Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 28, 2009, 11:48 AM   #1
Personal Sales Rating: (4)
2008 Mitsubishi Lancer Evolution
My Garage
monkey_187's Avatar
Drives: PB EVO X GSR w/SSS, 04 Cobra, 01 Mustang GT S/C, and a Burro.....EVO 8 MR~SOLD
Radar direct wire install help
I am installing my radar detector using a direct wire so I dont have to use the one from the cig lighter. I need help on where to splice the wire so it gets constant power after I turn the car on. Anyone with a wire diagram and some help I would appreciate it. I need the wire to be somewhere on the passenger side under the glove box. If you have pictures of the wire and location it would help me a lot. Thanks in advance for the help.
__________________
EVERYONE~what do you have done to your car?
ME~"rims and tires"
It is better to die on your feet than to live on your knees.
Offline
Old Aug 28, 2009, 02:16 PM   #2
Personal Sales Rating: (0)
kenpo1441's Avatar
Drives: 08' PB MR
Don't splice...just run the wire down to the fuse box and use a fuse tap; I did it on mine and it has worked great. I ran the wire across the head liner and then down the a pillar which opens up right above the fuse box.
Offline
Old Aug 29, 2009, 01:19 AM   #3
Personal Sales Rating: (1)
►EvolutionX◄'s Avatar
Drives: 08' GG Evolution X GSR
Aye, Mount your radar detector by your rear-vier mirror, run the wire behind it, tuck it behind the headliner, run down through a pillar, along door jamb, into drivers fusebox, then purchase a fuse tap (search an automotive parts store) and tap in, DONE, then when you sell the car, you dont have to fix anything. SEARCH, there is a thread of someone who did exactly this.
__________________
Engine Modifications
AEM CAI
AMS FMIC
AMS UICP
AMS 02 Downpipe
AMS Test Pipe
ETS V2 Cat-back
-Visual Modifications-
AEM Analog Boost
AEM Analog Wideband
V1 Hardwired
Ralliart Tailights
Powdercoated Wheels
Offline
Old Sep 1, 2009, 10:24 PM   #4
Personal Sales Rating: (5)
itznoraa's Avatar
Drives: Lancer
i tapped mine into the cig lighter with add a fuse into the fusebox near the drivers foot.
also hid the wire like everyone else said.
Online
Old Sep 3, 2009, 11:22 PM   #5
Personal Sales Rating: (3)
suprawillis's Avatar
Drives: 2008 Evo X GSR, 94 Supra 6spd
Hard-wired my 8500 tonight. Took me 5 minutes. I have the radar detector suctioned on the left side of the windshield. The wire is tucked in the A-pillar, down to the fuse box area. The ground is mounted to a 12mm bolt inside the dash area near the fuse box, and the power source is just fuse tapped it. Took 5 minutes. Got the hard wire from ebay for 7 bucks shipped to my door.
__________________
2003 Evo 8-Bone stock Lightning yellow-sold
2003 Evo 8-weightless white-sold
2008 Evo X
1994 Toyota Supra 6spd 964 rwhp. Stock shortblock
http://www.youtube.com/watch?v=r-KrBytvXLE
Offline
Old Sep 21, 2009, 09:12 PM   #6
Drives: OBP 2008 Evolution X GSR red 85 corolla GTS
does the a pillar piece just pop off?
Offline
Old Sep 21, 2009, 09:15 PM   #7
kenpo1441's Avatar
Drives: 08' PB MR
Yes it does...there is a small plastic strap that was kind of a pain to get off, but once you get past that it comes right off. There is a nice size hole that you can feed the wire down right in front of the fuse box.
Offline
Old Sep 21, 2009, 10:39 PM   #8
mini fuse #13 is the cig lighter/acc fuse. it's in the minifuse compartment in the cabin.
if you go to the third row from the bottom (or forth row down), it's the one all the way to the right. should be a blue 15 amp fuse.
tap into that with a bussman and you should be set.
Offline
Old Sep 22, 2009, 08:31 AM   #9
chidevildog's Avatar
Drives: 2008 EVO X
damn I actually did mine the fugly route.. I drilled small holes underneath my rearview mirror and tap onto the light/dome switch.. to turn it on i have to tap the dome light which i removed the bulb and tap again to turn off... I forgot to turn it off once and radar just kept blinking.. I def. have to fix it..
__________________
Forge Bov (FOR SALE)
AMS Intake
Nisei Uicp
UR TP
HKS hi power
Cobb AP
Tein S.
Offline
Old Sep 22, 2009, 02:07 PM   #10
Spazo's Avatar
Drives: RR Lancer Evolution X GSR SSS Aero
Damn Chi... that's, um, a "creative" way of doing it.
Offline
Old Sep 22, 2009, 04:34 PM   #11
Drives: 2008 EVO X
Quote:
Actually, I was bored and it was late at night.. I started and wanted to do a clean install but didn't have the right proper tools.. After fumbling around I ended up with the above description.. It works.. still have to fix it later
__________________
AMS Intake
Nisei Uicp
UR TP
HKS hi power
Cobb AP
Tein S.
Offline
Tags
08, detector, diagram, direct, driver, evo, evolution, install, installation, mustang, phone, radar, setup, v1, wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
