Jun 26, 2009, 01:54 PM
Personal Sales Rating: ( 0)
Agency Power shorty antenna
http://www.vividracing.com/catalog/a...8-p-46204.html
I just got this delivered, but it's not fitting. I have navigation... does that make a difference?
Offline
Jun 26, 2009, 02:00 PM
Personal Sales Rating: ( 4)
Drives: 08 evo x, ex 96 eclipse gst, 03 evoultion 8, and 07 audi s4
damn, i ordered the same thing.. it says nothing about there being a difference (although i was told the apr vortex generator they carry would fit also, and it doesnt, plus it blocks the nav antenna from working...)
ill let you know monday if mine works
__________________
chris type rre cat back
rally cat
ultimate racing o2/dp
ets upper and lower i/c pipe
ets 4" front mount
aem intake
mueller stage 1+
matte black vinyl
wedsport sa-67r 18x9 +20
cosworth cams
blouch dominator 2.0
hb speed tune
400whp/360wtq
Offline
Jun 26, 2009, 02:06 PM
The APR VG doesn't fit? I just ordered that and the person I talked to said that it does.
WTF?
Offline
Jun 26, 2009, 02:18 PM
I tried again and it definitely does not fit.
Offline
Jun 26, 2009, 02:32 PM
Nevermind. You just have to take the screw out, screw it into the hole in the car, and then screw on the antenna.
Offline
Jun 26, 2009, 03:14 PM
ill keep that in mind
as for the vg. i placed it on, everything seemed cool. when i tacked it down (from the front to the back, as stated in the instructions) the front part around the antenna popped up, i practically layed on it for 5 minutes, with no luck.
so after giving up, i jumped in the car to go to work, no sirius. it just kept cutting in and out like i was going under an overpass/trees.
__________________
rally cat
ets 4" front mount
aem intake
mueller stage 1+
matte black vinyl
cosworth cams
hb speed tune
400whp/360wtq
Offline
Jun 27, 2009, 12:03 PM
post pix when u guys get a chance!
Offline
Jun 27, 2009, 01:08 PM
2008 Mitsubishi Lancer Evolution My Garage
Drives: PB EVO X GSR w/SSS, 04 Cobra, 01 Mustang GT S/C, and a Burro.....EVO 8 MR~SOLD
I would also lie to see pictures if anyone has them, I was thinking of getting the same antenna but now Im not sure I want to.
__________________
EVERYONE~what do you have done to your car?
ME~"rims and tires"
It is better to die on your feet than to live on your knees.
Offline
Jun 27, 2009, 01:16 PM
Offline
Jun 27, 2009, 01:18 PM
Offline
Jun 28, 2009, 10:12 AM
was about to purchase but :
Next Day Air Early AM $95.69
Next Day Air $64.38
Next Day Air Saver $59.43
2nd Day Air $35.79
3 Day Select $27.21
Ground $17.47
anyone know where I can purchase where shipping isn't as much as the antenna almost
Offline
Jun 28, 2009, 10:50 AM
Personal Sales Rating: ( 9)
Drives: HBSpeed Tuned X GSR | STi
lol that gap is horrible, go with the perrin one, no gap. and the vg does not stop the nav from working, the nav antenna isn't even on the antenna base it's under the dash lol. . . .
shoulda just taken your sisters wrx antenna, it would probably have fit better
__________________
JOEY | '08 GSR 326HP/344TQ | '10 STi
| HKS Legamax Catback | AEM Intake | Nisei MB Pipes | ETS 3.5" IC | Cobb AP, Rear Sway | Walbro | DW 800cc | UR DP/O2 | RRE RallyCat | WORKS SSK, Base Bushings | AMS Cable Bushings | ARC Ti Knob | T1R Boot | RalliArt AC Panel, Taillights | BC Racing Coilovers | Volk CE28N TA 18x9.5" +24 | JDP RA Lip | APR CF VG, CF Rad Panel, Grill Cover | Defi Boost, CUII | Rexpeed Spats, Vents, Hood Dampers | OEM Visors, Trunk Spoiler, '09 Cupholder |
Offline
Jun 28, 2009, 11:12 AM
joeym3 - sirius stopped working and the nav screen and directions were refreshing almost as if it were on a dial up modem.
cut the piece off... and all is well. so the base of the antenna 100% effects both things.
__________________
rally cat
ets 4" front mount
aem intake
mueller stage 1+
matte black vinyl
cosworth cams
hb speed tune
400whp/360wtq
Offline
Jun 28, 2009, 11:42 AM
lol i've had this piece for probably 4 months and i have not had any problems with my nav, the nav antenna is on the actual nav so i don't understand how this would affect the nav at all, no reason for there to be 2 antennas. check antics22 nav install, nowhere does he replace the antenna base. i don't listen to sirius so i can't comment on that. but my nav works perfectly fine, it doesn't make sense that a piece of cf will block a signal when metal has no affect.
__________________
Offline
Jun 28, 2009, 12:07 PM
I don't mind the gap. It doesn't really bother me.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
