Boost Leak test AND valve overlap
H Guys,
Just trying todo a boost leak test, but at about 1bar the 'boost is leaking in the engine' lol... and my little compressor wont push psat 1bar
does anyone know what degrees i need to be at so all the valves are closed?
How can I tell without taking the cam cover off?
Cheers
D.
Cheers
D.
i made a little rubber coupler that goes right on the turbo with a end cap/valve stem on the other side. pvc primed and glued everything and use the stock clamp to secure it. holds 30+ psi, but pressure still bleeds from the boost control silenoid...unless you plug it
Cylinder 1 is about to combust (intake valve closed)
Cylinder 2 is about to exhaust (intake valve closed)
Cylinder 3 is about to compress (intake valve about to close)
Cylinder 4 is about to intake (intake valve about to open)
It's hard to say what degree exactly since you have to know the exact cam opening/closing degrees, take in consideration the valve clearance, etc. But by knowing the sequence above, it should be a few degrees after top dead center right when cylinder #3 intake valve is closed. If you go too far ATDC cylinder #4 intake valve will open.
Place the engine in TDC (be sure it's TDC cylinder #1 and not #4 ), apply the compressed air into the intake and rotate the crank clockwise until the leak stops.
But know that I think of it, I wasn't thinking about overlap which occurs between the end of the exhaust stoke and the begining of the intake stroke. This maybe a little harder than the easy thinking above
Easy way, just keep rotating the crank until the leak stop
When #1 is at TDC #4 should be in the middle of overlap. If you keep rotating the crank clockwise overlap will end and #4 intake valve will open further but at the same time the #4 exhaust valve will fully close. So as long as your cylinder isn't leaking, you should still have a good seal even with the intake open. So this means it should still be some degees ATDC when #4 overlap ends
