Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 29, 2008, 02:57 PM   #1
Personal Sales Rating: (1)
Drives: CZ4A
Evo X Mishimoto Radiator Install
EVO X Mishimoto Radiator Install
STEP 1
-Let car cool off!! Coolant/Radiator/Hoses are HOT!
-Drain engine coolant once everything is cool.
-Remove Plastic Intake Air Duct
: 2 plastic Screws
-Remove Plastic Cowl above radiator
: 3 plastic Screws
-Remove Upper (hot side) Intercooler Pipe
: 2 clamps, 2 12mm bolts
(In the above photo you can see the X with the upper plastic trim pieces and upper intercooler pipe removed for access)
STEP 2
-Remove 4 10mm Bolts into bumper tabs
-Remove 3 10mm Hood Latch Bolts and pop Cable out (Unplug harness directly behind core support (2 wires))
-Remove 10mm Bolts holding Radiator support
: 2 on each side up top, 3 under hood latch
-Unplug Horn Wire
-Remove 1 10mm Bolt holding headlight to Rad support on each side.
-Pop the 3 clips out for the Latch harness (behind support on drivers side).
-Pop the 3 clips out for the crash sensor harness (harness runs underneath rad support)
-Remove the 2 12mm Nuts for the crash sensors
: one next to the intercooler inlet, other far D/S of rad support
: then remove sensors
-Remove the Radiator support. Shouldn't need much more than a little wiggle and pull.
(In the above photos you can see the X with the upper radiator support removed.)
STEP 3
-Unplug and un-clip the radiator fan wiring harness.
-Remove the 12mm bolt holding the Coolant filler neck to the Fan Shroud.
-Next remove the A/C Condenser from the Radiator
: There are 2 tabs that need to be un-clipped halfway down the radiator on each side.
: Then there are 2 more tabs at the top of the radiator, on each side.
-Remove Clamp for Upper hose to Radiator then remove hose from radiator.
-Remove Clamp for Lower U-shaped hose to Coolant Pipe or Radiator.
: It was easier to leave the U-shaped hose attached to the rad, and disconnect it at the pipe end.
-Remove Radiator, lift up on passenger side of radiator first, then pull up to slide radiator w/fans out.
(Stock radiator removed with fans still attached)
(Engine bay with the stock radiator removed)
STEP 4
-Stock Fan assembly has 4 clips and 2 10mm hold downs
: Remove the 10mm bolts and brackets
: Pop the 2 clips halfway down each side of the radiator, and the 1 on each top corner.
-If you left the U-shaped hose attached to the radiator, then swap it to the new one now.
-Swap fan assembly to the new radiator, and put the 10mm bolts back in with their brackets.
(The pictures above illustrate the installation of the stock fans to the Mishimoto aluminum radiator)
STEP 5
-Slide the radiator back down in, drivers side first to get the U-shaped hose to clear the side
-When the lower locating posts line up and drop into the rubber grommets, you are good to continue.
-Then lift up the A/C condenser and slide it down into the clips. Make sure it's all the way seated.
The Mishimoto radiator seated back in the stock location. Great fitment!
STEP 6
-Re-install the core support, watching the middle brace and bumper tabs.
: It is easier to run and clip in the harnesses now, while the rad support is loose
-Re-install the Hood latch and Crash sensors.
: The hood latch cable runs through the big hole on the right (d/s) of the latch
-Re-install the upper and lower coolant hoses, and the filler neck to the fan shroud.
-Re-install the Upper Intercooler pipe.
-Re-fill with coolant and start the Car
-Check for any leaks. If none, then finish the install of your performance Mishimoto Radiator.
(JNZ Tuning upper intercooler pipe is re-installed. Upper and lower radiator hoses are also re-installed at this stage)
STEP 7
-Re-install the Plastic Cowl above the radiator.
: Also install the intake air duct to airbox if you still have the stock setup.
(Back how we started but with the additional cooling and great looks of the new Mishimotor radiator!)
-In the pictures below you can see a side by side comparison of the Mishimoto aluminum radiator next to an OEM EvoX radiator. Notice the attention to detail in the fan shroud mounting points and radiator hose hookups.
Stats on the Mishimoto radiator are as follows:
Quote:
Originally Posted by Mishimoto
Core Size: 700mm x 408mm
Rows: 2
Inlet: 35mm
Outlet: 35mm
Core Thickness: 40mm
Tank Wall Thickness: 2mm
Purchase Includes: Mishimoto Radiator and 1 Year Warranty
(courtesy of JNZ Tuning, Inc. www.jnztuning.net)
Offline
Old Oct 30, 2008, 12:14 AM   #2
ilive2win's Avatar
Drives: 09 370Z
awsome, thank you for the write up
__________________
NEW HKS GOODIES ON THE Z, CHECK IT OUT
http://www.cardomain.com/ride/3800620/1
Offline
Old Jan 15, 2009, 03:26 AM   #3
antics22's Avatar
Drives: RR Evo X, GG Evo IX
Send a message via AIM to antics22
what are the stock specs compared to the mishimoto?
Offline
Old Jan 15, 2009, 07:59 AM   #4
Personal Sales Rating: (13)
Robevo RS's Avatar
Drives: Evo X Rally Car
good info ! thanks
__________________
Rallyarmor - Schroth Racing - Endless - Hot Bumpers - Forced Performance ( RED ) - Driver Technologies- HMS Motorsport- Toyo tires - AMR Engineering - Speedline Corse -BRIAutoengineering - AMS Performance
HARracingusa.com
Offline
Old Jan 15, 2009, 11:17 AM   #5
Drives: 2000 MR2 Spyder(s)
Quote:
Are you looking for dimensions on the OEM radiator?
Offline
Old Jan 15, 2009, 12:23 PM   #6
Personal Sales Rating: (0)
JDW1479's Avatar
Drives: 2008 Phantom Black EVO MR
DSSA,
What UICP, LICP, and intake is in the pics? Is that an anodized AMS intake? What about the LICP, AMS as well? And UICP?
__________________
JJ Williams "Breakin Tackles"
Tuned by Evolution Dynamics
AMS Polished Intake with Heat Shield
AMS Polished UICP
AMS Test Pipe
AMS Single Racing Exhaust
AMS O2/Downpipe
Eibach Pro Kit Springs
AEM Digital Boost Gauge
AEM Digital Wideband
3 Port MAC Boost Controller
18x9.5 +22 Bronze Volk TE-37s
265/35 Falken 452
JDM Fog Delete Kit
Clear Bra
Limo Tint
CROWN ROYAL XR (XBOX 360 gamertag)
Offline
Old Jan 17, 2009, 02:56 AM   #7
antics22's Avatar
Quote:
yes please, id like to see what the cooling differences would be going to the mishimoto (or any other aftermarket radiator for that matter)
like for example, does the mishimoto hold more coolant? are the dimensions bigger than stock?
stuff like that.
On the IX, radiator swap to koyo/pwr/etc was obvious... I cant really tell for the X.
Thanks in advance.
Offline
Old Jan 20, 2009, 12:37 PM   #8
Personal Sales Rating: (11)
R0ME0's Avatar
Drives: N/A
Any more specific directions on where to drain the coolant at? Is there a bleeding valve? Pics would be most helpful. Thanks!
Offline
Old Jan 20, 2009, 12:45 PM   #9
Quote:
Originally Posted by JDW1479 View Post
DSSA,
No that is actually our in house pipes, we make for the EVO X and will powder coat any color a customer wants. They were made a few weeks after we picked up the car actually, probably before AMS. But thanks for the compliment they do make a nice product.
If you are interested: http://jnztuning.net/shop/catalog/in...?cPath=305_315
Offline
Old Jan 20, 2009, 12:56 PM   #10
Quote:
The valve is on the front side of the radiator at the bottom on the passengers side.
It drains through one of the pegs that sit the radiator in the rad. support.
Offline
Old Jan 21, 2009, 02:18 AM   #11
antics22's Avatar
bump for anybody that might know the size/capacity differences between OEM and MISHIMOTO radiator...
Offline
Old Jul 2, 2009, 09:36 PM   #12
Personal Sales Rating: (2)
jd888jd's Avatar
Drives: Evo X- now I own, WRX Subaru - SOLD!!
Send a message via MSN to jd888jd Send a message via Yahoo to jd888jd
Got any pic of this pegs?
__________________
FS: My GTSPEC Front Strut BAr
Asking Price: $160 CAD, just had it on the car for more than a month. MINT!!!
Call me or PM me 4163022342
Reference:
http://www.gtspec.com/index.php?nav=...pid=536&cat=75
Offline
Old Jul 3, 2009, 03:20 PM   #13
tenevoten's Avatar
Drives: Evo x gsr / Toyota Tundra
sweet post. thanx
__________________
robispec kw varient 3 clubsport coilovers, bumpsteer kit, rear sway bar, camber/caster plates,
ets intercooler
ets licp
ams uicp
ams air intake
ultimate racing turbo back exhaust
ams shifter bushings
works short shift
perrin shorty antenna
cosworth cams
wheels advan rg2's
nitto nto5 tires
fp red and fuel system
ams fuel rail
awaiting install on turbo and retune
ordered fp red and fuel system
tune by TUNING TECHNOLIGIES\\ECUTEK\\AND DYNO
350AWHP\\363LBS TORQUE
Offline
Old Jul 3, 2009, 11:19 PM   #14
Drives: RR GSR X
Quote:
If you look at the bottom of the passenger side portion of the radiator you will see a petcock. It's black and looks like mickey mouse ears. If you turn it it will drain down the cylinder on the mount. If you take it out because you are impatient, like I did, it will drain faster but you will be wearing most of it.
__________________
ETS V2 Catback
ETS O2 Down pipe
ETS Test Pipe
ETS 4" FMIC
ETS UICP
AMS LICP
AMS Fan shield
Harmon Motive intake
Eibach Prokit Springs
Mishimito Coolant Hoses.
Skunk2 Shift Knob
Perrin Stubby Antenna
Cobb AP Stage 2 ACN AMS
AEM UEGO/Boost
Exedy Stage 2 HD
Act Prolite Flywheel
Whiteline Roll Center Adjustment
Offline
Old Aug 25, 2009, 05:57 AM   #15
mlomker's Avatar
Drives: 08 EVO GSR
Quote:
lol. I appreciate this how-to, I will be installing mine on the 12th. I decided to go with their fan shroud thinking it may be a little more bling.
__________________
RR 08 GSR
304hp/305tq DD by Shane@DBperformance
Offline
Tags
clamp, disconnect, evo, evolution, evolutionm, exhaust, fan, fans, install, ix, left, mishimoto, rad, radiator, x
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
