Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 30, 2009, 04:23 PM   #91
Silver Sponsor
Personal Sales Rating: (0)
Fair's Avatar
Quote:
Originally Posted by MrBonus View Post
Fair, were you able to fit those without spacers?
Yep. The 18x10.5" ET30 is pushed a bit outward on the rear, but with the relatively narrow 265/35/18 tire it didn't matter and didn't stick out. With a 285/30/18 tire it might indeed stick out/rub, so we're looking at an 18x10 ET30 instead for use out back when we go up in size.
Quote:
Originally Posted by goofygrin View Post
the RPF1 is lighter... but the offset stinks (+15). Cheaper too
I oh so scientifically (bathroom scale) weighed my 18x10.5 RPF1s to be around 19#.
19.7 according to the specs: http://www.enkei.com/spec_charts/RPF1.pdf
We weighed the Enkei 18x10 ET30 at 19.1 pounds, which seems more reasonable. This wheel would fit the rear much better but wouldn't work as well up front (prolly needs a 5mm spacer). We have longer studs and spacers handy, if/when we need them.
None of these Enkeis we tested had the right hub bore for an EVO X, so we'll machine some hub adapter rings to make them fit hubcentricly.
__________________
Terry Fair @ Vorshlag Motorsports - www.vorshlag.com
Offline
Old Mar 30, 2009, 04:27 PM   #92
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Quote:
You realize they make them I think they're all of $20-30.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Mar 30, 2009, 06:38 PM   #93
Personal Sales Rating: (1)
Excalibur's Avatar
Drives: 2008 WW Evo X GSR
Send a message via Skype™ to Excalibur
Bye bye fogs!
3 pound drop, but more importantly it unblocks coolers on both sides
Cheers,
Where do you get these?
__________________
Ecuflash (evolution dynamics)
ETS HTA GT3582R Twin Scroll
ETS Turbo Intake
ETS 4" Intercooler & Piping
Twin 38mm Mini Wastegates
Deatschwerks 1000cc Injectors
Walbro 255lph Fuel Pump (UR Install Kit)
ACT TTP Clutch w/ AMS MC Upgrade
Buschur Racing Catback
AMS Testpipe
Forge Front Lower Motor Mount
Perrin EBCS
AMI Dual Gauge A-Pillar
AEM UEGO and Boost Gauge
Perrin 2" Shorty Antenna
Offline
Old Mar 30, 2009, 11:55 PM   #94
hyperviperx's Avatar
Drives: GG X GSR
^ Japanparts.com has the JDM RS mesh grills.
Offline
Old Mar 31, 2009, 08:27 AM   #95
goofygrin's Avatar
Drives: RR EvoX
I think they said in a thread that it's just some mesh that they attached.
__________________
mmmm corn
Offline
Old Mar 31, 2009, 09:07 AM   #96
Silver Sponsor
Fair's Avatar
Quote:
http://www.hrpworld.com/index.cfm?fo...action=product
We used 1/4" mesh and cut to fit.
__________________
Offline
Old Apr 7, 2009, 06:05 AM   #97
Drives: EVO X
How would I lose weight?
I would buy a RS.
mine is actualli 1400kgs without fuel (3080lbs)
Offline
Old Apr 7, 2009, 09:18 AM   #98
GoKimiGO's Avatar
Drives: For Tri State Evo
Quote:
Originally Posted by DJ Brett B View Post
usually replacing items with expensive carbon fiber items is not as cost effective as adding power- remember, its all about good power to weight ratio that makes your car FAST. Take weight of car and divide it by horsepower. Adding 20 hp makes your car faster than removing 100 lbs for instance.
Yeah in a straight line. The best performance mod you can do is weight loss, it improves every single aspect of a cars performance. Adding power improves acceleration nothing else.
My car being daily driven will only see weight mods that will not affect safety and comfort.
__________________
Happy safe and spirited driving :)
///// Tri-State Evo
Offline
Old Apr 8, 2009, 10:05 AM   #99
Silver Sponsor
Fair's Avatar
Quote:
I would buy a RS.
True, that is a lightweight car. Only problem with the RS is you lose ABS...
I dip into ABS under threshold braking a good bit in low speed (autocross) events and I our braking data logging shows that having ABS is a performance benefit. Its still nice to have on track, as a safety net to improve driver confidence and to avoid flatspots under heavy braking. ABS is also invaluable in the wet, like no other driver aid ever designed.
Our ABS/AYC/SST/etc equipped EVO X is a real heavyweight.... lots of electronic doodads and a big big car overall. It weighed 3490 pounds with a full fuel tank at the Houston SCCA National Tour last weekend. We'll never legally get it as light as an EVO 8 RS, of course, but it was still pretty dang quick at this (and other) autocross event. On a road course all of the electronic help and added mass isn't probably going to make up for the added weight, but we'll see.
edit: we keep trying to get weight out, a bit at a time. We just added a Cobb downpipe and cat and dropped another 10. Every little bit helps...
__________________
Offline
Old Oct 13, 2009, 10:07 PM   #100
Golfa's Avatar
Drives: ****baru STi
Thanks to Terry ^^ who had the only valuable posts in this entire thread!
Offline
Old Oct 30, 2009, 04:51 PM   #101
Drives: 2009 black ralliart, injen cold air, custom exhaust and valve cover paint.
Send a message via Yahoo to theirvin
I bet by swiching out those recaros for some carbon sparco seats will remove dead weight, the exhaust system is also heavy and can be easily replaced. Look at Ryan Gates Evo X, AMS did a great job with his car!
Offline
Old Nov 8, 2009, 06:11 PM   #102
Phantom X Evo's Avatar
Drives: 2010 PB Evo X GSR sss
Rear head rests are about 3lbs and engine cover is about 2lbs ( on bathroom scale).
Offline
Old Nov 18, 2009, 04:57 AM   #103
hotdog's Avatar
Drives: 2008 Evo X
Quote:
Removing the middle headrest in the back also has the added benefit of allowing you to see better, if you're short
__________________
2008 Evo X GSR. Rally Red.
Buschur
UICP/LICP
Buschur Intake/MAF Pipe/Shield
Buschur Cat Back Bullet
Buschur Test Pipe
Buschur Shifter Bushings
Buschur Evo X FMIC
Offline
Old Nov 18, 2009, 05:18 AM   #104
Personal Sales Rating: (35)
Domolution's Avatar
Drives: RC Cars!
Send a message via AIM to Domolution
Quote:
Originally Posted by aznxkaiser View Post
Im a skinny asian kid...I weigh like 129 LOL my body weight is JDM yo!
LOL! Hahaha......wah dah pak!?! ^____^
And many ways to lose weight.....rear seats, trunk linear, spare tire, ugly ass scissors jack, rear windshield whipper and fluid reservoir, and other crap that you don't use daily, but perfect for losing weigh.
__________________
WEHEHE!!!!!!
:D
Offline
Old Nov 18, 2009, 10:21 AM   #105
Personal Sales Rating: (10)
Solo II Evo's Avatar
Drives: 2003 Evo GSR
Send a message via AIM to Solo II Evo
Quote:
Originally Posted by shagjw View Post
Dear god they have Evo's in the UK ... must be wierd to drive on the wrong side of the road on the wrong side of the car. and FQ i think spares are a US requirement with any new car
Someone lives in a black hole.... Evos were in the UK before the U S! And since when is it the wrong side? lol.. granted I probably would be very thrown off driving a RHD car, but RHD = JDM TYTE YO!
Honda Accord Hybrids, Prius, and Civic Hybrids all come w/ fix-a-flat, not spare tires, here in the US.
__________________
Schreinerized
An uber 03 LY Evo
Tracked, Autox'ed, and finally, no longer a daily driver.
Featuring: Exedy Twin, Custom Valved PSS9s (12k/16k), Baller NT03+M, and the usual stuff found on most Evos.
WTB: Rota P45R, 18x9.5". Any color.
Offline
Tags
08, 3lbs, battery, corolla, evo, evolutionm, factory, subwoofer, tire, weight, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
