SST Throttle Lag - Definitive Answer
Old Apr 29, 2013, 05:38 AM
ClockwerkOrange's Avatar
So what's the definitive answer for getting off the line faster? I just got my X MR, and almost got rear-ended because the my car took too long to get going! I know I'm not going to have instant torque liketheCamaro I just traded in, but I want it to use the torque it does have.
so is the answer a "throttle controller", tcu flash, ecu flash, launch control sequence at every stop sign, ???
Old Apr 29, 2013, 08:34 AM
Leezon's Avatar
When the car is cold is can be a little rough on the throttle, but as soon as it's warmed up it's faster than a GSR off the line.
Have you had a turbo car before? Do you know about turbo lag?
Old Apr 29, 2013, 08:38 AM
punk3r's Avatar
What i do is leave some room to the car in front of me and anticipate the light, let go of the brake right before the light turns green so the clutch will engage before i get on the gas. But you can look in the SST section of the forums, there's a whole thread on tuning the SST table and stuff.
Old Apr 29, 2013, 09:20 AM
EvoForumUser12's Avatar
Have your tuner remove the 1st gear throttle limit.
Old Apr 30, 2013, 12:21 AM
Yessir. Very first car was a Volvo turbo coupe (turbo brick - 4-speed w/ push-button overdrive). Also had a turbo Eclipse that I would drag all the time, as well as an Evo VIII that I would do track days & auto-x with (and a little drag racing, but that got boring).
With the SST I just can't adjust my launches to suit what I'm about to do, and I'm not going to take the time to set up a launch sequence (not to mention it costs $12K to fix the transmission!) So I'm hoping there is a better way I love everything about the SST except for getting off the line from a stop.
I even tried power braking but it didn't help. There is a stop sign on my way to work that has basically no merge lane, and people are doing 50mph+ trying to get to work pretty much bumper-to-bumper, so I have to get moving in a hurry. My Evo VIII had absolutely no problem with this. My Camaro was more difficult because it had no traction. And this one, let's just say it scared the crap out of me the first time I was expecting it to go and it didn't. And the guy behind me was none too happy either.
Do the '13's have that? I thought they didn't. If they do I'm gonna do that, thanks!
Old Apr 30, 2013, 12:22 AM
Is the SST table in the ECU or TCU? Sorry but I haven't been following the X as closely as I should have been all these years!
Old Apr 30, 2013, 12:34 AM
punk3r's Avatar
I believe it's in the TCU. I haven't really mess with it myself. I never had a problem with getting off the line, like Leezon said, once the SST warms up it response pretty smooth and quick. Before i had my car tuned it did have a lot of turbo lag off the line though, that might be what you are feeling. just a thought
Old Apr 30, 2013, 12:40 AM
punk3r's Avatar
I just read your other thread and you had other turbo cars so you know what turbo lag feels like so nvm haha turbo lag might not be your problem then. But after a tune my car did feel a lot lighter and quicker off the line.
here you go: https://www.evolutionm.net/forums/ec...nt-thread.html
i could be wrong with the file being in the TCU. give that thread a read, should answer most of your questions. hope that helps bud
Old Apr 30, 2013, 08:43 AM
alright cool! I think I'll give English Racing a call. if it's tunable, Lucas can tune it!
thanks!
Old May 2, 2013, 06:27 AM
thanks!
The information about this 1st gear limit is on the other forum. Google "evo x sst 1st gear throttle limit found" and you should see the link.
sgoodwin1
Dec 29, 2017 08:43 PM
Evo_Goodness
Sep 2, 2016 05:05 PM
D-Man
Jun 5, 2016 07:53 AM
lukas1989
Apr 17, 2016 03:48 PM
vince126
Canadian Forum
24
Dec 3, 2014 12:59 PM
Quick Reply: SST Throttle Lag - Definitive Answer
