Daytime Running lights
Old Feb 10, 2008, 06:27 PM
mksevo's Avatar
does anyone know how to turn these things off. I am not a fan of DRL. my vette had a single fuse that would disable it. , I will dig thru the manual some more.
Old Feb 10, 2008, 06:41 PM
EvoM Administrator
Noize's Avatar
If you figure it out, let me know. I want them gone as well. It was a sub-menu in BMW, but I did not see it in the Evo submenu when I peeked at it.
That manual is a big sucker, huh?
Old Feb 10, 2008, 06:49 PM
mksevo's Avatar
ok, Just did it. if you want the walkthru go to the how to section but the down and dirty is grab your manual page 7-42 , go to the fuse box in the engine and pull fuse # 13. last one the bottom row 10 AMP. have fun going stealth.
Old Feb 10, 2008, 06:50 PM
EvoM Administrator
Noize's Avatar
Thanks man, that's awesome.
Old Feb 11, 2008, 11:07 AM
R0ME0's Avatar
is fuse #13 only for the DRL or something else also? This gives you full control of the lights after pulling this fuse?
Old Feb 11, 2008, 11:23 AM
Jake26's Avatar
whats strange about these is that i own a 2008 lancer gts. mine didnt come with fuse 13, and some lancers did. My lancer is wired as a "CAN" drive circuit. I recently installed a HID kit, cousing my lights to stay on constant, i really dont think there is a way to disable them yet. Unless you have fuse number 13 and your car wasnt wired in a CAN drive circuit. Even when my car is off it shoots out 12v constant. had me and my installed puzzled...
Old Feb 11, 2008, 05:03 PM
mksevo's Avatar
this only controls the DRL in you have th HID setup. it may be different if you have standard lighs or NON EVO.
Old Feb 24, 2008, 04:29 PM
WarmPepsi's Avatar
do you figure CAN is for CANADA? (where drl's are required)
Just a thought. dunno.
Old Feb 24, 2008, 07:35 PM
mksevo's Avatar
why cant you just pull the low beam bulbs if you install HID, are these highbeam only not both LOW and HIGH>.
Old Aug 2, 2008, 04:30 PM
itznoraa's Avatar
ok i just pulled fuse 13 from the engine fuse box.....
WTF i still get DRLs!!!!
someone pm to help me!
Old Aug 2, 2008, 06:20 PM
628's Avatar
There's another thread on this, and from what I can remember, pulling fuse 13 will only affect projector housings, not the reflector housings.
Old Aug 2, 2008, 07:06 PM
kart125's Avatar
Pulling the light bulb seems the best way to get rid of DRL's. I did it on my Turbo X to get the "light bar" on by itself (see pictures) because in Canada DRL's are mandatory and were always on. Only downside is a message on the information panel "DRL fault left and right bulb". I don't know if the Evo is "smart" enough to detect that the bulb is out. Try it anyways... it takes 2 minutes.
Old Aug 2, 2008, 11:46 PM
itznoraa's Avatar
ah so what you are saying is that for the models with projectors in them, pulling fuse 13 works.
my DRLs and headlights are the same bulb...so pulling them means i have no headlights
Old Aug 3, 2008, 03:30 AM
Slimdatwelve209's Avatar
still wouldnt matter if you have the base evo X pullin the fuse wont make the drl go away i believe it only work with SSS evo x that has the stock HID
Old Aug 3, 2008, 07:34 AM
kilgoja's Avatar
i never understood the point of drl...they are annoying to me...actually can make it harder to see an oncoming car cuz of the brightness if they are aimed wrong...i mean it just doesn't make sense...cant u see the car fine without them?...as far as foggy or rainy weather...just turn ur lights on...common sense...glad my ix doesn't have drl
Quick Reply: Daytime Running lights
