Apr 23, 2009, 08:18 AM
Personal Sales Rating: ( 20)
2008 Mitsubishi Lancer Evolution
Drives: PB Evo X
Evolution X helpful FAQ, TSBs, known issues, etc.
Generalized Evo X info
- Evolution X TSB / Recall Information
- Maintenance schedule, TSB, fluid specs, etc
- How does the Evo X compare to the Evo VIII and IX?
- What will the 2010 Evo have compared to the 2008?
- TPMS FAQ borrowed from the Lancer section
- Comprehensive list of differences between GSR and MR
Engine/turbo/driveline concerns
- Exhaust: black smoke
- Transmission shifting is notchy/grinding
- What does ASC do? ASC problems/ ASC light is on
- ASC Video Demonstration
- Evo X and RA SST Forum
Appearance/cosmetic concerns
- Paint is chipping in spots
- Seat fabric coming apart (Why do I see the staples in the seat?)
ECU concerns
- Limp mode
- Mitsubishi factory reflashes, hesitation, and stalling
Suspension/Brake concerns
- The Brake Rotor, Pad, Line, Fluid, and Duct Thread
- Spring Rate Chart for Evo X
Gold stars and kudos to all of you that helped Smike and I with the leg work and ideas we used to make this thread: Spy007, KGHtheII, gunzo, goofygrin, Blacksheepdj, dek0026, adambl03, mad VIII, jwoods986, ►EvolutionX◄, TTP Engineering, and RussellM.
Thanks a ton, guys!
We will add more as we are able.
Offline
Apr 28, 2009, 02:19 PM
Drives: PB Evo X
Streamlining sticks, added TSB link to clear clutter at top in X General.
Offline
Tags
10, brakes, engines, evo, evolution, evolutionnet, evox, faq, issues, maintanace, maintenance, problem, schedule, scheduled, tsb  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
