Oct 25, 2009, 08:40 AM
Personal Sales Rating: ( 1)
Drives: 2008 WW Evo X GSR
3582 twin scroll problems
Ok, I got my kit that was started by jms in san antonio finished up by evolution dynamics in Dallas and everything felt pretty good and only got stronger during the drive home. By the time I got back to Abilene, the car felt amazing. Started it up today to test it out again farred's stage2 cobb tune stock turbo setup. Everytime we do a pull, it cuts out and I get codes. Here they are.
0123 Throttle Position Sensor (Main) Circuit High Input
1233 Throttle Position Sensor (Main) Plausibility
1235 MAF Plausibility
0139 Heated Oxygen Sensor (Rear) Circuit Slow Response
We went under the hood and found that there was only one wastegate hooked up and the one that wasn't hooked up had to be reinstalled correctly as the vac port was on the upper part as opposed to the lower. We gapped the plugs to .020 and made sure everything was good to go and retuned. The car was amazing at this point and I was becoming at ease, but only 4 starts later, it's done it again. Same codes, and limp mode. At this point I have no clue what it is.
We have to run 27psi on the car b/c the springs in the wastegates are too stiff.
I'm clueless at this point. What is wrong?
__________________
Ecuflash (evolution dynamics)
ETS HTA GT3582R Twin Scroll
ETS Turbo Intake
ETS 4" Intercooler & Piping
Twin 38mm Mini Wastegates
Deatschwerks 1000cc Injectors
Walbro 255lph Fuel Pump (UR Install Kit)
ACT TTP Clutch w/ AMS MC Upgrade
Buschur Racing Catback
AMS Testpipe
Forge Front Lower Motor Mount
Perrin EBCS
AMI Dual Gauge A-Pillar
AEM UEGO and Boost Gauge
Perrin 2" Shorty Antenna
Offline
Oct 26, 2009, 12:52 AM
Personal Sales Rating: ( 0)
Drives: PB EVO X
I wish i could help.. I got tuned today and was tripping the throttle codes and the tuner added extra settings into ecuflash i believe that can turn off those codes. problem fixed afterward.
the last two i think are directly related together, i remember having those codes before. My maf went out shortly after, but i'm not expert.
Offline
Oct 26, 2009, 04:19 AM
Drives: evo x ,92 talon tsi , 88 starion esir
i had the same codes after i instyalled cams and turbo
its in the tune
you need to go back to your tunner
__________________
current mods
fp red
cosworth mx1 cams and springs
dw 800 cc injectors
aqumist hsf1
apexi avcr
wb 255 fp with ur install kit
ur turbo back exhaust
perrin front mount
turbo trix hard pipes
exedy twin disc
hood dampers
perrin 3" antena
twm short shifter and bushings
blox front engine mount
t1r shift boot
blox neo shift knob
mase tunned 430/377 at 24 psi
near future mods are
atp down pipe with tial 44mm wg
bc coilovers
fenders rolled
volks bronze ce28
Offline
Oct 26, 2009, 04:20 AM
I had the same codes after i instyalled cams and turbo
its in the tune
you need to go back to your tunner and hope you had better luck than i did
sry for the double post
__________________
current mods
fp red
dw 800 cc injectors
aqumist hsf1
apexi avcr
perrin front mount
exedy twin disc
hood dampers
perrin 3" antena
t1r shift boot
blox neo shift knob
bc coilovers
fenders rolled
volks bronze ce28
Offline
Oct 26, 2009, 04:24 AM
So, just adjust the air check tables and torque limit tables? Then, if we can't get it where we want it, just disable it all together? I wonder which one of the two tables is causing the problems.
__________________
ETS Turbo Intake
AMS Testpipe
Perrin EBCS
Offline
Oct 26, 2009, 07:06 AM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Oct 26, 2009, 09:46 AM
Personal Sales Rating: ( 40)
Drives: Operation Damaged Goods - 03 Yellow Evo
Jeremy -
Let us know if the DTC Disable codes work.
Thanks,
Michael
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Oct 26, 2009, 03:19 PM
Quote:
Originally Posted by tephra
I did. That's why I posted up in there, but I'm a noob in that thread and have no idea how to do any of that. Which is why I asked if there was anyone that could explain with pics perhaps or possibly even get on skype and do a sharescrean. Something to teach me. My tuner knows how to do it, but wanted to tune it out if possible.
__________________
ETS Turbo Intake
AMS Testpipe
Perrin EBCS
Offline
Oct 26, 2009, 04:04 PM
Drives: WW EvoX GSR
Use the "mode23 illustrated" thread as a guide, instead of copying the mode23 xml in, you copy the dtc xml in..
exact same process
__________________
Offline
Oct 26, 2009, 04:16 PM
exact same process
Thanks for the help. I'll check that out now.  Sorry for all the newbness. I just want to learn everything I can. I wish there were a handbook/textbook to teach me everything. I don't even want to learn it to make money off of others, I just want it to be able to be happy with the car. It's been a pain in my ass lately since I've been getting so many limp modes, lol.
__________________
ETS Turbo Intake
AMS Testpipe
Perrin EBCS
Offline
Oct 29, 2009, 02:12 PM
Personal Sales Rating: ( 6)
Drives: 06 Evo IX Apexi Silver ; 08 Black Honda Civic EX
need the same info! have all the codes that u do.. still stock turbo..
rom id 53050009
Thanks!
Offline
Oct 29, 2009, 02:42 PM
We raised the limitters and it's only popping the codes every once in a while. If it pisses me off again I'll go ahead and load the new map I have that is supposed to have the dtc's partially disabled.
__________________
ETS Turbo Intake
AMS Testpipe
Perrin EBCS
Offline
Tags
3582, 53050009, ets, evo, hta, id, kit, rom, scroll, turbo, twin  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
