS O2 Eliminator
CUSCO Strut Bar Rear
AMS Intake Fan Shield
AMS Mesh Screen CAI
CUSCO Strut Bar Front
COBB Intercooler Pipes
COBB Turbo Inlet House
AMS Shifter Base Bushings
PIONEER AVIC-F90BT/ Speakers
AMS SS Single Cat-Back Exhaust
AMS Under Hood Shifter Bushings
Design Engineering Intercooler Spray Kit
Mishimoto Silicone Radiator Hose Red Kit
Perrin/Prosport Performance Gauges. Boost/EGT
Offline
Sep 2, 2009, 08:41 PM
Drives: 08 Evo X
Im an electrical noob but correct me if im wrong please. The fuse taps will be on the fuse box with fuses on them and power for accessories(gauges, radar) would mount on the other screw for that fuse tap? This looks so much easier and neater than having to tap for power individually for each gauge.
__________________
PB X
Stockness FTW....
... i can haz custom exhaust?
Offline
Sep 2, 2009, 10:09 PM
Quote:
Yes that is correct I should have install pics up by Monday/Tuesday.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Sep 3, 2009, 07:41 PM
Drives: PB EVO X
this setup is definitely cleaner then the way i did mine. will copy, thanks.
Offline
Sep 3, 2009, 08:40 PM
Personal Sales Rating: ( 2)
Drives: 08 MR
Thanks for sharing. really useful stuff.
__________________
1600 miles on all parts; MR Bilstein and eibach springs for sale. Stock intercooler for sale. Stock fog lights for sale. PM me
Offline
Sep 4, 2009, 07:35 AM
Drives: 2008 Evo X
It's a good time to do it too, on a newer car. Know where everything is, where everything is routed. Lovely.
__________________
2008 Evo X GSR. Rally Red.
Buschur UICP/LICP
Buschur Intake/MAF Pipe/Shield
Buschur Cat Back Bullet
Buschur Test Pipe
Buschur Shifter Bushings
Buschur Evo X FMIC
Offline
Sep 5, 2009, 09:29 PM
2008 Mitsubishi Lancer Evolution
Drives: RR Lancer Evolution X GSR SSS Aero
So, I started tackling all my "electrical installs" today. Should have checked the forums first as I now see. However, our ideas aren't that far off. I can't wait to see your install pics to see how close our ideas are...
Any who, I'm also using the ATC Fuse taps but (since I'm still a basic nub when it comes to electrical stuff) all I could find are the 10A taps... Is this what you are using or did you find some bigger ones? Should the 10A be fine for pretty much everything? I know my fuzz buster has a 2A/250V fuse in it and the cig lighter is a 15A fuse; does the 10A limited tap cause a prob? I know you can always drop Amps and be OK (rather than go bigger, ie run a 25A fuse in a 15A slot).
Any thoughts would be appreciated!
Reason: corrected amperage on the fuzz buster
Offline
Sep 7, 2009, 01:37 PM
I'll try to get some pictures tonight.
I will try to get pictures later tonight.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Sep 7, 2009, 05:27 PM
Drives: 2k2 maxima & evo x
subscribed
Offline
Tags
12, atc, block, buss, connect, dallas, distribution, eclipse, evo, fuse, gauge, guage, panel, pics, tx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
