Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Jun 23, 2011, 01:17 PM   #1
Personal Sales Rating: (1)
Garage is empty, add now
twinturbogreg's Avatar
Drives: 2010 Evo X
Transfer Case ACD Bleeding
Is there any way to power up the ACD pump to bleed the system? I have called 3 dealers to do this for me and have gotten 3 differant answers. One said I don't have to bleed it, One said $150, and the other said $325. Do we have any Mitsu Techs on here to check into this for me?? Any help would be great! Thanks guys
Offline
Old Jun 23, 2011, 01:33 PM   #2
Personal Sales Rating: (7)
razorlab's Avatar
Drives: a laptop connected to your ECU.
Key on/off with gas pedal to the floor, repeat, bleeds itself.
Quote:
Originally Posted by n03lsevo View Post
I know this has been talked about before, but if you can't find it here's the fast way of bleeding the ACD without going to the dealer:
Tools:
10mm wrench or socket
vacum hose
ACD fluid
how to:
this is a 2 man job, someone to turn the key to the on position and step on the gas pedal until the pump comes on and anther to loosen the 10mm bleed bolt on the TCase(bottom).
1. have a guy under the car ready on the bleed bolt with vacum hose on it diverting to a cup or bottle for excess acd fluid.
2. turn the key to on position, without starting, as soon as you turn the key, press on the gas peddle to the ground and notify your buddy under the car that its on.
3. the acd pump will come on and open the bleeder right away to let out air or fluid. Close bleeder when pump stops pumping usually after 3-5 seconds.
4. repeat 5-6 times.
good luck
__________________
Bryan
2005 5spd MR - E85 powered
2014 5spd Evo GSR - E85 powered
Offline
Old Jun 23, 2011, 06:55 PM   #3
Drives: 2010 Evo X
Quote:
So do I have to have someone loosin the bleed valve on the T-case while I do this?
Offline
Old Jun 23, 2011, 07:54 PM   #4
ob5
Personal Sales Rating: (0)
Drives: Lancer Evolution 8 gsr
Yes
Offline
Old Jun 23, 2011, 08:25 PM   #5
razorlab's Avatar
Quote:
Read what I quoted.
__________________
Bryan
Offline
Old Jun 24, 2011, 05:58 AM   #6
Drives: 2010 Evo X
Ahhh My Bad! haha Thanks!
Read what I quoted.
Offline
Old Jun 24, 2011, 11:29 AM   #7
Personal Sales Rating: (2)
2008 Mitsubishi Lancer Evolution
AWDTerror's Avatar
Drives: 2008 RR Evo X
AWDTerror
Why do you need to bleed it may I ask?
Offline
Old Jun 24, 2011, 01:35 PM   #8
Drives: 2010 Evo X
I put a new transfer case in the car. Factory over fill of fluid killed it
Quote:
Offline
Old Jun 29, 2011, 06:39 AM   #9
Drives: 2010 Evo X
Can I ask where you got this info?
Offline
Old Jul 1, 2011, 05:42 AM   #10
Personal Sales Rating: (13)
black95tt's Avatar
^ That's how it is on the Evo IX's, I can confirm because I did it that way when I bled my transfer case after replacing the ACD unit.. I'm not sure if that same trick works on the X's. Have you tried it yet?
__________________
Phantom Black Evo X GSR
(SOLD) 06 GG MR
Offline
Old Jul 1, 2011, 08:58 AM   #11
Drives: 2010 Evo X
I tried everything to get the get the pump to turn on and got nothing Anyone else have any idea's?
Quote:
Offline
Old Jul 6, 2011, 06:16 PM   #12
Evo-B's Avatar
Drives: '05 EVO VIII
Send a message via Yahoo to Evo-B Send a message via Skype™ to Evo-B
So overfilling the reservoir can lead to ACD problems? Reason why I ask is I just did the clutch on my EVO and we removed the ACD line buy the tcase bolt. I thought you could just fill it up and it would be good to go. I now have all ACD lights on and the reservoir is about a half inch above the max line. I am gonna try and bleed it this way this weekend but until then any body know of any other issues with the ACD that happens after a clutch install?
__________________
I CALL THE BIG ONE BITEY
Offline
Old Jul 7, 2011, 10:51 AM   #13
Emerging Sponsor
Personal Sales Rating: (56)
sr20det91's Avatar
Drives: 2005 WW Evo 8 - 2014 F-150 twin turbo
jason.coche @PenyRoyal
Should be key to ACC position then throttle to the floor. Some people say they have to cycle the steering wheel back and forth, but I've never had to do it.
Also I've never heard of an overfilled TC causing failure. Not saying that its not possible,just counter intuitive. Seems like it woould be hard to overfill anyway due to the fact it comes gushing out the fill plug when its at it proper level.
Offline
Old Jul 7, 2011, 10:54 AM   #14
Emerging Sponsor
sr20det91's Avatar
You definitly need to bleed your ACD system ASAP. You could possibly burn the pump up otherwise.
Offline
Old Jul 7, 2011, 08:15 PM   #15
Drives: 2010 Evo X
People keep chiming in with Evo 8's and 9's.... This thread is about the EVO X. The ACC and throttle to the floor does not work on the Evo X like I said above.
Also it's been documented that there have been many T-case failures from overfill. Again for the Evo X.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
9, acd, bleed, bleeder, bleeding, case, change, clutch, evo, evolution, faail, pump, transfer, turbo, valve, wreck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
