Jul 19, 2009, 04:41 PM
Personal Sales Rating: ( 0)
Drives: Evo X / WRX
Curbed my rim
So after years of parking to close to the curb it finally bit me in the a$$. Yesterday I curbed my rim nothing deep a little smaller than an inch in length; how could I go about at least smoothing it out trying to somewhat repair it? Would sand paper be my best option for a quick fix?
Thank you for your input
Offline
Jul 19, 2009, 04:51 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
what wheels?
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Online
Jul 19, 2009, 04:52 PM
Drives: Evo X / WRX
Quote:
Originally Posted by endGameXIII
what wheels?
Just the stock gsr's
Offline
Jul 19, 2009, 04:58 PM
Personal Sales Rating: ( 1)
Drives: PB Evo X GSR
My local Mitsu dealer has a guy who specializes in alloy wheel repair. He charges about $150 per wheel but I've seen the results and it's nothing short of amazing. Try contacting your dealer and see if they have a similar service.
Offline
Jul 19, 2009, 05:34 PM
Drives: Ten Gran Sport Racing
I did fix my curbed rims before on my Scion tC. Buy bondo, 800 and 2000 grit sandpapers (if I remember correctly), and a spraypaint can with the color of your choice, primer and/or clearcoat.
Mix the bondo til you get a chewy mixture, patch it up nice and neat. Wait for it to dry then wetsand with 800 grit til it smoothens out with the rim. Spray primer, wait for it to dry then wetsand again with the 2000 grit sandpaper. Spray paint, let dry, then wetsand again. Spray clearcoat, let dry, then off you go! Don't forget to tape around the tires and cover with with newspaper before doing so.
Online
Jul 19, 2009, 05:37 PM
Personal Sales Rating: ( 24)
Drives: Evo X - GSR
Do a google search in your local area or go old school and check the yellow pages. There will likely be several wheel repair companies. Some that will even drive out to your location and fix the wheel on the spot. From the description you posted, should be less than $100. Will look like new.
Offline
Jul 22, 2009, 04:16 PM
Drives: 08 Lancer Evo GSR
Quote:
damn, did the same thing yesterday....the worst feeling. i just sanded the big scratches down then hit it with a very lite grit paper and it doesnt look nearly as bad.
Offline
Jul 22, 2009, 05:50 PM
Drives: 2008 Evolution X!!!!
bad curb? did you happen to take a picture of it? just want to see how bad curbing the stocker can it really get. i heard the stocker is weak when it comes to running over...anything.
__________________
2008 WW Evo X
Mods: AEM intake, Works stealth exhaust, Works re-flash and tune
Hp: 307@7k
Tq: 308
on a dynopack
Special thanks to Edo Performance and Works
recently ichiba tp and uicp...Hp/Tq=326tq/313.2hp thx to
jon, ronny, matt@
HB speed! DynoMite!
Offline
Jul 22, 2009, 07:46 PM
Drives: Evo X / WRX
Quote:
I feel you. The feeling just sits in the back of your mind! It's really not that bad of a curb rash maybe two of them about an inch long each that are not deep at all. I may try what you did. What type of sand paper and grit paper did you use?
Thanks!
Quote:
I'll post pics up tommarow.
Offline
Aug 4, 2009, 02:12 PM
Drives: 08 gts , 07 outlanderxls ,09 RA
if it is just a small section on the edge....
...sand the area real smooth.
...... then paint it with a little touch-up bottle from "dupli-color" brand.
the best match i have found for the mitsu wheel silver is : subaru "artic silver"
Offline
Aug 7, 2009, 02:06 PM
Drives: 08 EVO X GSR
I was thinking of repairing my curbed rim myself, does anyone know the color code of the stock Enkei rims? Should a basic silver be good enough?
Offline
Tags
albany, alloy, buy, curb, curbed, evo, fix, fixing, ny, repair, restoration, rim, rims, scion, scratches, tc, wheel  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
