Jul 9, 2009, 08:43 AM
Personal Sales Rating: ( 0)
APR Vortex generator
The part that goes over the antenna base is stick up when I test fitted it. Even if I put the tape on, I doubt that it will bend to the curve of the roof. Ughhh
And one of those rubber weather strips along the sides of the roof is not coming up. It's stuck or something. The other side just unclipped at the first part. Any tips?
I might just get this professionally installed and fitted if it becomes too much of a hassle
Offline
Jul 9, 2009, 09:19 AM
Personal Sales Rating: ( 14)
2008 Mitsubishi Lancer Evolution My Garage
Drives: PB Evo X ; 1973 VW Super Beetle
this is nothing new as it was discussed at every VG thread that i can remember for as long as the APR VG was mentioned.
3 things you can do as far as what i have read people with this VG did.
1. make sure the roof is hot for the double sided tape to really stick.
2. buy a thicker rubber to hide the gap on the front of the antenna base.
3. cut out just the portion that covers the antenna base so the rest stays flat on the roof.
good luck
__________________
2008 PB Evo X GSR, SSS, OEM AW Mats, OEM Navigation, OEM MR Recaro Leather Seats, OEM Splash Guards, OEM Rear Wing Extension, OEM Door Visors, OEM UK F&R Scuff Plates, OEM UK CF Vortex, 2010 Cupholders, OEM BT and Volume Control.
BlackTop CF V-Style Lip, K&N Air Filter, Nisei Red UICP, Rxpd Rear Bumper Extension, Work Emotion XC8 19x10 +35; Kumho Ecsta 265/30
http://www.cardomain.com/ride/3059755
_The Lord will Provide_
Offline
Jul 9, 2009, 10:01 AM
Drives: 08 WW Evo X
^ can you post a link to these threads? the search feature sucks
Offline
Jul 9, 2009, 10:07 AM
thanks beetle. I remember the one guy cutting his because he put it on and it was stuck, so he just cut that portion off while still on.
I'm curious about option 1, but worried that over time it will just pop up again once the adhesive loses its integrity.
I will probably end up cutting it off, although I would rather not. If the person who did the rubber thing is around, then please let me know what you did and post a pic.
Offline
Jul 9, 2009, 10:57 AM
i will see if i can find those threads.
__________________
Offline
Jul 9, 2009, 11:32 AM
Personal Sales Rating: ( 9)
Drives: HBSpeed Tuned X GSR | STi
i just bought some door molding that people put on door edges in black and used that along the whole vg, looks a lot better and no gap. kinda like beetle_oranges oem one, but my molding is a bit larger
__________________
JOEY | '08 GSR 326HP/344TQ | '10 STi
| HKS Legamax Catback | AEM Intake | Nisei MB Pipes | ETS 3.5" IC | Cobb AP, Rear Sway | Walbro | DW 800cc | UR DP/O2 | RRE RallyCat | WORKS SSK, Base Bushings | AMS Cable Bushings | ARC Ti Knob | T1R Boot | RalliArt AC Panel, Taillights | BC Racing Coilovers | Volk CE28N TA 18x9.5" +24 | JDP RA Lip | APR CF VG, CF Rad Panel, Grill Cover | Defi Boost, CUII | Rexpeed Spats, Vents, Hood Dampers | OEM Visors, Trunk Spoiler, '09 Cupholder |
Offline
Jul 9, 2009, 02:12 PM
I took it to my mechanic and he said that he can make it fit, but I need to buy more 3M tape. Nowhere sells it! I went to Wegmans and Home Depot and they don't have it. I'll try an office supply store tomorrow.
He also said that he thinks that when APR made the pieces they left it on a level surface right out of the mold and the part, therefore, does not conform to the curve.  on them. I would have gotten the Rexpeed one if I knew I had to modify this one to fit since the Rexpeed one has larger fins.
Offline
Jul 9, 2009, 08:26 PM
lol there are mutiple threads that state that it doesn't fit flush on the antenna. i dont think any amount of double sided tape will fit. gl
__________________
Offline
Jul 9, 2009, 08:32 PM
Drives: RR GSR X
That's BS. I was going to get one until I saw this. Who wants to cut stuff up and buy pieces for something that should fit. I'm pretty bummed out.
__________________
ETS V2 Catback
ETS O2 Down pipe
ETS Test Pipe
ETS 4" FMIC
ETS UICP
AMS LICP
AMS Fan shield
Harmon Motive intake
Eibach Prokit Springs
Mishimito Coolant Hoses.
Skunk2 Shift Knob
Perrin Stubby Antenna
Cobb AP Stage 2 ACN AMS
AEM UEGO/Boost
Exedy Stage 2 HD
Act Prolite Flywheel
Whiteline Roll Center Adjustment
Offline
Jul 9, 2009, 08:46 PM
Quote:
I know that. He's going to shave off some of the bottom so that it sits better on the curve of the roof. It won't sit flush, but the front piece that sticks up will hopefully sit closer to the roof so that the adhesive will hold. I need more tape because he needs to take all the preset tape off those parts, and I need more tape for my ARC air intake duct.
If the shaving doesn't work then I'm going to cut that part off, which is ridiculous because it should fit right out of the box. I'm ordering all JDM and AMS parts from here on out because I don't want these crappy fitment issues.
Offline
Jul 9, 2009, 09:50 PM
on the contrary i remember reading someone claiming he did exactly this. if memory serves me right he did it for his friend and claims that it stuck without any gaps. i just need to find that thread.
home depot should have the 3m red double sided tape. its in the paint department.
__________________
Offline
Jul 9, 2009, 09:52 PM
Drives: 08 WW Evo X
You mean Chargespeed?
Offline
Jul 9, 2009, 09:58 PM
Personal Sales Rating: ( 5)
Drives: Wicked White Evo X
Thats exactly what i got at home depot. i removed all the double side tape that came with the VG from APR and used the 19lb grip red 3M double side tape. That stuff is very strong and I suggest you to heat it up and peal slowly if you ever want to remove it off the surface. Otherwise you will be removing your clear coat and some paint.
Offline
Drives: 08 WW Evo X
Do you guys think it's possible to heat it up so it reforms to the curvature of the roof?
Offline
Jul 9, 2009, 10:53 PM
I went to my local home depot today and they didn't have any 3M tape. The workers didn't even know what the hell I was talking about when I asked for it. I'll try the other one in the other town. Maybe an auto shop has it, like Pep Boys?
Even if a stronger 3M adhesive works, it's still upsetting that the part doesn't fit.
Offline
Tags
antenna, apr, blackcfevox, evo, evolutionm, generator, generators, kn, paint, roof, spoiler, stick, strips, uk, vortex  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
