Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2009, 01:57 PM   #1
Personal Sales Rating: (0)
Drives: 2008 Evo X MR, 1999 E36 M3, 2006 Audi A6
Clunking sound from passenger side rear
Anyone else have this? Sound like metal-to-metal impact when I hit a bump, turn into a driveway, or in any way flex the suspension.
I've looked at everything that I can think of... battery is secure, seat belts aren't clanking, nothing loose in the trunk or spare area, nothing rattling around on the floor. I'm at my wits end--the next step is to jack the car up and see if there's anything loose underneath.
Given that it happens when loading the suspension from side-to-side, might it be a swaybar end link? (My E36 M3's swaybar end links clunk around, but that's because they are custom-fabricated Heim joints with very little play... can't imagine a stock suspension would make that kind of noise)
--michael
Offline
Old Jul 30, 2009, 02:30 PM   #2
gizmotoy's Avatar
Drives: 2008 WW Evo X, 2006 Civic Si
It's probably a loose end link. I had mine back into the dealership with only a few thousand miles on it for what sounds like exactly what you're describing. They said the nut looked like it wasn't torqued properly at the factory and backed out. They torqued it back up and I haven't had a problem since (13k miles now). At least one other person had the same problem.
You could probably tighten it up yourself if you can track down the right bolt.
Edit: Here's my original thread
Horrible Clunking Noise - 1600 miles
__________________
AMS Intake & Dual Exhaust, Buschur-tuned to 306whp: Dyno Results Thread
Offline
Old Jul 30, 2009, 04:01 PM   #3
Personal Sales Rating: (1)
jrsimon27's Avatar
Drives: Lancer Evolution X MR
i have the same cluncking noise they have re-tighten everything but it didnt help and yes i think its the swaybar...
__________________
STOCK EVO X MR WW
Offline
Old Jul 30, 2009, 04:38 PM   #4
I jacked the car up in the right rear, and put a socket on all of the sway bar carrier bolts and end links. None were loose...
I need to get the car aligned, so when I take it to my alignment guy, I'll have him check all bolts. Maybe he'll find something.
Offline
Old Aug 1, 2009, 04:31 PM   #5
Drives: EvoX Gsxr1K6 WR450
Perhaps you have a stone up in the springs?
Offline
Old Aug 1, 2009, 04:43 PM   #6
Personal Sales Rating: (2)
fuzzydoodle's Avatar
Drives: 95 TSi
Could be you're sway bar end links, most likely not, but could be.
More likely a strut coming loose, check your upper strut bolts in the trunk, sometimes those come loose, and when it flexes it makes a 'clunk'.
There should be 3 holding the strut plate to the fender well, probably under the carpet up by the top in the trunk, just look at the strut and follow it up, either those could be loose, or in the center there is a nut that holds the actual STRUT to the strut mount.
Most of the time, that just comes a little loose and the strut bangs around.
This is from 4 years experience at Les Schwab in the brake/shock/alignment dept.
Could also be a lower ball joint, most likely not, but not to rule out.
Like I said, 90% its those struts. I don't know exactly how yours mount so I can't give you exact locations on bolts but, just take a look, maybe even with the wheel off, and just double check everything. You will find it.
__________________
OG Mudbones #1 Fan
Offline
Old Aug 4, 2009, 09:50 AM   #7
Thanks for the info. I got the car aligned, and my mechanic found a couple of slightly loose bolts on the subframe, which were tightened up. Sway bar end links/brackets were fine.
However, the clunking is still there. I'd like to check the top of the struts/strut mounts. Do I do it from the underside, or do I pull the carpeting out of the trunk and access the top of the struts from there?
(PS: what a difference an alignment makes! The car was way off from factory, and it feels like a completely new car. Just did it to stock specs (no mods, stock suspension), but got it _exact_, and it just feels perfect.)
Offline
Old Aug 4, 2009, 10:12 AM   #8
Drives: WW Evo X MR
guys as soon as you jack the car up you cant look at the suspension being loose becasue all the wight from the tires and brakes( gravity ) takes care of it , so you have to look at it with a big flat screw driver or bar and check everything from the car wheels touching the ground ,
put it on blocks and then go underneth and look..
another idea
look at your spar tire and jack !!!! and see if there loose!!! it might be your jack jumping around every bump you hit lol
Offline
Old Aug 5, 2009, 01:32 PM   #9
I did check the strut bolts (from inside the trunk), and everything was good and tight.
Clunking is still there.
Interestingly enough, when I took out all of the trunk carpeting, I found a small oval-shaped piece of metal stuck in some glue on top of the right rear wheelwell. I was hoping that this was what was causing the noise, but even with it taken out, noise is still there. The more I look at it, and where it might have come from, I'm thinking that it was a metal frame casting piece that was "popped out" during body assembly and stuck on some glue. Weird.
Offline
Old Aug 5, 2009, 02:00 PM   #10
Codevo's Avatar
Drives: GG X
A thread should be posted and stickied titled "what noise does your evo x make?". Haha. I can't even begin to count how many people i have heard talk about unwanted and unexplained noises in their evo x.
__________________
evolutiondynamics built longblock • 5 angle valve job w/ported & polished head • Kelford 214-B's w/springs •
FPRed • GM 3 port solenoid • AMS FMIC • AMS intake • AMS UICP •
AMS LICP • UR o2/DP combo • DW 800cc • Walbro 255 • ACT 6-puck •
Megan Racing coilovers • Volk TE37 18x9.5 • 285/35/18 Ventus RS-2's •
Carbon Fiber. Lot's of Carbon Fiber.
Offline
Old Aug 5, 2009, 02:04 PM   #11
gizmotoy's Avatar
A bunch of dealerships around here have a little rumble-strip "obstacle course". If you can find something like that, throw a friend in the trunk and drive around. It might at least give you an idea of what direction to look.
__________________
Offline
Old Aug 5, 2009, 05:25 PM   #12
Personal Sales Rating: (4)
Drives: 2008 Evo X GSR
I'm having the same issue but I have aftermarket coilovers and rear swaybar so there's more to think about. It's progressively gotten worse over the last month or two. I guess I've been too lazy to get underneath the car. I'll probably check it out this weekend. I sure hope its a loose bolt/nut on the endlink or bracket.
__________________
Tuned by DG Motors 311whp/325wtq
Offline
Old Aug 5, 2009, 09:13 PM   #13
Drives: 08 Evo X Apex Silver
Oh crap, I just read this thread and I have the same sound. I've been too lazy to check because my friend borrowed all my jacks. I just broke out the hand crank jack and checked the endlink joints. Turns out my nut for the endlink fell off! I found a spare and tightened it back up. Cool!
Offline
Old Aug 5, 2009, 09:28 PM   #14
davidiii's Avatar
Drives: 08 EVO X GSR
Quote:
Picture of where your talking about?!?
__________________
2008 Mitsubishi Lancer EVO X GSR
AMSOIL IN MY VEINS
ETS CAI
Speed Circuit Hotpipe
AGP FMIC
Ultimate Racing Minimuffler TP
Buschur Racing Quiet Exhaust
ETS O2/Downpipe
343Whp 349Wtq by CBRD using Cobb AP
Rexpeed Polarized Mirrors
Titek CF Hood Scoop
Eibach Lowering Springs
Offline
Old Aug 6, 2009, 05:43 AM   #15
gizmotoy's Avatar
Yea, whoever they have tightening the end links should be fired There have been a ton of these. There's at least half a dozen others with similar loose endlink experiences over on the "other site." I'm glad I caught mine before the nut fell off
__________________
Offline
Tags
08, bar, car, clunk, clunking, coming, drive, lancer, metal, noise, passenger, rear, reverse, side, sound, suspension, sway, tightening
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
