Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 1, 2009, 11:37 PM   #1
Personal Sales Rating: (10)
R0ME0's Avatar
Drives: N/A
X GSR Oil Cooler Specs
Does anyone know the dimensions and number of rows the stock GSR oil cooler is? This info would be super helpful! Thanks in advance!
Offline
Old Sep 2, 2009, 07:10 AM   #2
Personal Sales Rating: (7)
2008 Mitsubishi Lancer Evolution
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Bump for answer as I am interested as well. Mine is bombarded with rocks especially from the side that faces the wheel well. I plan on removing all the rocks and straightening the fins this weekend to get airflow back up again. I'm also going to zip tie a finer mesh against the plastic wheel well so that larger rocks aren't beating up the core so badly.
From the front I also noticed that the ducting isn't really complete leading up to the Oil cooler either and I may try and seal it up better so the airflow is forced through the core.
It would be good to see what aftermarket cooler upgrades there are that will fit the Evo X.
__________________
Chris Wirth
Onelap.RochesterDSM.org
2008 Evolution X (11.7 @ 118 mph)
- Garrett GT3076R - Prototype Intake Manifold
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" v1 CB - ATP O2 DP w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- 275/30-19 Yokohama ADVAN Neova AD08 on 19x9.5 Kosei K3 Wheels
- BC Racing ER Coilovers (10k/10k) - Rear Anti-roll Bar
Offline
Old Sep 2, 2009, 07:15 AM   #3
Personal Sales Rating: (6)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
I'm sure you can fit much larger cores in that area. But it's not needed for a daily driver, I think the OEM one does a good enough job. I'm sure one of the larger vendors will make a kit eventually. Is it needed for 95% of the people probably not.
__________________
List:
-Clipse3GT Tune -COBB UICP, LICP, BOV HP, SF Intake, Turbo Inlet Pipe, Sway Bars -ETS 4" FMIC -AMS DP, Fuel Rail, Rollerstop -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -GM 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant. -Advan RS 18x10
Future:
FP Green Turbo (to install)
XXX Exhaust Manifold
Offline
Tags
2008, cooler, evo, gsr, oem, oil, specifications, stock, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
