Oct 20, 2009, 03:30 PM
NTEC Club Forum Leader
Personal Sales Rating: ( 4)
Drives: RR EvoX
Evo VIII/IX fuel pump sock for an X with E85?
Reading on here, it seems that you need a new sock for the fuel pump assembly if you go E85. Do you need one at all? From an 8/9? Which one do you need?
I know you need an external fuel filter as well since you're removing the one with the pump when you swap pumps.
Any recommendations for an off the shelf one other than URs?
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Oct 20, 2009, 08:01 PM
Personal Sales Rating: ( 1)
Drives: WW Evo X
Quote:
I was looking at this one from HB Speed
Pre-order Evo X fuel pump housing kits with filter
Offline
Oct 20, 2009, 09:31 PM
Drives: RR EvoX
Hmm... I got the housing, but what I got did NOT have a filter...
__________________
mmmm corn
Offline
Oct 20, 2009, 11:37 PM
Drives: 08 Evo X Apex Silver
Do you have an upgraded turbo? If not, you won't need a fuel pump upgrade for e85. Just use 1000cc injectors and you'll be about 90% duty cycle.
Offline
Oct 21, 2009, 12:02 AM
Personal Sales Rating: ( 0)
I thought the fuel pump upgrade was needed with E85 and the stock turbo??
Offline
Oct 21, 2009, 12:23 AM
Silver Sponsor
Drives: EVO, STI
Quote:
Ran out of stock pump on E85 on stock turbo:
http://forums.evolutionm.net/7044333-post55.html
Walbro upgrade fixed it.
Now it's on BlaqOps Progressive Double Pumper (progressive twin pumps) with a Dom2
Offline
Oct 21, 2009, 01:07 AM
Quote:
Originally Posted by GST Motorsports
I can't remember but wasn't that car running Bosch 950cc injectors?
Let me recant my statement. You may be ok with 1000cc injectors and e85 w/o a fuel pump upgrade.
Let me just post my friend's setup as a data point. He was running DW 1000cc injectors w/ bolt-ons and stock fuel pump. I just checked his logs and he's at about 91% duty cycle peak w/ AFRs at around 12.0.
Offline
Oct 21, 2009, 03:39 AM
Drives: PB EVO X
my hb speed housing came with the sock filter.
as for a inline fuel filter, i bought the fuel lab one which is rated for e85, but that thing is huge.. so i also bought the russell competition one and will probably run that one.
Offline
Oct 21, 2009, 07:39 AM
Drives: RR EvoX
on 93, I'm already maxing out duty cycles with the stock injectors @ 11.5 AFRs. I think the walbro upgrade, especially since I track the car, is worth the effort.
I've got 1000 cc injectors as well.
__________________
mmmm corn
Offline
Drives: RR EvoX
Quote:
Crap. I PMed hbspeed. Maybe they just forgot it (I was pressuring them  )
__________________
mmmm corn
Offline
Tags
blaqops, dubble, e85, evo, filter, fuel, hb, line, location, net, problem, pump, pumper, sock, speed, stock  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
