Sep 23, 2009, 05:17 PM
Personal Sales Rating: ( 0)
Drives: evolution X
need retune after switching from straight tp to res/catted one??
as title says do i need retune my car after switch to more restrictive tp??
tahnks for opinnions.
Offline
Sep 23, 2009, 05:18 PM
Drives: Evolution IX GSR EDM
ofcourse..
Offline
Sep 23, 2009, 05:20 PM
Drives: evolution X
yeah that's what i tought, i have to put resonated tp b/c cannot stand drone any more. it's even worse with windows up , and winter is coming..
Offline
Sep 23, 2009, 08:35 PM
Personal Sales Rating: ( 2)
Drives: Evolution X GSR
Uhhhh. Not really. In fact I wouldn't be suprised if nothing changed at all. the AFR might change a tiny bit, but as far as REQUIRING a retune I highly doubt it. Maybe some tuner can chime in.
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Sep 23, 2009, 08:36 PM
Personal Sales Rating: ( 46)
Drives: AS Evolution X GSR SSS Traded 9 MR
^ that. wont be that big of a change but to get the best gains or in your case goin backwards in your gains a tune would be better.
__________________
Evolution X GSR SSS
2007 & 2008 Best Mitsu OC MD Car Show
2nd 2009
LaScuola Motorsports
Tuned by Kreionic
12.8 @ 108
Advan RS 19x10 // ARC Knob // BC Coilovers // Bride Custom Shiftboot, Armrest & Door Panels // Custom CF Wrapped Dash // Defi White Racer // Rexpeed CF Hood Vent, CF Antenna, and CF Fender Vents // Ultimate Racing O2/DP, TP, Catback
Offline
Sep 23, 2009, 09:39 PM
Personal Sales Rating: ( 5)
Drives: Evo X GSR
You don't need a tune at all. As far as the exhaust is concerned, you're going from a straight pipe to a straight pipe. Resonators are straight through. All you're doing is quieting the exhaust tone, not adding any restriction whatsoever.
Even if you were swapping to a high flow cat, they flow enough that there isn't a significant restriction which would require a retune.
__________________
2008 Octane Blue Evo X GSR • SSS / Navi / Aero
Engine • Cobb AP • AMS Intake • Nisei UICP & LICP • ETS 4" Intercooler • Tial 50mm BOV • T1R O2 Downpipe • Custom 3" high flow cat • Custom 3" dual catback exhaust
Chassis • Gram Lights 57 Maximum 18x9.5 +22 • BFG g-Force Sport 245/40-18 • Eibach springs • Whiteline rear swaybar
Exterior • APR Front splitter • AMS/Gates gurney flap • Ralliart taillights
Interior • TWM Short throw shifter • AMS shifter bushings • AEM Analog boost gauge
Offline
Sep 23, 2009, 09:41 PM
Drives: '06 MR SE
Probably not but i guess for IDEAL performance you might want to.
__________________
335hp/345 ft-lbs @25psi on 91oct (5500 ft. altitude...) by JustDSM
Offline
Sep 23, 2009, 09:42 PM
Drives: '06 MR SE
This is probably pretty accurate. I don't think the resonation would change the flow a whole lot.
__________________
Offline
Sep 23, 2009, 10:05 PM
Drives: Evo X GSR
Resonation doesn't change the flow at all. There's nothing inside a resonator that protrudes into the exhaust stream. It's a straight pipe.
Straight through, no restriction, just a quieter tone afterwards
__________________
Offline
Sep 23, 2009, 10:15 PM
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
No retune needed. As long as pipe diameter is the same.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Sep 24, 2009, 02:45 PM
Drives: evolution X
thanks guys!!! that's good news spoke with my tuner and he confirms that too. have to get resonated tp at least just for winter , drone with closed windows during highway cruise is CRAZY!!! hope that resonated tp gonna help me.
thanks again!!
Offline
Oct 25, 2009, 07:56 PM
Drives: 2010 GG EVO X GSR / SSS
it will
Offline
Oct 26, 2009, 10:09 AM
Drives: evolution X
yeah i put res tp about one month ago, it's way better less vibrations and drone. thinking about put one more actually.
Offline
Tags
add, bc, cai, cat, catted, coilovers, downpipe, dp, evo, evolutionm, exhaust, flow, force, garage, high, retune, tp  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
