ATTN: EVO 10 Owners, Run a manifold heat shield or your car could catch on FIRE.
Old Feb 24, 2012, 05:57 AM
Scottr126's Avatar
Short version: If you own an EVO 10 you must run the stock or some sort of exhaust manifold heat shield or you will eventually burn your firewall, valve cover, wiring, or the car to the ground.
Long version: Yesterday we had an EVO 10 on our dyno for tuning. During some preliminary cruising and getting things set up it was noticed there was smoke pouring out from the back of the engine bay near the turbo. Sure enough the material on the firewall was burning and a hole about the size of a golf ball had formed. I quickly got some water and put it out but the damage had already been done. The wire loom had melted off a wiring harness in the area and the firewall pad had been burned up pretty good. I have no doubt in my mind if this car had the plastic valve cover it would have melted also.
I noticed when spraying the area with water that the water was actually sizzling off of the strut tower brace. Needless to say it was HOT back there. And this was without doing any WOT pulls...
This isn't the first time heat has taken its toll on an EVO 10 engine bay I have seen ABS modules burn up and plastic valve covers melt.
If you have an EVO 10 RUN THE STOCK EXHAUST MANIFOLD HEAT SHIELD, IF YOU BUY A TURBO KIT MAKE SURE IT COMES WITH PROPER SHIELDING. Stock frame turbo, PTE turbo, Garrett turbo.. it doesn't matter. The area around the turbo on these cars does not do well with alot of heat like the 8s and 9s did.
My main goal with this post is to warn the owners of these cars about this as I don't want anyone to have their car burn to the ground or even worse. You will notice in our turbo kit we have both a manifold heat shield AND a firewall heat shield.
Old Feb 24, 2012, 06:01 AM
Alpha X's Avatar
Wow thanks for the heads up. I was thinking about just using Titanium Exhaust Wrap. But after reading this I'll use a heat shield as well.
Old Feb 24, 2012, 06:06 AM
carbonair's Avatar
just for personal education, would this not happen only on a dyno? While driving the heat would be disapated and the air will move the heat out of the engine bay.
Old Feb 24, 2012, 06:11 AM
Scottr126's Avatar
I have seen some EVO 10s on the road course burn parts up. If it were me after seeing this stuff I wouldn't risk it.
We have three front dyno fans running all the time.
Old Feb 24, 2012, 06:22 AM
Kendogg's Avatar
Does the car come with a heat shield stock? Or do you need to buy one?
Old Feb 24, 2012, 06:32 AM
Scottr126's Avatar
Yes from the factory it comes with a heat shield.
Old Feb 24, 2012, 06:50 AM
Phantom09's Avatar
i have a MAP mainfold and i been looking for shields. i looked on your website but seems you shields only come with the turbo kit purchase. anyway we can buy them and will they work with the Map Mani?
Old Feb 24, 2012, 06:57 AM
Kendogg's Avatar
So yours didnt have a heat shield cause you removed it?
Old Feb 24, 2012, 07:14 AM
murlo26's Avatar
*****...I don't want to deal with more evo x nonsense!
Thanks for the heads up though AMS!
Old Feb 24, 2012, 07:17 AM
CAD EVO's Avatar
Probably saved alot of cars and possibly lives. Good job informing the community.
AMS
Old Feb 24, 2012, 07:22 AM
Scottr126's Avatar
The car that inspired this post had a tubular manifold that didn't have the provisions for a factory heat shield.
Old Feb 24, 2012, 07:23 AM
Kracka's Avatar
Check out their firewall heatshield: https://www.evolutionm.net/forums/ve...our-evo-x.html
And also their new custom/prototype manifold shield they made for me: https://www.evolutionm.net/forums/9990004-post45.html
These along with ceramic coatings should be a very reliable and safe setup IMO.
Old Feb 24, 2012, 07:24 AM
desiromeo812's Avatar
I would also run a turbo blanket. Good save in the picture, this coulda been worse if not spotted on dyno
Old Feb 24, 2012, 07:25 AM
Scottr126's Avatar
That MAP firewall shield is really nice. Definitely a good option.
Old Feb 24, 2012, 07:35 AM
sblvro's Avatar
thanks for the heads-up! some points to take/learn by mitsubishi when designing the next engine orientation for the evo
now a sticky!
Quick Reply: ATTN: EVO 10 Owners, Run a manifold heat shield or your car could catch on FIRE.
