Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 24, 2009, 10:00 AM   #1
Personal Sales Rating: (3)
DRAG's Avatar
Drives: 08 EVO X GSR
TPS Sensor wiring diagram, or gas pedal?
Does anyone have a wiring diagram for the TPS sensor and actuator, or even one for the gas pedal would help???
I have looked through the service manual and I'm having trouble finding it. Mitsu manuals are horrible! Thanks.
__________________
08 EVO X GSR
11.72 @ 116.4, best mph 119.5
3710 lbs, stock turbo, no nitrous
1/4 on nitrous?? 200 shot Kaboom! LOL
"They copied all they could follow, but they couldn't copy my mind, so I left them sweatin and stealin a year and a half behind" -Rudyard Kipling
Offline
Old Jun 24, 2009, 10:09 AM   #2
Personal Sales Rating: (0)
Excellence..'s Avatar
Drives: 1994 Chevrolet Silverado
im sure a certified mitsubishi dealer ship can provide you with a wiring diagram, if not fix your problem for like a fortune, good luck, hope this helps.
Offline
Old Jun 24, 2009, 12:11 PM   #3
Personal Sales Rating: (1)
antics22's Avatar
Drives: RR Evo X, GG Evo IX
Send a message via AIM to antics22
If you have a copy of the EVO X Service manual, the information you are looking for should be on section 42C or PDF file GR00005600-42C.pdf
Im not sure what you are trying to do, but the TPMS sensors are all controlled via the WCM which is also tied-in to the ignition immobilizer.
Offline
Old Jun 24, 2009, 12:27 PM   #4
DRAG's Avatar
TPMS is the Tire Pressure Monitoring System. I need the Throttle Position Sensor (TPS).
__________________
08 EVO X GSR
Offline
Old Jun 24, 2009, 12:29 PM   #5
antics22's Avatar
Edit.
Offline
Old Jun 24, 2009, 12:30 PM   #6
antics22's Avatar
Quote:
damn, i totally misread your post... let me dig up the TPS then... disregard my previous reply. lols
Offline
Old Jun 24, 2009, 12:41 PM   #7
DRAG's Avatar
If you found it I would send my wife over for a free BJ.
__________________
08 EVO X GSR
Offline
Old Jun 24, 2009, 02:02 PM   #8
antics22's Avatar
Does this help?
Offline
Old Jun 24, 2009, 02:10 PM   #9
antics22's Avatar
here's gas pedal
Offline
Old Jun 24, 2009, 02:12 PM   #10
antics22's Avatar
These are all listed on PDF file GR00006300-17.pdf of the EvoX service manual...
Offline
Old Jun 24, 2009, 02:18 PM   #11
DRAG's Avatar
That was EXACTLY what I was looking for. You are the man.
__________________
08 EVO X GSR
Offline
Old Jun 24, 2009, 02:26 PM   #12
antics22's Avatar
erm, dont forget to send the wifey over! lmao
Offline
Old Jun 24, 2009, 02:33 PM   #13
DRAG's Avatar
I'm getting her lubed up right now and sticking her in a Fed Ex box. Handle with care!
__________________
08 EVO X GSR
Offline
Old Jul 1, 2009, 10:34 AM   #14
DRAG's Avatar
Just FYI, the actual wiring on my X is different from that shown in the diagram. It says the voltage output is pin #6 (yellow-pink wire). My yellow-pink wire is pin #1 and pin #6 is solid green.
__________________
08 EVO X GSR
Offline
Old Jul 1, 2009, 02:23 PM   #15
antics22's Avatar
yea, theres a few discrepancies i've noticed too... For example, when i rewired the steering wheel harness to connect BEFORE the clock spring, a couple of the wires were listed as white, but it was pink in reality... and another one listed black/red was actually solid green! go figure...
Offline
Tags
2000, diagram, evo, lancer, monitoring, pedal, position, pressure, sensor, silverado, system, throttle, tire, tps, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
