Sep 29, 2009, 10:08 PM
#31
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Quote:
Originally Posted by Spazo
I saw this as I bought my bussman but installed anyway (with a 10 AMP fuse installed). It's been running fine for my fuzz buster so far.
I guess my follow up questions to Clipse's answers are:
1. Are there accessories/gauges that draw more than 10 Amps (I'm sure you could combine multiple gauges...)
2. Where would one obtain a bussman that allows for greater than 10 Amps (maybe 15 like the socket for the cig) of vamp-age?
I did not see a BUSSMAN Fuse Tape that was rated for more than 10AMP. I looked through their catalog.
I still cannot see a 5 gauges hooked up to draw more than 10 amps.
I think you will be more than fine with the 10 AMP fuse taps. If you need anything more than that run a line from battery and use a large fuse inline then run it to a distribution block.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Sep 30, 2009, 11:15 PM
#32
Personal Sales Rating: ( 0)
2008 Mitsubishi Lancer Evolution
Drives: RR Lancer Evolution X GSR SSS Aero
Quote:
Good call
Offline
Oct 6, 2009, 05:36 PM
#33
Drives: OB X GSR
Why use a large fuse inline when you can add your own fuse block like this:
^currently working on putting this in... you can use ATO fuses ranging from 5A to 40A with this.
Btw, I may be wrong, but I don't think you have the right idea with the dimmer. The dimmer wire is supposed to tap into a headlight signal so that when the headlights turn on, the gauge dims. This would make for a dim gauge at night when you don't need it very bright at all and bright gauge during the day when it would be harder to see.
Online
Oct 13, 2009, 07:12 PM
#34
Drives: 2008 Evo GSR
with this setup how many gauges could you run???
Offline
Nov 3, 2009, 02:29 PM
#35
Personal Sales Rating: ( 3)
Drives: 2008 RR Evo X MR
So, any opinions on using the same distribution block setup for grounds. One for power still, and a separate block for the grounds. I know most gauges are specific in the way they should be grounded. i.e everything grounded to a common lug, but not twisted first. Between 3 gauges and a wideband controller there are a lot of grounds to run. A grounding block will save me a lot of time, but i don't want to create any signal noise from grounding everything through the block. Any feedback would be great.
Offline
Nov 5, 2009, 07:50 AM
#36
Drives: 08 RR Evo X
Hey Clipse,
Could you PM me with what Gauge Pod that is?
Offline
Nov 5, 2009, 09:32 AM
#37
Personal Sales Rating: ( 2)
Drives: Acura RSX Type S
Quote:
Originally Posted by Blayze999
Hey Clipse,
Same here. I'm only getting A/F and boost gauges and that's a reallly sweet spot to put them in.
Offline
Nov 5, 2009, 09:47 AM
#38
It cost me 18 bucks...
Summit Racing SUM-G2878
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Nov 5, 2009, 09:48 AM
#39
Quote:
I have no issues running three things into that common ground. Everything works normally. The key is to run smaller AWG or thicker wires to the main terminals. Running skinny wires might now work as well.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Nov 5, 2009, 01:45 PM
#40
Drives: PB EVO X
i took some of the ideas here and am in the process of routing from battery -> inline fuse -> relay -> d-block -> my gauges/radar.
I originally had 4 gauges/radar tapped into the cig lighter and i had some electrical issue, So now i'm going to power it straight from the battery.
Offline
Nov 5, 2009, 02:06 PM
#41
Cool post up some pics whenever you get done
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Nov 5, 2009, 03:24 PM
#42
Personal Sales Rating: ( 1)
Drives: 08 Evo X, 08 Harley soft tail
Gauges produce hardly any noise. widebands/computers/EBC do however and need to be on different post vs "clean" grounds.
__________________
91 306ci 76mm turbo c4 tranny Ford Mustang Hatchback
08 Harley soft tail Night Train
08 Evo x Octane Blue Pearl
Offline
Nov 5, 2009, 03:30 PM
#43
Drives: PB EVO X
Quote:
explain more.. so does this mean i shouldnt ground all to one bolt? find 4 different bolts if i have 4 different electronic?
Offline
Nov 18, 2009, 11:53 AM
#44
Drives: 08 EvoX GSR WW
This is way helpful thanks!
Offline
Nov 20, 2009, 04:47 PM
#45
some electronics make alot of feedback/ noise. The battery is a gaint filter. if you combine a noisey ground with a clean ground it can make the device(s) not give correct information. Example would be your wide-band produce noises and putting it with a clean ground can make it not read right. Its hard to make sense of it I know
I have a mustang that I've been building for 2 years, its my drag car. I completely rewired it. My gauges are wired in parallel (power and ground) My wideband has its own ground, so does my boost controller.
so basically I have three diferent grounding locations. I have muplite junction studs/blocks in the car for power and grounds.
Of course this is very very unlikely that you will experince any of this.. just remember to scrape away paint and make sure its bar metal for the ground.
__________________
Offline
Tags
12, atc, block, buss, connect, dallas, distribution, eclipse, evo, fuse, gauge, guage, panel, pics, tx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
