Fuel pump relay safety: All new BLUE relay from Mitsu, updated info on page 4
Old Sep 4, 2009, 06:28 PM
LVSBB6's Avatar
So I went to my local dealership to buy #MR588567 relay for fuel pump, they ordered it in for me but with a different number replacement listed #8627A011. According to the parts advisor, Mitsubishi may be aware of the relay problem and now uses another manufacturer to make this part.
Here's what it looks like:
Old Sep 4, 2009, 06:52 PM
►EvolutionX◄'s Avatar
why does it say relay, horn? just curious
Old Sep 4, 2009, 06:58 PM
LVSBB6's Avatar
horn relay = fog light relay = DRL relay = highbeam relay = Fuel Pump Relay
Old Sep 4, 2009, 07:17 PM
stokEd's Avatar
Thanks for the heads up.
Old Sep 4, 2009, 07:21 PM
artnsx's Avatar
how much was it?
Old Sep 4, 2009, 07:27 PM
Mitsutech56's Avatar
Thats the updated fuse for TSB-07-13-010 used to correct a no start issue due to condensation freezing in the relay housing in cold climates. Its also used for Throttle Valve Control Servo, Injector, & Starter.
Old Sep 4, 2009, 07:34 PM
artnsx's Avatar
so...in addition to being the fuel pump relay? or are you saying it's not the right part for a replacement fuel pump relay
econorocket's Avatar
x2 ??????
Old Sep 4, 2009, 07:39 PM
that green relay supersedes the old relay. I meant to include the fuel pump also.
Old Sep 4, 2009, 07:43 PM
Awesome, thanks for the clarification!!!! Just ordered mine! Preventative maintenance FTMFW
Old Sep 4, 2009, 09:50 PM
Djstorm100's Avatar
so this is the right relay for the fuel pump? How much was it?
Old Sep 5, 2009, 05:45 AM
DarwinX's Avatar
What do you think the chances are Mitsubishi makes the replacement of this fuel pump relay it's own TSB so we can get this replaced for free?
Old Sep 5, 2009, 07:12 AM
therocket's Avatar
This green relay (ACM32221, still manufactured by NAIS-Matsu****a) is already present in the fuse relay box: they are relays H, K, N that are throttle actuator control motor relay, injector relay, starter relay
So now Mitsu decided to use the green relay also for all the other actuators (fuel pump, high beams, horn, DRL, etc) in place of the black relay (ACV31212) currently used fot them?
Old Sep 5, 2009, 07:25 AM
AWDTerror's Avatar
Originally Posted by therocket
This green relay (ACM32221 still manufactured by NAIS-Matsu****a) is already present in the fuse relay box: there are at least 3 of them, used for other engine actuators. So now Mitsu decided to use the green relay also for all the other actuators (fuel pump, high beams, horn, DRL, etc) in place of the black relay (ACV31212)?
color coordination with the whole "going green" theme?
Old Sep 5, 2009, 07:27 AM
Spins4's Avatar
Nice! I'm going to have to call my local Mitsu Tues. to see if they have any, and if not, get one in for Wednesday while my car is there for a reflash and have my alignment looked at.
If it is a TSB, it should be covered. I'll see what my service manager says when I drop my car off. I'm at least lucky enough to have 2 Mitsu dealerships near me that won't dick me around.
Quick Reply: Fuel pump relay safety: All new BLUE relay from Mitsu, updated info on page 4
