Help me
Old Sep 17, 2013, 03:32 PM
eviltwins's Avatar
Help me
I just bought a 2010 EVO X want to upgrade the turbo don't know much about these cars can you please help me with choosing a turbo i want to make around 500 to all 4 wheels I'm going to build up the motor and getting suspension
Old Sep 17, 2013, 04:24 PM
2.0T Mirabeau's Avatar
FP Black should do that easy but you should really be building the block
Old Sep 20, 2013, 09:57 AM
ETS Michael's Avatar
A black can make the power at decent boost. We have another option using a T3 turbo kit. A GTX3076R will spool up faster and make the same power on pump gas. We also have larger T3 options like a GTX35R, HTA35R, etc. One of the key benefits will in a T3 will be the extra top end power. Most of the stock frame turbochargers make peak power and taper down towards red line where the T3 variants pull all the way to red line.
http://www.extremeturbosystems.com/E...Turbo-Kit.html
If you decide to go to the turbo kit route and need help, let me know!
Michael
Old Oct 4, 2013, 10:19 PM
EVOXTIMES's Avatar
So you going for a turbo upgrade right out of the gate?
Old Oct 6, 2013, 03:07 PM
IRPerformance's Avatar
Sure why not? Whenever I started small on any build, I always wanted bigger later down the road. A 3076 would be better in my opinion for the 500 awhp goal. If you plan to run 22-25lbs consistently, go with the GTX version. The high pressure ratio of that wheel is more suited to higher boost and will make more power. Like Michael said, the stock frame turbos will tend to drop power towards redline. If you think you will ever want to get closer to the 600 awhp mark, I woud go with a 3576 or 3582. I wouldn't try it on a stock motor though.
marceloevo
Oct 3, 2013 08:30 AM
Silver_Hawk09
Lancer Aftermarket Forced Induction Tech
19
Jun 13, 2010 06:11 PM
4mywifeandkids
24
May 6, 2009 11:34 AM
alexyim
Jul 1, 2005 04:52 PM
oz dan
Oct 1, 2003 10:30 AM
Quick Reply: Help me
