Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 13, 2009, 03:05 PM   #1
Personal Sales Rating: (0)
Drives: Evo x Mr PB
Cobb ap question
installed the ap, i was hitting about 22.5 psi of boost on stage 1 map, in a mr on 91 octane. my dyno numbers where 316/278 tq, are these numbers WTQ or crank?
what gear and what rpm range should i do my dyno's in? is the dyno feature reliable?
thanks.
Offline
Old Oct 14, 2009, 09:41 AM   #2
ApexSilverXGSR's Avatar
Drives: Evo X GSR
Just to let you know, the dyno on the AP isn't very accurate at all because it's based on its built in accelerometer. Unless you can measure your X's weight properly with you in the car, you're going to get values that don't make much sense.
Better to just go get dyno'd at a reputable shop and use the AP for stored staged maps and monitoring.
Offline
Old Oct 14, 2009, 11:40 AM   #3
Drives: 2008 RR Evo X
Um....no, the Cobb AP has NO built in accelerometer. It's based off of speed, time, distance, etc.
As long as you have the weight correct and correctly , the Cobb AP has been proven to be pretty accurate.
Offline
Old Oct 14, 2009, 02:52 PM   #4
Drives: Evo x Mr PB
the numbers on the cobb ap says hp/tq. is that crank, or actually at the wheel, how much does an mr weigh? isnt it like 3545 or something, then i just add my weight on there?
Offline
Old Oct 14, 2009, 07:11 PM   #5
it's measured at the wheels. just go to a truck stop with a scale and get your weight with you in it.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
