Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 13, 2009, 11:41 AM   #1
Personal Sales Rating: (0)
Drives: 2008 Mitsubishi Evolution X
Brake warning light...
Ok, ive noticed that everytime i go into a corner,especially when making a left turn at a decent speed my warining light comes on. It the one with the exclamation point and parentheses (!)...i looked it up in my manual and it says check brake fluid. Ive checked the brake fluid and everything is good..ive made an appt with the dealer but wanted to know if anyone else has had this problem.
Offline
Old Oct 13, 2009, 11:48 AM   #2
Dr. Ev0L's Avatar
your brake fluid is most likely on minimum. eventually the light will be on all the time as your brake pads wear further. i would get the pads checked to see where they are at. that light is a warning but sometimes the fluid is a little low from the factory.
Offline
Old Oct 13, 2009, 12:00 PM   #3
Personal Sales Rating: (13)
rcheung's Avatar
Drives: 2003 Evo 8
Quote:
Your brake fluid could be sloshing causing it to trigger the light when turning. It still means that the fluid is at or near the low mark and either you have a leak in the system or pads are getting low.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
Old Oct 14, 2009, 03:38 AM   #4
I would bet more than likely the pads are low rather than a leak in the system. You can always check the brake resevoir.
Offline
Old Oct 14, 2009, 08:22 AM   #5
2008 Mitsubishi Lancer Evolution
My Garage
stikllr13's Avatar
Drives: Evo X
Same thing happened to me, it IS an indicator that your brake fluid is low. Top it off! Problem solved.
__________________
Mods:
Cobb: SF Intake, Springs, R/Sway Bar, AP, Turbo Inlet
Artisan: Cat-back exhaust
Works: Short Shift
AMS: Under Hood Shifter Bushings
Titek: CF Hood Scoop
Rexpeed: CF Front Lip, CF Bumper Cover, CF Side Spats
Auto Meter: Boost Gauge w/ CF pod
3M: 5% Tint
Endless: NS97 Front Pads
Rotora: Brake Lines
Ralliart: Tails
Rota: 18X9.5 Yamaha Black Rota Grids
325Whp 323Wtq on Mustang Dyno
Stage 3 coming this Summer
Offline
Old Oct 14, 2009, 12:58 PM   #6
rcheung's Avatar
Drives: 2003 Evo 8
Quote:
The problem is not solved only bandaid. If the low fluid indicator light is on something is wrong.
__________________
2003 GSR EVO
Offline
Old Oct 14, 2009, 04:54 PM   #7
Personal Sales Rating: (4)
Drives: 08 evo x, ex 96 eclipse gst, 03 evoultion 8, and 07 audi s4
Send a message via AIM to tokeone
your fluid goes down as your pads wear. you get the indicator when youre pads are past halfway done...
trust me
add some fluid, and know that new pads are not far behind
with 50k miles on my car, ive been through this a few times
__________________
chris type rre cat back
rally cat
ultimate racing o2/dp
ets upper and lower i/c pipe
ets 4" front mount
aem intake
mueller stage 1+
matte black vinyl
wedsport sa-67r 18x9 +20
cosworth cams
blouch dominator 2.0
hb speed tune
400whp/360wtq
Offline
Old Oct 14, 2009, 11:40 PM   #8
thanks for the advice..i have 11,000 miles on my car..just had it serviced last month so i guess its the pads...my fluid looks good.
Offline
Old Oct 14, 2009, 11:44 PM   #9
m0nkie's Avatar
Drives: WW GSR SSS
I hit 20k.. had that problem n it was my pads wearing out..
__________________
A wise m0nkie never m0nkies with another m0nkie's m0nkie.
Offline
Old Oct 14, 2009, 11:46 PM   #10
i heard my brakes squeak a lil the other day too so i guess its time for new pads...how much does the dealer charge for new pads on average?
Offline
Old Oct 15, 2009, 12:44 PM   #11
well the thing is if the fluid is slightly below full this happens because on braking or hard acceleration the fluids movement exposes the censor enough...
even if it looks full add more fluid.
your pads should probably be good for a few more thousand miles. id say they probably have about 40% life left. thats pretty much how its been everytime its happened to me.
which as of yesterday is my third time.
__________________
rally cat
ets 4" front mount
aem intake
mueller stage 1+
matte black vinyl
cosworth cams
hb speed tune
400whp/360wtq
Offline
Old Oct 15, 2009, 01:20 PM   #12
Personal Sales Rating: (1)
2007 Jeep Grand Cherokee
My Garage
Deception's Avatar
Drives: GG Evolution X GSR
Don't go through a dealership for new pads, they over charge like crazy... if you're looking for less performance pads along with less brake dust and squeaking, you should check out some silicon pads...
Offline
Old Oct 15, 2009, 01:37 PM   #13
m0nkie's Avatar
Drives: WW GSR SSS
I just ordered some Ferodo DS2500 pads for 280$... my shop said they can order oem pads for about 280 too... so I decided to upgrade a lil..
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
