Oct 22, 2009, 10:26 PM
Personal Sales Rating: ( 1)
Drives: 08 WW Lancer Evolutino X GSR
About oil change and engine flush
Hi guys, I'm going to do my first own oil change. So far the dealer did 3 times oil changes for me, but suddenly I figured they might not change the oil filter and didn't really drain the oil completely every time,and I'm a little behind schedule for this oil change,so I'm thinking make I could do a engine flush. But IDK if I can do engine flush on a turbo car, and if it's necessary or good to our engine. If it do no harm to our engine,what's the recommended brand?
Condition of my oil: I changed my oil every 6000km, but before
every oil change, the oil was quite dark( not totally black, my car has only 17000KM).
__________________
2003 Mitsubishi Eclispe GTS (sold)
2008 Lancer EVO X GSR
Offline
Oct 22, 2009, 10:31 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Warm up car, drain old oil, fill up with your choice of oil, go drive... no need to flush. 3700 miles is not too long, I run my oil up almost 5000 miles with no issues. However, I get a oil report to tell me how long I can run the oil for and how it is holding up.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Oct 22, 2009, 11:55 PM
Personal Sales Rating: ( 21)
Hopefully your dealer has been using mobil 1 and not bulk oil.
Offline
Oct 23, 2009, 09:01 AM
Personal Sales Rating: ( 2)
Drives: 'MMVIII Evo 10
I'd flush with a synthetic that you are willing to use long term..so it would cost 5 qts...otherwise, don't use cheap oil for anything unless its an emergency. You'd be better off just changing the oil a little early the next couple of times. The new oil will have a fresh additive package that will keep the contaminants in suspension so it is somewhat psychological to need to see really clean oil.
the other thing is the evo blackens the oil quickly anyhow.
BTW- don't flush with a chemical cleaner! (re-read your post)- just put fresh oil in, drive it 'till its warm, then drain and refill-or just do what I recommended and just change the oil a little early next time.
Offline
Tags
5000, ams, change, engine, evo, evolutionm, filter, flush, flushing, hange, harm, miles, oil, turbo, wait  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
