Help! Clutch pedal all the way down...
Old Aug 22, 2009, 03:51 PM
Riz5's Avatar
Well guys, I was pulling out of my driveway today and I put my car to 1st gear and right when I'm letting my clutch go it just "popped" and the car stalled. At this point the clutch pedal was all way down on the floor and I didn't know what had happened.
And ideas to what has happened and how to fix it??
Old Aug 22, 2009, 05:05 PM
slonez's Avatar
The master clutch cylinder just busted.
I blew 3 units before converting to E9 version.
My suggestion is you go the same route using the E9 master clutch or at least get the AMS ring with a stock replacement (my last one with the ring did not last very long either).
https://www.evolutionm.net/forums/ev...-breaking.html
Old Aug 22, 2009, 05:15 PM
Babs's Avatar
retainer clip?
Old Aug 22, 2009, 06:49 PM
Riz5's Avatar
I think it might be the master cylinder, and slonez I might have to try the E9 version then if that is true. Also, it could be the clutch line also. I'll have to find out monday when I get my car towed to the workshop.
Old Aug 22, 2009, 07:44 PM
XIEmperorIX's Avatar
Couldn't it also be the slave cylinder? If it's not functioning right I believe it can cause the same problem.
Old Aug 23, 2009, 07:42 AM
slonez's Avatar
If it is the master clutch cylinder, I don't see the point of replacing with the stock unit.
Good luck.
bbong
Jun 11, 2017 05:25 AM
marcouxa1
Mar 8, 2014 02:28 PM
clubEVO93
11
Jan 3, 2011 06:05 AM
erniebu
Oct 27, 2010 10:19 PM
momo_EVO8
Northwest Region
45
Jul 16, 2009 11:49 PM
Quick Reply: Help! Clutch pedal all the way down...
