May 14, 2008, 01:51 PM
#31
Personal Sales Rating: ( 7)
Drives: '05 AS Evo VIII (96940011)
all this for a simple DRL...
__________________
MODS
- CBRD BBK Full
- FIC 1050cc
- KELFORD 272 CAMS
- BC SPRINGS & Ti. RET.
- GATES
- AQUAMIST HSF-1
- SPEC Super Twin P-Trim
- INJEN A/I SYS w/Amsoil filter
- TIAL Q 50mm BOV
- 3" TURBO XS CATBACK
- eBay 3" TESTPIPE
- 3" MR DN PIPE
- MR HEADER
- ETS LICP
- ETS 3.5" FMIC
- EVODAVE HEADLIGHTS
- EVO 7 TAILS
- TEIN-S
- 255 F.PUMP
- Amsoil ATM 10w30
____________________________________________
4WSTuned! R.I.P. Westley Hess (12/30/2008)
North West Evolution!!
Offline
May 31, 2008, 08:32 PM
#32
Personal Sales Rating: ( 0)
Drives: X GSR
Why would the owners manual tell you how to disable the DRL's???? If the manual tells you which fuse to pull I can't see how that voids anything. It is a fuse. Moreover, I suspect if you drive in to a dealer and they notice that and point it out it would be simple to tell them, yeah I pulled the fuse like the owners manual said. Done. Who cares?
Offline
Jun 13, 2008, 09:43 AM
#33
Personal Sales Rating: ( 2)
Drives: Evo X- now I own, WRX Subaru - SOLD!!
Quote:
Originally Posted by mksevo
ok, per the owners manual, you will need to access the fuse box in the engine bay, its the large black box on the drivers side. lift the lid from the front there is a small plastic latch. you will need to remove fuse # 13 this is the last fuse on the first row of fuses at the bottom of the box. it should be a red 10 AMP fuse. look on page 7-42 of the manual if you need a pic. but the bottom row of small fuses has only 13 in it. pull this out and presto no DRLs , I did test everything else and all seems to work fine. spaces for fuse 11 and 12 were empty. Hope this helps.
This doesnt work on Canadian Base model EVO X.....Tried it today..pulled the fuse out nothing happened. ..
Offline
Jun 13, 2008, 02:55 PM
#34
Drives: EVO X GSR
look in your owners manual , its the section on headlights and fuses. should show you which fuse runs the DRLs. they are on a seperate fuse link than the headlight.
PS this doesnt work for EVO without HID. so you may not have the HIDs.
__________________
So many MODS so little TIME
Offline
Jun 27, 2008, 06:48 AM
#35
Drives: OB Evo X GSR
Did anybody find out how to disable the DLR for evo x non HID yet?
Offline
Jun 27, 2008, 11:10 AM
#36
Drives: WW X
Quote:
Originally Posted by AkumaMax
just for the sure fact that some peoples eyes at night can't determine the distance of some cars. Your eyes sometimes plays tricks on you. Plus it's not just the fact that people have lights on then more or less it being a factor of falling asleep or being drunk etc... If you're that worried about the cops seeing you then you have got to slow it down a little. I know how the Texas highways are and everything but speed can kill! Also you don't own a sports car you own a 4 door Saloon
most cops don't even know what an evo is. to him it is another sedan and get and ticket and see what he write. most likely it will be mitsu lancer and the color. it isn't like you're driving a lambo. i hate when people think that their car is so cool that everybody wants to touch and cops are on the look out for it. give me a break!
rock on ricer!
i quoted because i am concurring with akumamax.
Offline
Jul 1, 2008, 11:20 PM
#37
Drives: 08 EVO X GSR. 07 911 Turbo
you will loose the head lamp adjustment as well when you pull fuse #13 on an HID equipped GSR.
Offline
Jul 2, 2008, 04:39 PM
#38
Drives: EVO X GSR
My headlamp adjust switch works just fine. you can raise or lower the HID. not sure which model you have but you may want to check it again. or maybe you pulled the wrong fuse.
__________________
Offline
Jul 8, 2008, 03:31 PM
#39
Drives: Silver Evo X
Quote:
+1 I'm wanting to swap in some HID's but don't know how they will react with the half voltage running the DRL's normally...could you run with the headlights on all the time as a temp fix without disabling the DRL's? Thanks.
Offline
Jul 31, 2008, 08:54 PM
#40
Drives: 2008 EVO X GSR
+1
__________________
2008 Evo X GSR GG, HKS Drop-in, AMS Underhood Shifter Bushings, Tint (18% Ceramic)
Offline
Aug 3, 2008, 09:03 PM
#41
Personal Sales Rating: ( 3)
2008 Mitsubishi Lancer Evolution
Drives: 05 acura TL (sold) / 08 ww evolution x gsr
Quote:
I run with them on all the time for now
Offline
Aug 3, 2008, 10:20 PM
#42
Drives: 08 Evo X ob
Coming from a fourth generation eclipse... we had the same issue. The DRL's worked in conjunction with the low beams. However, a solution was found by tampering with some sort of circuitry box if you will. Not quite sure what it is, but it worked beautifully. Tried looking for something similar for the X but no luck. I'm no electrical engineer by any means, not my field... so I will attach a link to the how to on removing the DRL's on a 4G Eclipse with the same low beam issue. Perhaps it will help someone else figure it out... one day.
http://www.club4geclipse.com/modules...ewtopic&t=9913
For me, it has nothing to do with being spotted by cops, being more noticed, etc... it's the aesthetics. Personally, I think it takes away from the appearance of the car during daylight. For example, I'm sure many ppl here have shut their car off before taking a picture, just so they can get rid of the DRL for the shot.
As for the safety feature, I'm not trying to sound immature... but if you can't see a 2 ton 6 feet wide heap of metal heading towards you, then you really shouldn't be on the road, or crossing it. my 2 cents.
Offline
Aug 17, 2008, 10:54 AM
#43
Personal Sales Rating: ( 5)
Drives: Lancer
hm, so it can be done!
just needs someone to figure it out....
ill be waiting in the mean time
Online
Aug 17, 2008, 12:02 PM
#44
Drives: 08 EVO X
pull the light bulb out. isnt that the easiest way to stop the drl?
Offline
Aug 19, 2008, 12:05 AM
#45
Personal Sales Rating: ( 13)
Drives: 04 Evo 8(SOLD) 08 Evo X and s13
nah wont work i know my gsr low beam bulb shares is the drl so pulling the bulb means no low beam haha. Stright high beam action in traffic guys would be flipping me off.
Offline
Tags
07, 08, accord, cbr600rr, day, daytime, honda, lancer, light, lights, running, time, turn  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
