I am just 1 bolt away from removing the turbo but I just can't seem to crack it lose so if you've done it before let me know what tool combination did you use to get this bolt off. Its the bolt that holds the hot (cast iron) side to the block right above the transfer case.
I've broke 2 extensions already trying to turn it with a breaker bar so I'm thinking maybe you don't need that many extensions or you're able to get it from a different angle. This is what I've been using 14mm deep socket -> universal joint -> 12" extension -> breaker bar and I've broke 2 extensions.
here is a picture of the bolt i'm talking about.
thanks in advance!
