Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 3, 2008, 03:21 PM   #1
Personal Sales Rating: (4)
PDXEvo's Avatar
Drives: '08 WW X GSR
How to: Make your own shift boot
Hey All,
Here is a little project you can do in about an hour, and only costs you about $5.
Below are the step by step instructions, and here is a link with step by step including pictures for each step.
http://picasaweb.google.com/cpavlas/...hiftBootOnEvoX
Items you will need:
- Seam splitter / or other cutting device (I used a pair of alternative lifestyle cutters, or dikes, for those that are non pc.
- Needle nose pliers for removing staples
- Small Philips and Flat Head screw drivers
- Scissors
- Material for making a new shift boot
- Marker for making the pattern
- Sewing machine (not necessary but makes it easier)
- Stapler, preferably a red one
Step 1: Dismantling the shift boot console
1 - Take off shift knob
http://picasaweb.google.com/cpavlas/...74365725804386
2 - Using your small flat head screw driver. Gently pry off the mini box area in front of the cup holders. You dont have to pry hard, so be gentle so you dont damage the plastics. Remove the cable plugged into the back of this box.
http://picasaweb.google.com/cpavlas/...74374315738994
3 - With the box removed, pull up, with some force, to pop the center area out
http://picasaweb.google.com/cpavlas/...74382905673602
4 - Now you can see the two screws holding the shift knob / ash tray / lighter
assembly in place. Go ahead and remove these two screws.
http://picasaweb.google.com/cpavlas/...74387200640914
5 - With the screws removed, gently lift up on the shift assembly. It comes up a lot
easier then the center console piece did
http://picasaweb.google.com/cpavlas/...74395790575522
6 - Unplug the lighter cable
http://picasaweb.google.com/cpavlas/...74404380510130
7 - Using your small flat head to push the leafs in on the connector holding the cable that goes to the lighter socket and remove the connector
http://picasaweb.google.com/cpavlas/...74408675477442
8 - With the shift boot assembly out, you can now easily remove the 4 screws holding it in place
http://picasaweb.google.com/cpavlas/...74412970444754
9 - Remove the shift boot from the assembly
http://picasaweb.google.com/cpavlas/...74417265412066
10 - Using your small flat head screw driver, remove the staples
http://picasaweb.google.com/cpavlas/...74425855346674
11 - Turn the boot inside out, and use a pair of alternative lifestyle cutters to remove the zip tie holding the shift knob retainer piece on
http://picasaweb.google.com/cpavlas/...74434445281282
12 - With the retainer piece removed, use a seam splitter, or other sharp cutting device, to cut the stitches out. You only have to snip a little but then pull the material apart. It comes apart quite easily
http://picasaweb.google.com/cpavlas/...74451625150514
13 - With the shift boot separated, you are now ready to make yourself the template for your new boot
http://picasaweb.google.com/cpavlas/...74455920117826
14 - Layout each half of the cars original shift boot onto the material of your choice and trace the pattern on to the new material
http://picasaweb.google.com/cpavlas/...74464510052434
15 - Cut out your pieces and then sew them together at the edges, just like the stock boot was
http://picasaweb.google.com/cpavlas/...74468805019746
16 - Re-attach the shift knob retainer and use a zip tie to hold it in place, just like the stock one was
http://picasaweb.google.com/cpavlas/...74485984888962
17 - Flip the boot back out again to prepare for attaching it to the shift boot assembly
http://picasaweb.google.com/cpavlas/...74490279856274
18 - Staple the new shift boot onto the assembly
http://picasaweb.google.com/cpavlas/...74498869790882
19 - Reverse your un-installation procedure from above and think to yourself, wow, this was the cheapest mod ever
http://picasaweb.google.com/cpavlas/...74503164758194
I went with white because I have a white/black leather seats combo going in, along with aluminum shift knobs etc. It wont look so out of place once thats done
__________________
Click here to join the Portland, OR Evo Yahoo Group!
Offline
Old Feb 3, 2008, 03:48 PM   #2
Personal Sales Rating: (5)
Jameson_IXMR's Avatar
Drives: an evo duh?
I dont have the X yet, but I imagine the idea is the same on the 9? Nice!
Offline
Old Feb 4, 2008, 01:19 PM   #3
Personal Sales Rating: (12)
Wow, how did you ever figure all that out?
Nice and thanks for sharing!
Offline
Old Feb 4, 2008, 02:29 PM   #4
Personal Sales Rating: (0)
Drives: '06 Evo MR, (SOLD May 3, '06) and '04 Ducati 999 Bi and '89 Mustang GT
Thanks!
This is just like the FOX network showing that series of TV shows
"Breaking the Magicians' Code: Magic's Biggest Secrets Finally Revealed"
(only with shifter boots)
Offline
Old Feb 4, 2008, 06:50 PM   #5
Drives: an evo duh?
^lol
Im just glad to hear the idea. Iv been looking for some little things to spend my time on between larger installs.
Offline
Old Feb 4, 2008, 08:44 PM   #6
Personal Sales Rating: (31)
sgand's Avatar
Drives: '09 ES Sport, '03 OZ
Send a message via MSN to sgand
thanks! heading to some craft store to pick out my new boot soon. lol
__________________
Quote:
Originally Posted by Blacksheepdj View Post
Oh my. Gotta agree with sgand on this...
The Lancer is an ECONOMY CAR. Learn it, live it, love it.
I need my wife's permission before modding my (our) new Lancer.
llllllll
FS: Interior Carbon Fiber
Offline
Old Feb 4, 2008, 09:36 PM   #7
Drives: 08 Graphite Gray Pearl X
^lol, thats exactly where i'm going to go too lol.. time to find REAL leather!
Wow just a zip tie??
No metal ring of anything else spiffy?
Anyway... good write up man!
Offline
Old Feb 4, 2008, 09:41 PM   #8
Personal Sales Rating: (11)
kimchee's Avatar
good job on that mod, looks nice
Offline
Old Feb 4, 2008, 11:42 PM   #9
PDXEvo's Avatar
Thanks guys. It will look better once the seats go in. Unfortunately, no one has patterns for the new seats yet, so they cant be done. What happened to the good ol' days when you made your own patterns?
__________________
Offline
Old Feb 8, 2008, 07:37 PM   #10
Personal Sales Rating: (7)
EvolvedVIII's Avatar
Drives: CZ4A
Where did you get your leather? All the fabric places I went too said they can't get leather.
Offline
Old Feb 8, 2008, 08:52 PM   #11
Former Vendor
Personal Sales Rating: (3)
Drives: 03 GSR,05 MR drag car,04 Civic Si,08 R1200GS,09 Ducati 1198S
Here is our replacement boot, genuine leather with double stitch to match the steering wheel, however it is not 5 bux
good luck
Offline
Old Feb 9, 2008, 05:21 PM   #12
Personal Sales Rating: (14)
Eric06's Avatar
Drives: 2006 Evolution IX
Looks good.
__________________
BR Tuned Evo IX
Offline
Old Feb 9, 2008, 05:26 PM   #13
PDXEvo's Avatar
You have to go to a leather dealer to get leather. If you want the stiching like above, its easy to do. Just choose your color and run it down with your sewing machine. Im not a big fan of the stitching though, so I didn't do it. I should update my pics with the new aluminum shift knob. It makes it look worlds better.
__________________
Offline
Old Feb 10, 2008, 08:51 PM   #14
Drives: an evo duh?
It looks great, please update pics, Id love to see them.
Thanks
Offline
Old Feb 16, 2008, 03:30 PM   #15
Personal Sales Rating: (72)
RpmSteve's Avatar
Drives: 07 4 runner/08 EVO GSR
Send a message via AIM to RpmSteve
PDX would you make me one if I paid you to do it? Or team D?
__________________
05 evo-sold
06 g35 coupe-sold/06 gsxr 600-sold
06 evo-sold
05 evo-sold
03 evo-sold
08 evo-sold/06 gsxr 1000-sold
Current-07 4 runner LTD V8/08 cbr 1000rr
C6 Z06 next!!!
Offline
Tags
04, 2005, boot, boots, evo, gt, lancer, make, mustang, pattern, patterns, remove, shift, shifter, small
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
