Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 19, 2009, 08:47 AM   #1
Personal Sales Rating: (2)
2008 Mitsubishi Lancer Evolution
newcomer81's Avatar
Drives: GG X GSR
installing FP Red any additional advice?
I am tossing on an FP red & down pipe this weekend. It was lightly used so contacted fp to find out if it should come with any install hardware other than the turbo; i was surprised that it does not. Following the Garrett instructions below i know i will be picking up new copper crush washers. anyone else that has upgraded to the red have any other input on replacement bits to get prior to the install? i know to pb blast the hell out of everything
instalation instructions i will be following:
http://www.turbobygarrett.com/turbob...structions.pdf
__________________
FP Red - UICP - TBE - Drop-in Air Filter - Test Pipe - Motionlab tuning 800cc injectors - Coilovers - 3 port ebc
Tuned by Motion Lab Tuning
Offline
Old Oct 19, 2009, 08:48 AM   #2
buchnerj's Avatar
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
did you get any upgraded oil lines or are you keeping it on the stock lines?
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Old Oct 19, 2009, 08:50 AM   #3
newcomer81's Avatar
Drives: GG X GSR
planned on keeping the stock ones unless there is reason not to.
__________________
Offline
Old Oct 19, 2009, 01:57 PM   #4
Personal Sales Rating: (0)
Drives: evo 10
maybe ah bolt or 2 for the back housing
Offline
Old Oct 19, 2009, 02:04 PM   #5
NickieBlaine's Avatar
if your going to be running more than mid 20's psi then you should probably get upgraded oil lines. fp recommends them so you dont burn the turbo up
__________________
2003 AS Evo- Broken
SBR 2.4- Spun Bearing in less than 200 miles
Ported/Polished/ 1mm Oversized Head
Comp 272's
ETS 4" FMIC
BR Ported Intake Mani
FP Ported Green, 18psi actuator
BR Ported Exhaust Mani
780cc
APS DP BOV
BR Mini Battery Kit
Full 3" Exhaust
Exedy Twin Disk
Walbro 255
www.midwestevos.com
Offline
Old Oct 19, 2009, 02:15 PM   #6
Personal Sales Rating: (28)
Drives: 2005 Electric Blue Evo 8
Get the new Oil line from FP. I think FP has an install kit that would get you everything you need. The Oil line is not hard to install, as I did it on my HTA Green.
__________________
BR parts (4WS Tuned) + E85
12.24 @ 112.0 (1.70 60') - 5/9/2008 (w/alky)
Midwest Evos
http://www.midwestevos.com
AMSOIL
http://www.amsoil.com
Offline
Old Oct 19, 2009, 02:36 PM   #7
linjy2's Avatar
Drives: PB EVO X
Send a message via AIM to linjy2
this is for a X, stock hardline is fine and I don't think they make SS line for our evo x yet unless its custom because i been looking for one for awhile.
__________________
Tuned by Mellon
FS Evo X Parts:
New 3port boost solenoid $70
http://forums.evolutionm.net/south-r...ml#post7558720
Offline
Old Oct 19, 2009, 05:29 PM   #8
Guru's Avatar
Drives: 08 EVO X WW GSR SSS Aero Navi
I used the original line. No problems here. Umm install is a biatch. I would get two new bolts for the manifold to turbo and replace the studs with bolts to make it easier to remove and install next time. Also you need LONG extension and swivel to get the bottom bolt out. It's quite hidden. Be prepared to be swearing a lot and have bloody hands but it'll be worth it. I also changed the manifold to turbo gasket just in case. Probably don't have to. oh and have some coolant hose and some vice grips to plug the coolant lines, otherwise you'll have a mess on oyur hands like me.
__________________
Dan
Thinking of a Blouch Turbo? Read this first:
http://forums.evolutionm.net/service-parts-tuning-review/375268-stay-away-blouch-turbo.html
Offline
Old Oct 20, 2009, 01:30 AM   #9
Personal Sales Rating: (4)
blueberryyumyum's Avatar
Drives: 2008 Lancer Evo GSR
Send a message via AIM to blueberryyumyum
what about bigger injectors and fuel pump? arent those recommended as well?
__________________
2008 Graphite Gray SSS Evolution X
[ACT][Artisan][BBS][HKS][Injen][Ivey Tuned][Mitsubishi][Seibon][TEIN]
Offline
Old Oct 20, 2009, 07:02 AM   #10
newcomer81's Avatar
Drives: GG X GSR
Quote:
Thanks for the heads up on the bolts I'll pick a few up. i don't plan on having to take the red off again but you never know if a exhaust manifold may someday find its way into the engine bay. I have about 2.5' of extention, i may pick up another 12" just to be safe (thats what she said).
Quote:
an upgraded fuel system will be coming in a paycheck or 2 but i got such a good deal on the red i didn't have all the supporting mods lined up that i wanted to have i don't have the will power to not put this damn thing on either. I'll see how well the stock fuel system holds up. iirc a few shops broke 400whp on the stock system before running out of fuel. i guess i'll see how it holds up, but i'll be watching a/f and idc like a hawk as i increase the boost.
__________________
Offline
Old Oct 20, 2009, 07:10 AM   #11
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Stock fuel and injectors will be ok at lower boost on pump gas, just don't plan on going much over 22 psi without very carefull datalogging to make sure it's not leaning out with no control.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Oct 20, 2009, 07:13 AM   #12
newcomer81's Avatar
Drives: GG X GSR
Quote:
i'll be using 93 oct and i am all set with evoscan and a wideband. if i run out of fuel then new injectors will be inbound earlier than i the pocket book would like.
__________________
Offline
Old Oct 20, 2009, 08:15 AM   #13
Personal Sales Rating: (9)
Tractionlimit's Avatar
Drives: 2008 Evolution X GSR 2004 Evo VIII RS (sold)
Quote:
Replace the turbo to hotside bolts if you can (as mentioned, PB blast the old ones 24hrs ahead of time to get them out.) Once you get the old bolts out of the turbo without breaking them, you're 75% done . A 24" extension and multiple flex extension sections will be worth their weight in gold.
Take it from me and USE ANTISEIZE on these bolts when reinstalling. You may never plan to take the Red off again, but chances are, YOU WILL, maybe even twice. This is especially true if you're not using a cast O2 downpipe or if the hotside was ported too thin. If you have time, maybe consider porting the stock exhaust manifold to match the gaskets. There is quite a bit of extra material there on both ends.
Don't mean to scare you at all, but it's better to be prepared for the worst as this isn't the most fun job. End results will be worth it though . good luck.
__________________
E85EvoXRed
481whp 443ftlbs
Offline
Old Oct 20, 2009, 08:16 AM   #14
At 22psi, you're better off with the stock turbo .
__________________
E85EvoXRed
481whp 443ftlbs
Offline
Old Oct 20, 2009, 09:34 AM   #15
newcomer81's Avatar
Drives: GG X GSR
i'm not scurrd!
My 1st turbo swap so i'm just trying to get as much info before heading into it. i'm mechanically inclined so i don't have any worries. i just hate getting to a point and having to stop because i don't have a new crush washer,a bolt or a hose clamp. pb blaster and anti-seize was already planned. I have a 3 day weekend so i am getting the turbo on, even if it is only at 21 psi =)
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
