Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 6, 2009, 08:26 AM   #16
Personal Sales Rating: (1)
Drives: 08 Evo X Apex Silver
Actually, this one's my fault. I installed an aftermarket swaybar. Guess, I'm fired.
Offline
Old Aug 6, 2009, 08:37 AM   #17
Quote:
Originally Posted by davidiii View Post
Picture of where your talking about?!?
Here's a pic of a Perrin swaybar. Just follow the red bar to the end. There's a nut that holds the bar to the endlink. Tighten that one.
Offline
Old Aug 6, 2009, 08:53 AM   #18
Personal Sales Rating: (0)
gizmotoy's Avatar
Drives: 2008 WW Evo X, 2006 Civic Si
Quote:
I quite literally laughed out loud. Glad you tracked it down
__________________
AMS Intake & Dual Exhaust, Buschur-tuned to 306whp: Dyno Results Thread
Offline
Old Aug 6, 2009, 11:31 AM   #19
jrsimon27's Avatar
Drives: Lancer Evolution X MR
i wish you could fine the cause of this problem i allready treid with mine and no luck please keep us updated...
__________________
STOCK EVO X MR WW
Offline
Old Aug 11, 2009, 12:26 PM   #20
Drives: 2008 Evo X MR, 1999 E36 M3, 2006 Audi A6
An update, and a question:
This has been driving me nuts. I've gone around the entire car, inside, outside, top, and bottom, and I can't find the source of the clunking.
It really only happens when there is some kind of side load, especially when turning left. Going down a bumpy road in a straight line does NOT make the clunk. Which leads me to believe something is "shifting" from side loads.
Question: I made sure that the spring spacers were removed, and they are. However, there is a piece of very flimsy black plastic tube around the shock/strut pistons in the front (yes, the front), maybe 1.5 inches long. Is this supposed to be there, or should that have been removed? Might that be the cause of the noise?
--michael
Offline
Old Aug 11, 2009, 12:43 PM   #21
gizmotoy's Avatar
From your description, it doesn't sound likely. If the tube is flimsy, how would it make a clunking sound? Clunking almost explicitly describes a metal-on-metal contact... you'd probably even describe metal-on-rubber as a thud. It doesn't seem to me that metal-on-flimsy plastic would make any discernible sound audible from the cabin.
If you take a picture of what you're talking about we can verify with our cars. I do seem to recall there was sensor wiring along that route, which may be what you're seeing.
__________________
Offline
Old Aug 19, 2009, 04:05 PM   #22
Another update:
Noise is still there. I've taken apart the entire trunk, nothing.
If I had to describe the noise, it may not be a metal-on-metal noise... maybe more of a "snapping". But, it's really hard to tell. I can reproduce it by doing any kind of turning, either left or right. And, now, it's starting to come from the driver side rear as well, and it's getting worse every day.
I have some new ideas:
1. Side skirts. I do NOT have the aero kit, just the stock sills. They snap onto the wheelwell in the rear with a little plastic clip. This clip comes loose with very little pressure. Could it be that side-to-side flex of the body is causing this skirt clip to snap off and then snap back?
2. Window bolt TSB. I read about that (need a higher-torque bolt somewhere in the door), but the TSB states that this only applies to cars built (edit: before!) January 2008. My Evo is a May 2008 build. I tried rolling the windows down, all the way, halfway, but that didn't change the sound.
Any other ideas? I think I'm just going to bite the bullet and take it into the dealer, and exercise my warranty. (I'm bone stock, no mods, so nothing to deny warranty)
--michael
Offline
Old Aug 19, 2009, 04:24 PM   #23
jrsimon27's Avatar
Quote:
Originally Posted by weneversleep View Post
Another update:
2. Window bolt TSB. I read about that (need a higher-torque bolt somewhere in the door), but the TSB states that this only applies to cars built after January 2008. My Evo is a May 2008 build. I tried rolling the windows down, all the way, halfway, but that didn't change the sound.
--michael
man i hope you find what it is cause iam on the same boat as you....
__________________
STOCK EVO X MR WW
Offline
Old Aug 19, 2009, 04:25 PM   #24
gizmotoy's Avatar
May comes after January...
__________________
Offline
Old Aug 19, 2009, 08:15 PM   #25
CatalystGod's Avatar
Drives: Evolution X GSR Graphite Gray
I think he meant it only happens on cars built BEFORE jan 08.
__________________
Keep yourself informed:
http://www.zeitgeistmovie.com
Offline
Old Aug 19, 2009, 09:07 PM   #26
Personal Sales Rating: (4)
Drives: 2008 Evo X GSR
I plan on crawling under the car tomorrow. The noise is really beginning to bother me. Had my suspension been stock I would have taken it to the stealership long ago. I'll post an update as well if I discover anything new or remedy the situation.
__________________
Tuned by DG Motors 311whp/325wtq
Offline
Old Aug 19, 2009, 10:15 PM   #27
Personal Sales Rating: (2)
cornercarver's Avatar
Drives: 09' Civic SI, Evo X, Mustang
Another update:
--michael
I think you are looking wayy to deep into it.... I just bought my X two days ago and it had this very same clunking noise. I just crawled underneath the car and checked the endlink bolt and sure enough, it was almost completely backed off.
You have to check the bolt when the suspension is loaded and the wheels are on the ground. The bolt will be tight when the car is jacked up.
Thanks for the help! I went and checked mine just minutes ago and found the bolt almost completely off. I just tightened it with a 14mm wrench....
Offline
Old Aug 20, 2009, 02:12 AM   #28
antzlim's Avatar
I had a same problem and my car has 1800 miles.
Just came back from dealer this mourning and found linkage on sway bar loose.
It's ok now but we'll see.
Offline
Old Aug 20, 2009, 09:12 AM   #29
Quote:
Durrr, yes, I meant to say:
Cars built before January 2008.
Thanks for the catch.
Offline
Old Aug 20, 2009, 09:43 PM   #30
Drives: EVO SST
Another update:
--michael
Bro, you are very determine to find the problem, really you can find the root cause of it... Becos, I am also hearing this strange nosie too.. I cannot really re-produce it.. i check the swaybar end link bolt... nothing, it is very tight!! So i rule out the swaybar end link... but i suspected it could be a brake pad issue... soemtime brake pad might be vibrating and touching the rotor... so it might be a good idea for you to clean your brake pad... and monitor for the noise...
Offline
Tags
08, bar, car, clunk, clunking, coming, drive, lancer, metal, noise, passenger, rear, reverse, side, sound, suspension, sway, tightening
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
