Nov 7, 2009, 05:35 PM
Personal Sales Rating: ( 1)
Cast iron > aluminum for boost anyway... why would you want to swap out one of the best 4 cycle engines ever? It would be like taking out a supra motor and putting in a an aluminum bmw inline 6. Its just a down grade lol.
Offline
Nov 7, 2009, 05:45 PM
Personal Sales Rating: ( 0)
Drives: jdm civic 07, mazda astina 96, toyota prado 97, nissan grand livina 09...soon to be evo
i also have this in mind
how would it feel with the 4B11 engine in an evo 9
Offline
Nov 7, 2009, 06:03 PM
does anyone know how much lighter the 4b11t is compaired to the 4g63..... Id bet if its significantly lighter the evo9 with a 4b11t would have better weight distribution.
Offline
Nov 7, 2009, 06:20 PM
Quote:
Its a decent amount lighter i would think. But If your going to do a swap thats going to take alot of fabing to make it work why use a 4b11t? Put in a supra motor or try and cram in a ls1/ls7. that would be worth all that time and work.
All your going to get by putting in a 4b11t is a motor that wont make as much power as your original motor. Yeah it will be lighter but you could just take out your spare jack and back seats and it would be close. I would rather take out my spare and jack and seats alot less work  .
Offline
Nov 7, 2009, 06:31 PM
weight distribution is key on the track (road course) the evo9 is a little front heavy a lighter moter would help that out.
Offline
Nov 7, 2009, 10:11 PM
Drives: E36 BMW, 64 VW bug, 68 Baja with EvoX motor, 67 5/1600
The 4b11t is 27 pounds lighter. the fab work involved would add weight yes, but you also need to cut out the mounts and what not for the stock motor so you would be close.
it would just be fun id say. but what are you talking about less power? stock for stock the 4b has better numbers. now yea for sure there's an infinite amount of mods for the 4g but in time the 4b is going to ave the same...though your right about the cast vs aluminum..but i dont think he will be boosting 35 PSI...
I got a 4b complete id be willing to trade for! lol i dont want to deal with the harness on it...
Offline
Nov 8, 2009, 08:43 AM
By less power i should of said less power potential. the 4g63 is one of the few 4 cylinders to go over 1100 to the wheels. Until the 4b11t hits that number it's a down grade. And a 27lb weight difference wouldn't even be noticeable.
And again with all the fab work that would need to be done why not put in a ls1 or supra motor? that would be a real upgrade  .
Offline
Nov 8, 2009, 08:59 AM
4B11T has proven togo over 750whp with a moderate size of mod lists, 1100whp will not be too far. HP can be gained easier with the 4B11T, with the weight of an evo IX and power of a X it would be great, thats if the costs for these are low, otherwise it may be cheaper to mod your IX furthur or get an X.
__________________
FS: HKS Legamax
Offline
Nov 8, 2009, 06:33 PM
Drives: 2010 PB Evo X GSR sss
Sounds interesting, but all that work for only 27lbs savings seems like too much for my tastes.
Offline
Nov 8, 2009, 08:02 PM
Drives: 2006 Yamaha R6, 2008 Evo MR, 2007 Twin Turbo Z06
:P I may be a bit one sided but I would say put a LS7 in and twin turbo it  ... Im running 10psi on my TT LS7 and its making a bit over 800hp :P and almost 500lbs/tq @3,500rpm at the wheel ahah now imagine that in a Evo.. Although my Z06 is only 3,200lbs...
Offline
Nov 8, 2009, 08:42 PM
Drives: evo 9 gsr,2008 vw jetta gli
nice proyect , that engine revs anad maintain torque nicely , and in low weight evo 9 could be a monster car, but as my view you may have to deal with room space on the tunnel to pass the exhaust is gonna be a little difficult (between the transfer and the tunnel) also the heat on the rear may have some issues with acd pump.
good luck
Offline
Nov 8, 2009, 08:44 PM
suscribed
Offline
Nov 11, 2009, 12:22 AM
Drives: 95 Talon TSi,06 EVO IX,04 350Z TT
Evo
I don't think is worth the hassle.Just get a Evo X.
Offline
Nov 11, 2009, 04:25 PM
Drives: O B evoX gsr
if you have it, just do it!
and let us know how it goes.
Offline
Nov 15, 2009, 11:03 PM
Drives: 2003 STi Spec C
i think the motor be more efficient in the car, not on it.
Offline
Tags
4b11, 4b11t, acd, drive, evo, gt2835, potential, pump, swap, trian, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
