Nov 5, 2009, 10:59 PM
Personal Sales Rating: ( 0)
Drives: 08 RR X GSR
Hmmm, was going to order the blaqops one, but now i have a decision to be made...hmmm.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Nov 5, 2009, 11:04 PM
The Blaqops control is "progressive" which means the second pump gets steadily increased voltage from the control box based on MAF signal. It sounds like the Buschur controller turns the second pump full on or off based on a boost trigger.
Offline
Nov 6, 2009, 07:04 AM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
Quote:
I think both methods will work fine as long as they are consistant so that tuning the crossover range in open loop will be predictable.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Nov 6, 2009, 07:53 AM
Personal Sales Rating: ( 44)
I don't know what Walbro says about the socks but I can tell you there are thousands of these pumps/socks being used with E85 at this point with zero problems. No fear of the sock being a problem. If you get right down to it, Walbro doesn't suggest their pumps be used with E85 either.
The double pumper is activated by a 6 psi pressure switch. Same one used in the hundreds and hundreds of EVO8-9 kits we've built. You'll have no problems tuning it.
Tephra is the person who will come up with the dual map switching and I'd guess Jack-of-trades will come up with the switch kits if and when it happens. That is outside of my development work.
Offline
Nov 6, 2009, 08:20 AM
Personal Sales Rating: ( 1)
Drives: 2008 Evo X
Looking forward to seeing your head release too.
Oh my, that sounds filthy.
__________________
2008 Evo X GSR. Rally Red.
Buschur UICP/LICP
Buschur Intake/MAF Pipe/Shield
Buschur Cat Back Bullet
Buschur Test Pipe
Buschur Shifter Bushings
Buschur Evo X FMIC
Offline
Nov 6, 2009, 09:59 AM
Personal Sales Rating: ( 18)
Drives: TB Evo IX
Great addition to the X lineup. Will be needing a few of these down the road.
__________________
JMS Racing Black Mamba Evo IX JMS Built, J-tuned
Best Pass: 10.01 @ 147mph..1.78 60' (Q16, QTP's)
Offline
Nov 7, 2009, 06:28 PM
Fuel Line Issues!
Quote:
David Buschur - I don't know what Walbro says about the socks but I can tell you there are thousands of these pumps/socks being used with E85 at this point with zero problems. No fear of the sock being a problem. If you get right down to it, Walbro doesn't suggest their pumps be used with E85 either.
You might want to re-think how you are approaching the development of your double pump fuel system after looking at this link below.
http://www.socalevo.net/index.php?op...&topic=85410.0
Best of Luck with your new Double Pump System!
Bob
Online
Nov 7, 2009, 07:59 PM
Your link has nothing to do with the components we are using, the Walbro pump itself or any issues from any of our products.
No luck required for us.
Offline
Nov 7, 2009, 11:05 PM
Thank You
Quote:
David Buschur - Your link has nothing to do with the components we are using, the Walbro pump itself or any issues from any of our products.
Glad to hear that your Double Pumper system for the EVO X has addressed all the problems that the EVO X had, in the LINK above (Post #22), when using E-85 over a longer period of time.
The EVO Community will again benefit from your thorough development efforts! Thank You
Bob -
Online
Nov 11, 2009, 06:47 PM
Drives: RR X GSR with my Wingman FHP
Congrats on finishing the Double Pumper
Just need it in my X now
__________________
Jestr Tuning
Buschur Racing - Military Veteran Owned and Operated
Offline
Tags
ams, back, buschur, double, e85, evo, exhaust, fuel, pumper, pumpers, racing, system, tank, turbo, work  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
