Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 24, 2009, 05:26 PM   #1
Personal Sales Rating: (3)
ganghyung's Avatar
Drives: Evo X 2008 GSR; 06 IX MR(gone)
boost leak test
hi I am trying to DIY boost leak test. does anyone know which location I should start to hook it up? and what diameter should i use? I have searched alot but there is no one for evo x. I made a two inch tester
__________________
2008 PB Evo X GSR w/ sss
Greddy TIC/Ichiba Test Pipe
Custom intake/turbo inlet
Prosport Boost & AEM wideband
cobb AP custom self tune
going to E-85
2006 GG Evolution IX MR (sold)
ACT HD6P clutch and flywheel/Walbro 255 /Fujita Intake, UICP and LICP/HKS HI exhaust.
Offline
Old Oct 25, 2009, 01:24 AM   #2
ganghyung's Avatar
I hooked it up to UICP, and air was entered constantly until 25psi. it slowed down to zero. I did several times but i heard anything from there. but my boost still peaks 13 psi with no tapering. is there other restrictors to raise the boost level such as boost pills or Solenoid?? I am using AP stage 1.
__________________
going to E-85
Offline
Old Oct 25, 2009, 06:16 PM   #3
Bighec's Avatar
Drives: 2008 WW X
I've heard the best place to hook up the is the turbo inlet, and other people on the forum have told me it is 3 inches.
__________________
Wicked White Evo X
Perrin Stealth Catback Exhaust
AMS Upper and Lower Intercooler Pipe
AMS Front Mount Intercooler
AMS Short Ram Intake
AMS O2 Eliminator / Downpipe
AMS Testpipe
AMS CEL Delete
Forge MBC
Goodridge Stainless Steel Brake Lines
Jestr Tuned 371hp/ 372tq
Offline
Old Oct 26, 2009, 08:22 PM   #4
Personal Sales Rating: (0)
Drives: Nothing
My understanding was that you need to take off the intake and hook it up (i.e. turbo inlet). This is what I was planning on doing when I finish building mine.
Sorry, I think it is 2.5 inches, not three. The intake reduces down in size when it gets to the turbo. Someone correct me here if I am wrong.
Offline
Old Oct 26, 2009, 11:33 PM   #5
Personal Sales Rating: (5)
itznoraa's Avatar
Drives: Lancer
yupp use the turbo inlet, and take a spray bottle and put soapy water in it. When you spray the connections, if there is a leak...it should make bubbles.
Offline
Old Oct 26, 2009, 11:49 PM   #6
linjy2's Avatar
Drives: PB EVO X
Send a message via AIM to linjy2
turbo inlet and its 2.5"
i just did a boost leak test this weekend.
I found out the stock bov leaks at 27psi. at least for me it does.. i needed to boost 30psi+
__________________
Tuned by Mellon
FS Evo X Parts:
New 3port boost solenoid $70
http://forums.evolutionm.net/south-r...ml#post7558720
Offline
Old Nov 1, 2009, 05:28 PM   #7
Drives: Nothing
So you are saying don't pump in more than 27 psi, or it leaks out anyway?
Offline
Old Nov 1, 2009, 05:48 PM   #8
murlo26's Avatar
Drives: 08 RR X GSR
Send a message via AIM to murlo26
The factory bypass valve varies pretty widely from Mitsu, its the same one from the Evo 9's. Some will hold 33psi, others only 25-26.
You can crush your bypass valve to make it hold more.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Old Nov 1, 2009, 06:01 PM   #9
Drives: Nothing
Should I just search for a thread on that?
Offline
Old Nov 2, 2009, 12:09 AM   #10
i heard there is an o-ring in the turbo oil line that can get displaced if you pressurize the crank case too much. Has anyone experienced an oil leak after doing a boost leak test?
Online
Tags
boost, diameter, evolution, lancer, leak, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
