Aug 22, 2009, 11:16 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
Transfer case drain plug size
i was following the transfer case oil change instructions in the service bulletin russell posted. when i got to the drain plug, i noticed the size is bigger than any sockets i have available. what's the size of that drain plug so i can purchase the right one instead of shooting in the dark?
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Aug 23, 2009, 04:53 AM
Drives: WW EVO X
Quote:
I THINK its 22mm which is the same as the Transmission Drain plug.
__________________
WW EVO X #32
AMS Front Motor Mount & Underhood Shifter Bushings
TurboTrix Piping Kit
ETS Dual Exhaust
T1R o2/DP Combo, T1R Testpipe, Shift Boot, Stubby Antenna
Prosport Boost Gauge
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Seibon CW hood/OEM Trunk
Chargespeed FRP VG
ECUTek Tune (318whp/359 Torque @ 26psi)
First EVO X in Canada to Break 300whp
Offline
Aug 23, 2009, 01:39 PM
Personal Sales Rating: ( 0)
Drives: Evo X GSR
Quote:
It's actually 24 mm, not 22 mm. The transmission and transfer case drain plugs are both 24 mm (just did it recently). Luckily, that was the largest socket size I had.
BTW, if you want to do the rear diff fluids, the drain plugs are actually a 10 mm hex (or allen key style), which most people probably don't have. I had to run to the auto store to get one.
Offline
Aug 23, 2009, 04:44 PM
Drives: Evo X GSR
ah crap and i just bought a 22mm socket...
and i just loaded my car on to a ramp
now i gotta go back and get another one
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Aug 23, 2009, 04:46 PM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
24mm is correct for the transfer case, rear diff (both drain and fill back there) and tranny (but only for the 5-spd). The MR 6-spd (at least the IX) are 10mm hex for both drain and fill.
BTW - probably best to get a longer socket or extension t-case fill bolt as it is tucked up in there pretty well. Don't lose any gaskets!
Offline
Aug 23, 2009, 07:00 PM
Drives: 08 Evo X GSR
Yeah sucks when u have to stop and go to the store to get the right tools. At least next time u know.
Offline
Aug 23, 2009, 07:28 PM
Drives: WW EVO X
My bad guys
__________________
WW EVO X #32
ETS Dual Exhaust
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Chargespeed FRP VG
Offline
Aug 23, 2009, 07:34 PM
Drives: Evo X GSR
Actually for the Evo X, the GSR 5-speed also uses 10 mm hex for the rear diff drain bolts. Transfer case and transmission are the only ones that use the 24 mm drain bolt. The fill bolts are all 17 mm (transmission, transfer case, rear diff). You will also need a 17 mm combo wrench to get off one of the rear diff fill bolts unless you have a really small socket wrench (not much room back there).
Offline
Aug 23, 2009, 08:09 PM
Drives: Evo X GSR
thanks folks - i got the 24mm deep drive socket and it worked. it was the first transfer case oil change, so it had a lot of metal adhered to the drain bolt...like it did with the gearbox fluid. i just don't get why this car loves to drop shavings in such large amounts, first i've seen it.
at any rate, i'm going to pursue the rear diff fluid another day.
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Aug 24, 2009, 04:19 PM
Drives: 06 Evo MR
That's a good point. The IX rear diff fill bolt (24mm for both fill and drain on the IX) doesn't give you much room to work with due to a cross brace back there. I couldn't get a torque wrench on it to tighten, but I was pretty sure what 23 ft-lb felt like after doing everything else.
Offline
Tags
10, 22mm, bolt, case, casing, drain, fill, filler, plug, reason, size, socket, tool, tranfercase, transfer, wrench  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
