new intercooler problems
Well i need help and im new to this stuff. I have a x with a catback and a access port i just installed a ETS 4" intercooler and everything is extreamly tight i made sure of that but now my idol is very low at start up drobing to 500 rpm or a little lower and when it does this it throws these codes and goes into some kind of limp mode
p1238 MAF plausibility
p0122 throttle position sensor/switch a circut low input
p1233 throtle pos. sensor(main) plausibility
p1241 torque monitor
p1235 Maf sensor plausibility
If i keep the rmp up to say 1000 for a minute or 2 when i let it idol down it stays in its normal range and seems to run fine. If anyone has any ideas or has run into this some help would be great. Is this a symptom of a boost leak?
