Oct 22, 2009, 04:19 PM
Personal Sales Rating: ( 0)
Drives: 2007 S2000
clutch lifespan?
Hi Guys,
Just sold my S2000 and am considering an Evo X. After viewing many posts it appears that the clutches in these cars are inadeqate. Can anyone speculate on projected (or documented) lifespan for the EVO GSR clutch with agressive street driving (no high RPM launches)? I am used to getting 100K out a clutch. Thanks!
Offline
Oct 22, 2009, 04:37 PM
Drives: 2008 Apex Silver Evo x
i cant speak for others. But the evo was my first stick car. Ive smoked the **** out of it on a few bad launches and i dont baby the car at all. 16k and seems fine to me. Im not making big power either. Just exhaust and cat delete.
__________________
Dane
PSU'11
2008 Evolution X
Apex Silver
Speed Circuit Wicked edition exhaust
Speed Circuit Test Pipe
HKS Drop In
Offline
Oct 22, 2009, 05:30 PM
Drives: OB 08 Lancer Evo X
I had really bad luck with my stock clutch, and I have reason to believe it was abused during test drives @ the dealership. i.e. really BAD launches by morons who have no clue how to drive.
I bought a used stock clutch/flywheel with 7000 miles, put them on at under 5000 miles and I now have 13500 miles on the car. Same driving style, lots of 2-step launches, quick-shifting, general huge amounts of abuse. The clutch is still holding fine, with almost 16000 miles on it. It doesn't burn and stink like my original stock one did, in fact I just smelt it today a little after slipping from 4500 rpm, and just for a small bit. The other one would stink for hours; I think it was just a defective clutch or it was abused early on in its life.
*knocks on wood* but I think I'll get many thousand more miles out of my current stocker - it's treating me pretty well.
BTW, this is with full exhaust, intake, UICP, methanol injection, and tune @ 28 psi with a 3-port EBCS so ~ 360-375 lb-ft to the wheels.
Offline
Oct 22, 2009, 05:40 PM
Personal Sales Rating: ( 2)
Drives: 08 EVO X WW GSR SSS Aero Navi
22,000 miles on mine before started slipping badly. I have an FP Red running 24 PSI. Stock cat back though so wasn't that much power. Spirited driving but only a few launches. was nothing left of the disc when I removed it.
Offline
Oct 22, 2009, 06:35 PM
Drives: 08 RR Evo X GSR
it's REALLY variable. Some die in 1200 miles, some go over 40k miles. ymmv... literally.
my first clutch died at 3800 miles, thanks to the flywheel being hotspotted to hell before I bought the car =/ I don't think the problem is the clutch disc, but the flywheel. EVERY ONE i've seen has been hotspotted like nothing I've seen come out of other cars.
Offline
Oct 22, 2009, 10:05 PM
Drives: 08 RR X GSR
If you launch it, which is not what the stocker was meant for it will die very soon even if you do it right, however if you dont launch it will last you a good while.
I am running 31 psi (i feel like i type this daily, lol) and making 400wtq on the stock turbo, at 17k now and no problems yet. It's all how you drive it. I drive it hard daily too, only get like 14mpg at most usually.
__________________
Buschur Racing Dual Exhaust w/Bullet Muffler
UR Testpipe
Works Short Throw & Works Base Hybrid Bushings & AMS Underhood Bushings
AMS 3" Intake w/ Heat Shield
AMS UICP
Perrin 3-port
ECUFlash TUNE - 354awhp/376awtq @31psi(dyno dynamics 1.0CF)
393awhp/395awtq (MAP's dynojet)
Cosworth MX1 Cams
Deatschwerks 1000cc Injectors w/E85
Perrin 2" Shorty Antenna
SOON: I see Redness on the Horizon and it's not a sunrise:)
Offline
Oct 22, 2009, 11:25 PM
Personal Sales Rating: ( 1)
Drives: CZ4A
32k miles and mine is still going strong. I don't launch at all though...
I want an Exedy soon though.
Offline
Oct 22, 2009, 11:49 PM
32K miles on a tune and some bolt-ons (300whp Mustang). No problems with the stock clutch and I don't launch it.
Offline
Oct 23, 2009, 02:13 AM
Personal Sales Rating: ( 3)
2008 Mitsubishi Lancer Evolution
Drives: 05 acura TL (sold) / 08 ww evolution x gsr
I almost have 17k miles and I'm on my second exedy stage 2 clutch!
__________________
Check out my car Blog
Tuned by Kreionic 297.7awp/ 340 awtq on Dyno Dynamics Dyno = to like 360awp on a dynojet
mods: DG Motors Evo 9 clutch master cylinder conversion/ Ecuflash tune / Greddy Ti-c / Exedy stage 2 clutch / TurboTrix intake / K&N Cone Air Filter / AMS Small battery kit / AMS Upper ic pipe / AMS test pipe / AMS o2 Simulator / Defi White racer boost gauge / ARC titanium shift knob / T1R suede shift boot white stitching / Tein Mono Flex Coilover
Offline
Oct 23, 2009, 02:49 AM
Drives: Evo X GSR
I'd say 6 autoXs and about 30~ street races
__________________
EVO X GSR
UR 3" single Cat Back Exhaust
UR 02/dp and testpipe/mini muffler
HKS drop in filter
Custom tune by HB Speed
Muellerized JICs
Offline
Oct 23, 2009, 05:56 AM
Drives: 2007 S2000
Thanks for your responses! Unfortunately this is not giving me a warm fuzzy feeling.
I think the stock clutch should be able to last 100K miles with agreesive street driving and no mods. Sounds like most of you have turned up the boost and do some hard launching.
Under these conditions I think it is reasonable to expect accelerated wear and reduced lifespan. Perhaps the EVO 10 has not collectively accumulated enough miles to get a meaningful response to this question. Are there any street driven EVO 10's out there with high miles to respond?
If the stock clutch fails at under 50K this is a design problem. I understand why
Mitsubishi designed the car with a small diameter flywheel and this would certainly limit the surface area for the disc. Does the MR use the same flywheel? Thanks!
Offline
Oct 23, 2009, 07:23 AM
Drives: 08 RR X GSR
Everyone here who doesn't launch is still on the stock clutch. The X is still new man, you aren't going to find too many high miled ones.
The stock clutch is fine.
__________________
UR Testpipe
AMS UICP
Perrin 3-port
Cosworth MX1 Cams
Offline
Oct 23, 2009, 07:26 AM
8k, stage 1 since 1k...no issues. no launching though...just my daily driver that gets turned fast.
Offline
Oct 23, 2009, 08:14 AM
coming from an s2k, you might be expecting a bit much. I mean, you went from a super low torque, light weight car with crap mechanical grip, to a heavy torque monster with more mechanical grip than sports cars 3x it's price. it's a perfect storm for dead clutches. I don't think a top of the line aftermarket clutch can make it 100k miles in an evo x. Clutches dieing before 15k are a problem, but 100k is much. remember, the clutch is a wear part that serves as protection for the engine. it made to wear over time
Offline
Oct 23, 2009, 08:28 AM
Drives: 2008 Evo X GSR SSS, 2003 Honda S2000(sold)
13K miles works as new. Mine's a DD so I'm not launching it. An S2k clutch won't stand up for repeated launches either fwiw. Coming fron an S2k myself, I'm thrilled with the all the mid range torque and don't feel the need to jump off the line like I have something to prove.
Offline
Tags
air, burning, car, clutch, cone, evolution, filter, lancer, life, lifespan, miles, mitsubishi, mustang, s2000, span  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
