Oct 19, 2009, 08:14 PM
Personal Sales Rating: ( 0)
Drives: 2008 EVO X GSR
Meth and NO2
I am running fp red on 29 psi with aem meth kit with 50/50 meth, upgraded pump and 800cc injectors, cams...., (dynoed 390 whp and 330wtq)
and would like to run 35-50 shot to help on the spool and upper the hp.
do i have to tune again if i am running a "small shot" on a wet NO2 kit? retard timing needed? how do i tune for a no2 kit if i am not running it all the time. can i just keep the existing timing?
do you guys think it is ok to run meth and nos on the same car.
which kit would you guys recommend on my application?
thanks guys.
kl
Offline
Oct 19, 2009, 08:23 PM
Personal Sales Rating: ( 12)
Drives: 06 TB MR and EG K20 Turbo
hmmm aren't your HO a lil low??? for a red with meth? just wondering...
__________________
DWB
let's just say our cars are kind of fast... PERIOD
4WS Tuned!!!!!
Offline
Personal Sales Rating: ( 6)
Drives: WW EVO X
thanks guys.
kl
Yes, yes you definitely need to retune.
Use ECUflash or CobbAP to flash between maps, 1 w/ Nitrous, 1 w/o nitrous
__________________
WW EVO X #32
AMS Front Motor Mount & Underhood Shifter Bushings
TurboTrix Piping Kit
ETS Dual Exhaust
T1R o2/DP Combo, T1R Testpipe, Shift Boot, Stubby Antenna
Prosport Boost Gauge
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Seibon CW hood/OEM Trunk
Chargespeed FRP VG
ECUTek Tune (318whp/359 Torque @ 26psi)
First EVO X in Canada to Break 300whp
Offline
Oct 19, 2009, 08:40 PM
Quote:
what do you mean??##
Offline
Oct 19, 2009, 08:45 PM
which kit would you recommend?
i am looking at zex turbo application set up.
http://www.zex.com/Pages/84/Turbo-Equipped.aspx
the kit will cut no2 once the boost hit a set amount of psi. on top of that, i will run a window switch probably between 2500-5000 rpm. so there are 3 things to control the no2 : boost psi, rpm and it has to be full throttle.
kl
Offline
Oct 19, 2009, 08:46 PM
Personal Sales Rating: ( 1)
Drives: TB IX MR SE, 07 R6
Umm just run 100% meth? dunno...
__________________
E85
Quote:
Found a driedout gerbil carcass at the bottom of the boxAND it had been shaved.
Offline
Oct 19, 2009, 09:48 PM
Drives: GG X
You need a tune if you are planning to run any nitrous.
And as far as your window switch and boost-specific initiation of the shot you are on the right track and taking the right precautions.
However; as the old adage goes "It's all in the tune" is never more true than when tuning for nitrous on a turbocharged application.
You will need to adjust more parameters than just timing if you want to be safe AND make optimal power with said shot being used.
I, just as you am planning on running nitrous with my setup as well. However I have a built motor and feel a little more comfortable doing so...
DRAG is a member on here that you should PM and speak with personally about any questions you have being that he has used nitrous on his own evo x.
Hope I helped man, GL!
__________________
evolutiondynamics built longblock 5 angle valve job w/ported & polished head Kelford 214-B's w/springs FPRed GM 3 port solenoid AMS FMIC AMS intake AMS UICP AMS LICP UR o2/DP combo DW 800cc Walbro 255 ACT 6-puck Megan Racing coilovers Volk TE37 18x9.5 285/35/18 Ventus RS-2's Carbon Fiber. Lot's of Carbon Fiber.
Offline
Oct 19, 2009, 10:15 PM
is zex a good kit to go with?
would you do direct port of single wet fogger if i want to run no2 with my Red?
Offline
Oct 20, 2009, 02:26 PM
Drives: GG X
Zex's turbo specific kit would be a great choice.
And I would choose a direct port setup over a single fogger setup, for 2 reasons. You will make more power AND make it in a safer was as well.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
