Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 15, 2009, 07:19 PM   #1
Personal Sales Rating: (2)
jd888jd's Avatar
Drives: Evo X- now I own, WRX Subaru - SOLD!!
Send a message via MSN to jd888jd Send a message via Yahoo to jd888jd
IS this normal?
I dropped off the car today to my mechanic shop and went back to work, and he drove the car around for a bit...see if everythings fine etc..so He called me back about an hr or so..He said why is my boost so high "25-26 PSi"?
And he asked me if I installed anything internal, cams etc... I said NO.
Current mods are Invidia Q300 Catback with T1R Test Pipe, ARC UICP, ARC Suction Intake Box, Ultimate LICP, Perrin IC. 91 OCt. Stock Turbo. No tune yet.
Is this something normal, I know black smoke comes out on WOT...Running Rich
Offline
Old Oct 15, 2009, 07:32 PM   #2
Personal Sales Rating: (0)
Drives: 2008 RR Evo X
yes...the more important question is, why does your mechanic know this?
Offline
Old Oct 15, 2009, 07:42 PM   #3
jd888jd's Avatar
Quote:
He drove the car, and shows on my boost gauge that iam boosting 25psi...
Offline
Old Oct 15, 2009, 08:51 PM   #4
Personal Sales Rating: (5)
ScottSpeed21's Avatar
Drives: Evo X GSR
I think what he meant was, why is your mechanic pushing full boost at WOT in your car?
__________________
2008 Octane Blue Evo X GSR SSS / Navi / Aero
Engine • Cobb AP • AMS Intake • Nisei UICP & LICP • ETS 4" Intercooler • Tial 50mm BOV • T1R O2 Downpipe • Custom 3" high flow cat • Custom 3" dual catback exhaust
Chassis • Gram Lights 57 Maximum 18x9.5 +22 • BFG g-Force Sport 245/40-18 • Eibach springs • Whiteline rear swaybar
Exterior • APR Front splitter • AMS/Gates gurney flap • Ralliart taillights
Interior • TWM Short throw shifter • AMS shifter bushings • AEM Analog boost gauge
Online
Old Oct 15, 2009, 08:56 PM   #5
Personal Sales Rating: (21)
Drives: RR X MR
^^^+1, especially since you haven't had it tuned, can't believe your mechanic is beatin' on your X. Take it easy until you get a custom tune.
Offline
Old Oct 15, 2009, 09:15 PM   #6
mlomker's Avatar
Drives: 08 EVO GSR
Quote:
Boost isn't the same as fueling. Probably just something wrong with your gauge if you haven't installed a boost controller--a X should be 20-21 psi stock.
__________________
RR 08 GSR
304hp/305tq DD by Shane@DBperformance
Offline
Old Oct 16, 2009, 05:15 AM   #7
stock boost is debatable on an Evo X. some have said as low as 19psi or as high as 25psi...my guess is because he is running a test pipe he gets a little spike up to 26-27psi.
Offline
Old Oct 16, 2009, 05:53 AM   #8
raytrix's Avatar
Drives: Wicked White Evo X
I have stock tune on the Evo X and with the Greddy Informeter I read 23.2 max psi on the stock turbo. I have Greddy SE Exhaust, Test pipe, and a drop in filter only. Both on and off the test pipe I have gotten peak of 23.2 psi roughly. It could be boosting more because I heard the on board IN-MAP sensor on the Evo X can only read up to 23 psi but the car boosts up to 24 psi max. Anything above 24 psi without a tune is not safe unless your logging knock to make sure your ok to peak above that and only for a 1-2 seconds.
Offline
Old Oct 16, 2009, 06:19 AM   #9
Personal Sales Rating: (6)
Drives: EVO VIII MR
Could be boost creep from the induction and exhaust parts. Usually that would occur with O2 housing and DP though. You should get a tune or reflash asap.
__________________
GG VIII MR
Apexi TBE // O2 Housing // IX BPV // Hallman Pro MBC // Cobb AP Stage 2 @ 22lbs // Injen UICP & Intake // ETS LICP
DBA // Project Mu
Online
Old Oct 16, 2009, 06:54 AM   #10
2008 Mitsubishi Lancer Evolution
newcomer81's Avatar
Drives: GG X GSR
Quote:
is it reading the boost through the obdii connection or did you install a separate boost sensor? reading full boost through the ecu requires 2 bytes which iirc only mode23 enabled evoscan and the AP can do without a separate 3 bar map sensor.
__________________
FP Red - UICP - TBE - Drop-in Air Filter - Test Pipe - Motionlab tuning 800cc injectors - Coilovers - 3 port ebc
Tuned by Motion Lab Tuning
Offline
Old Oct 16, 2009, 07:41 AM   #11
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Its the intercooler pipes causing boost to go that high.
Although I'd be ALL over the dealer for boosting that high unless they were checking something else.
My dealer drives it barely above 3krpm when testing the car for something. If it's something that requires a WOT they have me do it.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Oct 16, 2009, 09:22 AM   #12
Personal Sales Rating: (3)
DVDee's Avatar
Drives: WW EvoX
These are fun times for this mechanic.
__________________
Performance Mods: Nisei UIP - Ecutek Tune by Dynoflash @ ICS Performance Dynojet - Forge WGA - Forge Unos MBC - SX HFC w/ WB bung - Tsudo N1 Extreme Exhaust
Interior Mods: Defi White Racer Gauge - AEM UEGO WideBand
Exterior Mods: 20% Tints all around - Faux CF wing inserts
Offline
Old Oct 16, 2009, 09:27 AM   #13
raytrix's Avatar
Quote:
It's reading off the obdii which is limited by the factory sensor mounted after the turbo in the manifold. The greddy informeter is actually just reading manifold pressure. It's more accurate to read off the vac lines which usually shows a higher psi than what is read on the manifold pressure. The greddy informeter without the optional boost sensor plugs will read off the obdii which mine is doing. So it's safe to say my car could be boosting +- 1-2PSI from the IN-MF pressure reading. If you can get a boost gauge to read off the vac, that is your best bet for accurate readings.
Offline
Old Oct 18, 2009, 03:09 PM   #14
Bighec's Avatar
Drives: 2008 WW X
When I took my car in to have it tuned Jestr told me it was knocking like crazy which would cause the ecu to dump excess fuel into the cylinder causing a rich mixture and black smoke to come out of your tail pipes. You definitely should have your car tuned asap.
__________________
Wicked White Evo X
Perrin Stealth Catback Exhaust
AMS Upper and Lower Intercooler Pipe
AMS Front Mount Intercooler
AMS Short Ram Intake
AMS O2 Eliminator / Downpipe
AMS Testpipe
AMS CEL Delete
Forge MBC
Goodridge Stainless Steel Brake Lines
Jestr Tuned 371hp/ 372tq
Offline
Tags
aem, analog, boost, correct, gauge, readings
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
