Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 16, 2009, 01:36 PM   #1
Personal Sales Rating: (0)
alex3dworld's Avatar
Drives: EVO X 2008
Monday AMS test pipe install. Tips?
saturday is my birthday
I will be installing my AMS SS test pipe on Monday.
Any Tips or recomendations to have on mind before Install?
Is a one man easy instalation?
Experiences with this particular test pipe or others?
Thanks
__________________
COBB APII
3M Tint 25% All
COBB SF Intake
AMS SS Test Pipe
AMS O2 Eliminator
CUSCO Strut Bar Rear
AMS Intake Fan Shield
AMS Mesh Screen CAI
CUSCO Strut Bar Front
COBB Intercooler Pipes
COBB Turbo Inlet House
AMS Shifter Base Bushings
PIONEER AVIC-F90BT/ Speakers
AMS SS Single Cat-Back Exhaust
AMS Under Hood Shifter Bushings
Design Engineering Intercooler Spray Kit
Mishimoto Silicone Radiator Hose Red Kit
Perrin/Prosport Performance Gauges. Boost/EGT
Offline
Old Jul 17, 2009, 11:11 AM   #2
Personal Sales Rating: (27)
rogue's Avatar
Drives: WW EVO X.... previously -EVO IX - Apex Silver
Send a message via AIM to rogue
easy as pie. After jacking up the car it will take 5 mins.
Online
Old Jul 17, 2009, 11:16 AM   #3
Personal Sales Rating: (1)
DendroEVO's Avatar
Drives: Apexi Silver EVO X
02 Socket for the 02 Sensor.
Breaker Bar for the two bolts on the downpipe. Mine were a ***** to get off.
Did you get some spacers for the 02 Senor? It will throw a CEL without them.
Other then that it's pretty simple.
__________________
Mods:
- STRI Boost Gauge
- AMS Upper IC Pipe
- AMS Intake
- AMS FMIC
- AMS Test Pipe
- AMS Twin Tip CBE
- AMS Tuned 316.62 WHP / 332.50 TQ on a 84 degree day =)
Offline
Old Jul 17, 2009, 11:19 AM   #4
rogue's Avatar
Get some Pb baster just in case, my bolts came of easy, but just in case.
Online
Old Jul 19, 2009, 07:51 AM   #5
2008 Mitsubishi Lancer Evolution
DarwinX's Avatar
Drives: 08 Apex Silver GSR
Quote:
Originally Posted by rogue View Post
Get some PB Baster just in case
^ +1. Let it soak in on the threads for a good 30 minutes first.
1) Do this job with everything COLD!
2) When removing the O2 sensor, make sure it's centered when unscrewing it. There's a lot of slop in the threads...easy to cross-thread. When installing the O2 sensor into the test pipe, put a little anti-sieze on the threads first. Did you buy an O2 spacer?
3) If the DP moves a little when breaking the front bolts loose on the stock cat, don't worry, the DP rides on a donut...just move it back when you get the stock cat pipe off.
4) Make sure your flanges are centered before locking everything down.
__________________
OEM Front Brake Air Guides
AMS UICP / Hot Pipe
TWM Short Shifter, Console Bushings, A6 Leopard Shift Knob
Perrin 25mm Adj. Rear Sway Bar
Perrin Cat-Back Exhaust
Deka ETX20L AGM Battery
Ralliart Tail Lights
AEM Intake
T1R Shifter Boot
AMS High-Flow Cat
Cobb Stage 2 Map
Works Under Hood Shifter Bushings
Offline
Old Jul 19, 2009, 10:51 AM   #6
Drives: 2008 Phantom Black EVO X GSR, 07 Yamaha R1
Send a message via AIM to Evo4Emperor
Make sure that if ur doing the job with a buddy for him not to completely remove the 02 sensor (from under the passenger seat)... thats what my buddy did... hahhaa
Easy as cake to remove.. the only problem we had as probably taking the bolts off. Anyways i had to remove my test pipe to put my stock cat on (fix-it ticket) taking it off was easy as hell.. its a 1 person job
good luck.
__________________
I love rice....no, not the big winged, big useless exhaust, useless body kit, and stupid a$$ wal-mart spinner hubcaps. I love the white rice..hehehe
- 08 Evo X GSR SSS: AMS Cat-back, AMS test-pipe
- 07 Yamaha YZF-R1: stock --- for now....
Offline
Old Jul 20, 2009, 07:32 PM   #7
Drives: EVO X 2008
Thanks guys!!!!
yes i have the O2 spacers, how did you install the Jets inside the spacer???
do i need to use all the jets or one in particular.
i'm talking about these Jets
http://www.amsperformance.com/cart/A...or-Spacer.html
__________________
COBB APII
3M Tint 25% All
COBB SF Intake
AMS SS Test Pipe
AMS O2 Eliminator
AMS Mesh Screen CAI
Offline
Old Jul 20, 2009, 07:35 PM   #8
rogue's Avatar
I think you pick one and then use the included C-Clip to lock it in. I have it here sitting in front of me, unopened.
Online
Old Jul 21, 2009, 06:56 AM   #9
Drives: EVO X 2008
yea, i think that's how to do it, but there is 3 of them. wich jet should i use????
well i'll figurate out.
going to install now
i'll let you know later
thanks guys!
__________________
COBB APII
3M Tint 25% All
COBB SF Intake
AMS SS Test Pipe
AMS O2 Eliminator
AMS Mesh Screen CAI
Offline
Old Jul 21, 2009, 07:10 AM   #10
rogue's Avatar
I would use the smallest jet i guess, since you don't have a cat at all, that way you are less likely to send of a signal.
Online
Old Jul 21, 2009, 04:23 PM   #11
chapscalyx's Avatar
Drives: 2k2 maxima & evo x
what size open wrench did you use to take out the o2 sensor
Offline
Old Jul 22, 2009, 05:48 AM   #12
DarwinX's Avatar
Quote:
I used an 22mm O2 sensor socket I bought from Advance Auto.
As for what size insert I used in my O2 sensor spacer...the middle one. No CEL as of yet (using a Cobb Stage 2 tune).
__________________
AMS UICP / Hot Pipe
AEM Intake
T1R Shifter Boot
AMS High-Flow Cat
Cobb Stage 2 Map
Offline
Old Jul 22, 2009, 08:33 AM   #13
chidevildog's Avatar
Drives: 2008 EVO X
The two bolts were from the dp were a pita for me.. after using rust buster, they came loose. oh i used my legs to push off my b bar... :P
Offline
Old Jul 22, 2009, 11:16 AM   #14
flagg77's Avatar
Yea, the hardest part of the install is breaking the OEM bolts loose. I did it by myself and it took me maybe 45 minutes inclusive of getting my tools/jack/stands etc out of the garage and into my driveway to actually do it. I also ended up drilling out a pair of spark plug defoulers for my O2.
Offline
Old Jul 31, 2009, 07:00 PM   #15
chapscalyx's Avatar
what kind of ramp you are using
Offline
Tags
ams, cat, code, evo, flow, high, install, installing, jet, o2, pipe, pipes, screens, sensor, spacer, stri, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
