Jan 30, 2010, 11:08 AM
Personal Sales Rating: ( 4)
Drives: 2008 PB evo X
HELP! I threw a CEL
HELP!!! Just did a little snow drift and all of a sudden threw a CEL. Now the car when I start it idles at 2000rpm and gradually goes up to 2500rpm. I did a reset and still the same thing it won't come down from this high idle. My mods are Nisei upper and lower ICP's, HKS air filter, Greddy DP non open mouth, and HKS Hi-power exhaust. Any help would be greatly appreciated.
Offline
Jan 30, 2010, 11:09 AM
Personal Sales Rating: ( 1)
Drives: 1997 GSX
Check out everything under the hood? sensors still connected, vac hoses etc?
Offline
Jan 30, 2010, 11:10 AM
Personal Sales Rating: ( 0)
Drives: 2003 RR EVO, 2005 CBR 1000rr, 2006 Passat 2.0T, 1990 International P-1000
Turn off the car and turn it back on. It will reset by itself.
Take it to someone who has an OBDII CAN reader.
__________________
Evo Green w/upgraded WGA 18psi
Helix O2 Housing
Helix Downpipe
Perrin Test Pipe
HKS Hi-Power Exhaust
AEM ShortRam Intake
Ported/Polished/Coated stock manifold
Ported turbine housing
HKS 280 intake/exhaust
Vishnu cam gears -3/-3
GM 3 port solenoid
Turbohoses Intercooler/UICP
ETS version 2 LICP
ACT HDSS Clutch
ACT Streetlight Flywheel
Walbro 255lph
RC 1200cc injectors
Sun Hyperforce
Mil Spec 65mm Throttle Body
Zeitronix ZT-2 LCD & ZAVT-1
400awhp on E85
Offline
Jan 30, 2010, 11:11 AM
Drives: 03 TB GSR
One of your vaccum lines could've popped off I would check those, also are you running a testpipe and no cel fix?
__________________
""Were not meant to enter the grave in a well preserved body but rather skidn in sideways totally worn out shoutn "holy **** what a ride".""
Offline
Jan 30, 2010, 11:25 AM
Personal Sales Rating: ( 3)
Drives: An AWD Buick LeSabre
How do you NOT have a like a 50 dollar OBD-II reader? Really? I mean, really really?
__________________
2008 Evo X. GSR. RR.
Invidia N1 CatBack
Buschur Test Pipe/UICP/LICP/Intake/FMIC
AEM Methanol Injection
Rally Innovations Light Plate
Swift Sport Springs
Whiteline RCA/RSB
Rota: 18x9.5 Grids
Applied Tuning Solutions- 330WHP/350WHTQ
Offline
Jan 30, 2010, 11:28 AM
Quote:
 I know I'm working on getting one right now. No I don't have a test pipe at all
Offline
Jan 30, 2010, 11:46 AM
I have this line disconnected, but I can't remember if this is disconnected because of the Nisei intake tube?. Was awhile ago I did this mod. Any idea on this line?
Offline
Jan 30, 2010, 12:03 PM
Personal Sales Rating: ( 5)
Turning off the car doesn't reset a CEL. Get an OBD-II scanner and pull the code. How can we help you if we don't have the code? It could be anything.
Offline
Jan 30, 2010, 12:18 PM
Have you gotten tuned yet? And if not... why not? I mean, besides the "safety" aspect of it, you'd get a gigantic boost in power with a tune. You're running a lot of fairly expensive mods.
__________________
Invidia N1 CatBack
Swift Sport Springs
Whiteline RCA/RSB
Rota: 18x9.5 Grids
Offline
Jan 30, 2010, 12:30 PM
I disconnected the battery to reset the ECU for a half hour. I will try to get the code when I can borrow an OBD II reader from my father in an hour, just wanted to see if there was any others that have experienced this. As far as a tune goes I wanted to get another UICP, FMIC and a test pipe and then I was going to get a tune. I guess there is no short cuts, I just wanted to do the tune once and have it last awhile. I guess I will post back in a hour or two when I get the code. Thanks for the replies.
Offline
Jan 30, 2010, 12:41 PM
Quote:
I think that should go back into the inlet pipe. Idk it's pretty close up.  So yeah possible vacuum leak, but not enough to cause a 2000 idle.
Offline
Jan 30, 2010, 09:39 PM
Drives: Evolution X
bad maf ?
Offline
Jan 31, 2010, 09:14 AM
Drives: 09 Ob Evo X 05 Cooper S
I see you are from Canada also. What was the outside temperature when you drift your car. The cold weather probably yield a couple more psi of boost versus your normal tune and in return your car might have exceed the torque table values.
That happened to me even on a near stock tune. Lately with the outside temp. being in the -15C/-20C depending where you are located your car might have overboosted.
Offline
Tags
cel, check, evo, evolution, fix, location, nysecel, obd, obd2, pipe, plugged, scanner, stopped, test, working  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
