Oct 30, 2009, 01:42 PM
Personal Sales Rating: ( 0)
Drives: WW Evo X MR
? pulley ? did anyone get it ?
wondering if its worth the 125 $ getting the pulley ??
if i need another tune or not ...... bla bla ... anything about it would be nice i looked everywere with no luck !
thnaks
Offline
Nov 1, 2009, 09:00 PM
Personal Sales Rating: ( 2)
Drives: 2010 Evo MR Touring
I'd say skip this one.
Offline
Nov 1, 2009, 09:06 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
Stay away from any crank pulleys that don't have an harmonic dampener.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Nov 1, 2009, 09:20 PM
Drives: 2008 RR Evo X
Quote:
Supposedly the 4b11t was balanced to eliminate the need for balance shafts so in theory it SHOULD be ok....but don't look for me for testing that theory.
Offline
Nov 1, 2009, 10:32 PM
Drives: X GSR
from what i've heard i'd pass
Offline
Nov 2, 2009, 04:02 AM
Drives: WW Evo X MR
anyone has it on ..?? lol
Offline
Nov 3, 2009, 08:26 AM
Drives: RR EVO X GSR
I would never consider one for this reason ^^^.
The gain is non-existent and the stress it puts on your engine is certainly not worth it.
__________________
Rally Red Evo X GSR
-Speed Circuit UICP-K&N Drop In-Waste Gate mod,2 turns-TWM Short Shifter with 400gram knob-Custom fabbed boost gauge in ashtray-Rally Armour UR Mudflaps-COBB AP, COBB Turbo Inlet Hose-Rexpeed CF HoodScoop, Vortex Generator-UR HFC, 4.5"intercooler, dual exit catback-Swift Springs-Perrin Rear Swaybar-Enkei RPF1s 18x9.5 Black- APR Front Splitter-
Offline
Nov 3, 2009, 08:34 AM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
The proper name for the part is HARMONIC DAMPNER as in, it dampens the engine harmonics to keep your engine bearings from getting destroyed.
An aluminum crank pulley is NOT a HARMONIC DAMPER and leaves nothing to dampen the twisting and flexing of the crank.
Crank pulleys are NEVER a good idea. FLUIDAMPR is an option for a HIGH PERFORMANCE harmonic damper, self leveling and balancing that will soak up the engine harmonics.
We use one on our 763whp Evo VIII. I am not sure if they make one for the X though.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Nov 3, 2009, 10:35 AM
Drives: OB 08 Lancer Evo X
Quote:
Absolutely not, and x2 to the first 2 comments.  The crankshaft harmonic damper NEEDS to be there because there is absolutely nothing else present to dampen the 2nd order harmonics of the rotating assembly of your 4B11. Given enough power, you can literally shatter a crankshaft without a damper in place. That's worst case of course, but as TTP said above, not having a harmonic damper will absolutely wreak havoc on your main and thrust bearings. This is one of those mods that is NEVER worth it, so just put it out of your mind  the 1-2 WHP you might gain from losing a couple of lb's in rotating mass is not worth the extra long-term wear on your crankshaft and bearings.
Offline
Nov 3, 2009, 10:42 AM
Personal Sales Rating: ( 3)
Drives: 2008 WW X
Screw the pulley, stay away from Ebay.
__________________
Wicked White Evo X
Perrin Stealth Catback Exhaust
AMS Upper and Lower Intercooler Pipe
AMS Front Mount Intercooler
AMS Short Ram Intake
AMS O2 Eliminator / Downpipe
AMS Testpipe
AMS CEL Delete
Forge MBC
Goodridge Stainless Steel Brake Lines
Jestr Tuned 371hp/ 372tq
Offline
Nov 3, 2009, 02:51 PM
Drives: WW Evo X MR
hahaha keep going .!!!
Offline
Nov 10, 2009, 07:17 PM
Drives: WW Evo X MR
anyone else ...\>??
Offline
Nov 10, 2009, 11:57 PM
4-Cylinder Motors inherently Vibrate Harmonically!
Yes, Mitsubishi was most likely able to balance the 4b11t with the Harmonic Balancer. It is impossible to take the Distructive "Harmonics" out of a 4 cylinder motor with out using some sort of external balance system! ( Like Balance Shafts and/or Harmonic Balancer ) There is a natural physical and Distructive dynamic occurring in the Motor because of being a 4 cylinder Motor.
Bob -
Offline
Nov 11, 2009, 12:21 AM
Drives: 07 STi(sold), Evo IX, Altima 3.5
I know my post doesn't concern 4b11's but with my experience with crank pulleys in the past is that they are a waste of money and like said above not worth the increased stress. Nissan guy's swear buy them but I did this on mine and I switched back to the stock one in less than two days. All the noises and weird vibrations I got was enough to make my decision.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
