Jul 18, 2009, 09:21 PM
Personal Sales Rating: ( 0)
Drives: 08 EVO X GSR
First Oil Change
I did my first oil change today!!!  Use a genuine mitsubishi oil filter, and About 5.3qts of Mobil 1 synthetic oil. Everything was going good but now my oil pressure light comes on every i turn the key to the "on" position....  has anyone run into this problem? i did everything by the book and i have checked and recheck oil level on the dipstick everything is good. only one of the little hole in the dipstick is covered in oil. The every top one but not the bottom? It an 08 GSR. Need help!!!!
Offline
Jul 18, 2009, 10:02 PM
I will check the oil level tomorrow with the engine cold... I can't think what else it can be. i read the manual and they only say to check oil level and take the car to the dealership.
Offline
Jul 18, 2009, 10:09 PM
Drives: 2006 GG Mitsubishi Lancer Evolution MR. Any Car on my Dealership.
What weight mobil 1 did you use? How many little holes are on the dipstick?
__________________
AMS FMIC
ACT XTSS
AMS SS CLUTCH LINE
MEGAN O2
GREDDY Ti-C CATBACK
DC Sports DOWNPIPE
HKS R.S.I.
Hallman MBC @23 PSI
FORGE B.O.V.
WALBRO 255
Cosworth M2's
SuperTech Dual Springs/Ti-Retainers
ARP Headstuds
ETS 2.5" Upper/Lower I.C. Pipes
Kuniiizzzeee Dial-IN
11.9 @ 116mph (6-speed MR)
Next Mods: FP Black on VP Import
Sponsored by my own dealership! http://www.mainstreetmotors.org
Offline
Jul 18, 2009, 10:58 PM
Drives: Ten Gran Sport Racing
Did it say in the manual to put 5.3 qts? When I did mine, I roughly put 4.7 qts of 10w30, and that includes the oil put in the filter. I don't have my manual at the moment. For all I know, filling it below the rated level is better than over it.
Offline
Jul 18, 2009, 11:25 PM
5w30. yes its like 5.32qts in the book. And two holes on the dipstick.
Offline
Jul 19, 2009, 12:17 AM
Drives: 2008 RR Evo X
remember not all of your oil drains out when you drain it from the pan. You will not use the full 5.32qts
Offline
Jul 19, 2009, 06:04 AM
 I rechecked oil level again, and everything is good??????  I am going to baby the car because i dont want to damage anything. i will recheck it later. i dont know why that Fing light is on!!! it only turns on when you go to start it and thats it!
Offline
Jul 19, 2009, 06:31 AM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
I know Mitsu's have been known for faulty oil pressure sensor. Sometimes water gets in the connector harness and causes the oil light to come on.
Also maybe reset the ECTAS computer with the miles til next maint thing. Might be causing it. If you car is stock you can always take it to the dealer.
Which line is the oil level at. Top line/dot or the bottom line/dot?
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Jul 19, 2009, 03:06 PM
Personal Sales Rating: ( 1)
Drives: 08' GG Evolution X GSR
It comes on when you click the key over, but not when the actual car is started? if so this is how it should be working.
__________________
Engine Modifications
AEM CAI
AMS FMIC
AMS UICP
AMS 02 Downpipe
AMS Test Pipe
ETS V2 Cat-back
-Visual Modifications-
AEM Analog Boost
AEM Analog Wideband
V1 Hardwired
Ralliart Tailights
Powdercoated Wheels
Offline
Jul 19, 2009, 03:19 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
uhm...yeah...every car i've driven before does that. camry, corolla, is350, 300, 330i, it's part of the startup check procedure. as long as it turns off shortly after you flip it to on (or start the car, whichever it was), it's normal. if there's a problem it stays on.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Jul 19, 2009, 05:25 PM
When the car is running the oil light shouldnt be on.....until you start the engine the ecu thinks there is no oil pressure so therefore the oil will be on. (key at the 2nd position)
__________________
AMS FMIC
ACT XTSS
AMS SS CLUTCH LINE
MEGAN O2
GREDDY Ti-C CATBACK
DC Sports DOWNPIPE
HKS R.S.I.
Hallman MBC @23 PSI
FORGE B.O.V.
WALBRO 255
Cosworth M2's
ARP Headstuds
Offline
Jul 20, 2009, 06:13 AM
I know what every car runs a self check at start up. It's not that. The multi-data display is showing the oil pressure light on. the oil is fill to the top line/dot. I will post picuters of what is going on. and i will take it to the dealership and ask. and repost that they said.
Offline
Aug 5, 2009, 10:26 PM
Drives: evo x
ive overfilled mine a bit and never had that problem. Thats weird maybe reset the ecu
Offline
Aug 7, 2009, 08:28 AM
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Lancer Ralliart
I'm thinking you overfilled it, mistakingly though.
Online
Aug 7, 2009, 10:40 PM
Drives: GG Evo X
it should only be 5 qt noob,
5.3 is if you take the oil out of the oil cooler and everthing
__________________
GG Evo X SSS
Greddy Ti-C- Harmon motive intake- Speed circuit 3" test pipe- Nisei 1 piece UICP- AMS fan shield-Cobb AP
Offline
Tags
2006, 2008, change, cost, dipstick, dot, eclipse, evo, evolution, fill, lancer, mitsubishi, mr, oil, type  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
