Oct 21, 2009, 09:58 AM
Personal Sales Rating: ( 2)
Drives: 2008 evo
help, check ACS warning light keeps coming on
hi guys i did some research and couldn’t find much information on this warning, if there is already FAQ bought it i didn’t see it and sorry for the repost
i get a ACS warning light on occasions whenever accelerate hard on the gas and the acs system shuts off, "it has never affected the performance of the car just a dummy warning light comes on
from what i have read so far its related to over boosting ? is this correct? if so I’m not sure how this is possible the car is 100% on stock tune and boost but i do have a few mods, the only mods i have is a full turbo back exhaust from invidia and a short ram intake from AEM, every thing is 100% correctly installed and nothing leaks, all vacum lines are correctly installed,
i do not have a boost gauge so i cant 100% verify the boost level but i cant see it being a problem since the ecu is 100% factory and no boost controller added
i plan on getting the tune done in December maybe this will solve the issue? or maybe its with the AWD system and i need to take it to the stealership
now I think abought it some I think it started coming on after the exhaust system was put on
any help in this department would be appreciated
james
rr evo x
Online
Oct 21, 2009, 10:32 AM
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: 08 Apex Silver GSR
You're running a full TBE and a SRI with no tune? Not good.
__________________
OEM Front Brake Air Guides
AMS UICP / Hot Pipe
TWM Short Shifter, Console Bushings, A6 Leopard Shift Knob
Perrin 25mm Adj. Rear Sway Bar
Perrin Cat-Back Exhaust
Deka ETX20L AGM Battery
Ralliart Tail Lights
AEM Intake
T1R Shifter Boot
AMS High-Flow Cat
Cobb Stage 2 Map
Works Under Hood Shifter Bushings
Offline
Oct 21, 2009, 10:38 AM
Drives: 2008 evo
darwin like i said its getting tuned in december, just put $1,500 into on top of the over 30k paid for it, i have do things in stages or my wife will divorce me !! LOL
i have full intentions of getting it tuned in december i have only had the car for a few months now, one thing at a time,
so why is this warning light coming on ? is it related to over boost or the AWD system ?
Online
Oct 21, 2009, 10:59 AM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
it's overboosting.
you're probably new to the stock boosted world, so i'll save the flaming later. but with any mod in a high boost car like the evo, you're supposed to keep at it easy until you can get a tune. to answer your question, it's more than likely you're overboosting. what brand intake/tbe do you have?
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Oct 21, 2009, 11:12 AM
Drives: 2008 evo
thanks endgame, and the reason its over boosting is because of the exhaust and intake system, even though the ecu is 100% stock and stock nothing to do with the AWD system
Online
Oct 21, 2009, 11:47 AM
Personal Sales Rating: ( 0)
Drives: 08 RR X GSR
I get this too, there are a few threads in the turbo/engine section about it.
It only happens to me when I spike past 30psi, seems like that is what most people see this at, or at least higher than 27 or so.
I spoke with Ryan Gates (blacktrack) he said this happens to him sometimes too and it sounded like he said it wasn't a big deal. I trust him when it comes to the X since he beats his to no end so you should be alright.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Online
Oct 21, 2009, 12:01 PM
Drives: 2008 evo
thanks murlo, looks like i will need getting the tune sooner then i planed on,
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
