Sep 10, 2009, 01:52 PM
#31
Personal Sales Rating: ( 9)
Drives: 2008 Evolution X GSR 2004 Evo VIII RS (sold)
Quote:
Originally Posted by GST Motorsports
I require all E85 tunes that come through our shop to have widebands so they can keep an eye on their fueling. It came in handy a couple months ago when the local E85 station was serving up E50...
Yeah, mine has come in quite handy already with this lean issue  . I won't ever run without one with all of the variables I have now. FWIW, I'm at +6 ltft and still getting 13s at WOT. It's looking more and more like a mechanical fuel system issue.
Offline
Sep 11, 2009, 03:30 PM
#32
Gold Sponsor
Personal Sales Rating: ( 34)
Drives: a fast Mirage.
Aren't both factory lines black?
Offline
#33
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
Nope, larger one is semi-translucent white and the smaller one is black.
You can see in the UR kit photo I posted what they are from the factory.
- Bryan
Offline
Sep 11, 2009, 03:48 PM
#34
Gold Sponsor
It looks like that white line is something that Ultimate Racing includes in their kit.
Offline
Sep 11, 2009, 04:01 PM
#35
Silver Sponsor
Drives: EVO, STI
You know Scott you bring up a good question, as this was the first pump I personally pulled on a Evo 10 (it was installed by the customer way back when)
Is the stock line a flexy hose like this?
- Bryan
Offline
Sep 11, 2009, 04:08 PM
#36
Gold Sponsor
From the factory both hoses are the same black flexy hose material. Someone should probably mention this to Ultimate Racing.
- Bryan
Offline
Sep 11, 2009, 04:10 PM
#37
Silver Sponsor
Drives: EVO, STI
Thanks for bringing that up.
The UR in line-filter wasn't able to handle the pressure at 29psi of boost either as it swelled...
Offline
Sep 11, 2009, 05:34 PM
#38
Personal Sales Rating: ( 0)
[/quote]I require all E85 tunes that come through our shop to have widebands so they can keep an eye on their fueling. It came in handy a couple months ago when the local E85 station was serving up E50...[/quote]
Bryan
Any chance GST would be willing to package a kit with injectors, fuel pump and all needed accessories to go along with. Like filters and hoses. It is a pain trying to figure out all the small things I need as it seems to be changing.
And I guess I need a Wide band for my post tune driving. Anyone have any suggestions on where I can get a good wideband? And anyone have some alternatives to the UG racing filter kit? I am starting to think for the money it may be easier at this point just to pick up a turbo and wait for all the dust to settle around the E85 on the X.
Offline
Sep 11, 2009, 06:25 PM
#39
It seems like HB Speed makes a similar setup to UR but the adapter sleeve that houses the Walbro is made from plastic instead of aluminum which reduces the costs. One of my concerns is the heat that builds up in the pump if it's isolated from the sloshing fuel that cools the OEM unit. The aluminum in the UR kit probably conducts the heat pretty well but I'm not sure how much the HB unit's plastic will insulate the pump.
I'm also unclear about whether there needs to be an additional in-line filter installed somewhere downstream. On the 8/9's I thought the only filter was the "sock" in the tank. I don't see any other filters on the car. Is it the same on the X?
Do the Walbros get hot if they are not sloshing around in fuel?
This whole fuel pump thing seems to be the only issue left to overcome for the E85 transition now that Deatschwerks has the 1000cc high impedence injectors available.
Come on GST, find us a solution for the pump/fuel lines!!!
Offline
Sep 11, 2009, 08:11 PM
#41
Silver Sponsor
Drives: EVO, STI
Quote:
Originally Posted by RB185AFM
Bryan
We do have a "E85 kit" for the Evo 8/9 which includes everything needed. The only differences/additions with the 10 would be the pump sleeve / inline filter / small replacement hoses. Since we are getting this request more and more I think it's time for us to offer these as well...
Our Evo 8/9 kit includes a zeitronix wideband, it's the best one I have found to work every time with no fuss and has the warning box for people that do not want the LCD screen (or they can combo)
Offline
Sep 11, 2009, 08:14 PM
#42
Silver Sponsor
Drives: EVO, STI
The stock pump is surrounded by plastic as well, afaik.
There does need to be an inline filter because the walboro pump upgrade does away with the whole inner assembly which is where the OEM filter was.
On the 8/9, the actual fuel filter is part of the plastic pump assembly and stays when the pump is upgraded.
The fuel sock is only to prevent the pump from sucking up anything.
Offline
Sep 11, 2009, 08:15 PM
#43
Drives: Evo 8
I just built a custom double pump in a viii and the car has been running strait E85 for over a year, and had the same e85 sitting in the tank for about 4 months.
No visible damage to anything.
Offline
Sep 11, 2009, 08:32 PM
#44
Personal Sales Rating: ( 26)
Drives: tanks into the shop
Congratulations but what the hell does this have to do with an Evo X?
__________________
MWE can suck my balls.
Offline
Sep 11, 2009, 09:00 PM
#45
Drives: IX SE, 05 Outback, 99 Civic
Quote:
Absolutely Nothing.
But that is good to know
__________________
gunhaha
Offline
Tags
255, braided, compatible, e85, earls, evo, filter, fuel, hose, line, problem, sae30r9, ss, stainless, walbro, x  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
