Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 24, 2009, 11:55 PM   #1
.MM
Personal Sales Rating: (1)
.MM's Avatar
Drives: 08 OB EVO X GSR SSS AERO
Exedy Twin HD + AMS clutch master ring + AMS clutch line. I NEED HELP!! PROBLEMS!!!
delete
converting to evo 9
__________________
2008 Octane Blue EVO X GSR w/SSS and AERO
Offline
Old Oct 25, 2009, 01:38 AM   #2
finnns2000's Avatar
Drives: CZ4A
Quote:
Checked it out and the clutch master was broken, even with the AMS ring and AMS clutch line and the retaining ring popped out of the center of the exedy twin HD.
That's just ridiculous. Mitsu ought to be ashamed for this bull#%!. Why make such cheap master cylinders...
Offline
Old Oct 25, 2009, 02:31 AM   #3
Personal Sales Rating: (6)
endGameXIII's Avatar
Drives: Evo X GSR
i read SSP already have a full billet master clutch cylinder fabricated. you might want to give them a ring and see if they can have their prototype to you. it has to be better than the plastic gimmick cylinder.
and the clutch pedal being slow to come back up...have you tried bleeding the system?
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Old Oct 25, 2009, 06:51 AM   #4
Drives: evo x ,92 talon tsi , 88 starion esir
i think you will find you have a hose or something collapsed inside the hose causing a restriction or a pinched line somewhere
i also have the exedy twin and my ped feels like stock
i would take the lines off and see if you can blow threw them
only other this is slave cyl
i can think of anything inside the bellhousing that could go worng
so 1 lines
and 2 slve cyl
cause you have allready put on a new mc and not likely to have 2 in a row bad
__________________
current mods
fp red
cosworth mx1 cams and springs
dw 800 cc injectors
aqumist hsf1
apexi avcr
wb 255 fp with ur install kit
ur turbo back exhaust
perrin front mount
turbo trix hard pipes
exedy twin disc
hood dampers
perrin 3" antena
twm short shifter and bushings
blox front engine mount
t1r shift boot
blox neo shift knob
mase tunned 430/377 at 24 psi
near future mods are
atp down pipe with tial 44mm wg
bc coilovers
fenders rolled
volks bronze ce28
Offline
Old Oct 25, 2009, 06:58 AM   #5
Personal Sales Rating: (3)
Evo a Mula's Avatar
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
The ams rimgs will not help it from breaking internally sadly & do you think the ring poped out your clutch exedys clutchs do that
__________________
**DG Motors Sponsored**
Call DG Motors 631-957-8464 for all you Evo needs
Dyno Tunes
Installations
Full builds
Dyno time
Offline
Old Oct 27, 2009, 12:29 PM   #6
.MM
.MM's Avatar
so 1 lines
and 2 slve cyl
i checked all the above and am still batting zero!
someone help me!!!
__________________
Offline
Old Oct 27, 2009, 12:29 PM   #7
.MM
.MM's Avatar
Quote:
ill check...if the ring popped out again...i might kill someone...
__________________
Offline
Old Oct 27, 2009, 03:37 PM   #8
did you happen to take the slave cyl off when you did your clutch if so there is a little restrictor in the bottom of the slave cyl mabie you didnt get it back in right
some where in the hydrolic system of the clutch there is a restriction this would be the only thing i can think of that would cause a hard to push pedal with a slow return pedal
i really dont think you will find a problem in the clutch asy itself
__________________
current mods
fp red
dw 800 cc injectors
aqumist hsf1
apexi avcr
perrin front mount
exedy twin disc
hood dampers
perrin 3" antena
t1r shift boot
blox neo shift knob
bc coilovers
fenders rolled
volks bronze ce28
Offline
Old Oct 28, 2009, 12:28 PM   #9
.MM
.MM's Avatar
i give up
ordered a complete evo 9 conversion kit and slave block and evo 9 clutch line
**** this, lol
__________________
Offline
Old Oct 28, 2009, 01:41 PM   #10
Personal Sales Rating: (0)
I need this too. Where can I order same thing, please?
Offline
Old Oct 28, 2009, 03:58 PM   #11
dg motors is selling the evo 9 conversion kit
__________________
current mods
fp red
dw 800 cc injectors
aqumist hsf1
apexi avcr
perrin front mount
exedy twin disc
hood dampers
perrin 3" antena
t1r shift boot
blox neo shift knob
bc coilovers
fenders rolled
volks bronze ce28
Offline
Old Oct 30, 2009, 10:19 AM   #12
Plat Vendor
Personal Sales Rating: (40)
ETS Michael's Avatar
Drives: Operation Damaged Goods - 03 Yellow Evo
Send a message via AIM to ETS Michael
So far we haven't had any breakage with the Exedy Triple in our car. We are still running stock components. Good choice going with the DG Setup!
Michael
__________________
Michael
Site: Extreme Turbo Systems
Pho: 360-263-3748
AIM: ETS MichaelR
Evo X Stock Block/Stock Head - World Record - 681whp (ETS 3586 Turbo Kit)
Evo X ETS Built Motor - 2.0L World Record - 718whp (ETS 3586 Turbo Kit)
1117whp Evolution 8 (ETS 42R Turbo Kit)
ETS 6.0" Intercooler - ETS 45R Turbo Kit - ETS Exhaust - English Racing Motor - English Racing Tune
ETS Holiday Specials On Our Website!! 20% Off ETS Products!!
Offline
Tags
clutch, evo, exedy, ix, master, slave
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
